first time i noticed this was yesterday, but i didnt think anything of it for some reason. until today when it continued to happen today. regular driving around is fine, and i can boost up to 15 lbs just fine as well. anything more than 15lbs (mbc is set to 21-22 roughly) and its almost like the car is backfiring, yet still accelerating. you can feel the loss of power as well. power cuts in and out almost like im hitting fuel cut or something. I previously had a cel due to "overboosting" so i cleared my codes last night, and lowered my mbc from 24 lbs to 21 lbs.
as of now, there is no cel, and i am not triggering limp mode. anything above 15 psi and the car hesitates and sputters. could this be as simple as a boost leak? where should i start if the car is not throwing any codes? should i continue to drive and wait for a cel, then check it?
my gut feeling is that it is a boost leak. i've never had one before so i cant compare it to one, but it is strange how everything is fine up until 15 lbs. i cant pressure test right now because i dont have access to any kind of compressor. if you guys think its a boost leak ill start going over the common places first (tbb, f hose, ic piping)
