Results 1 to 30 of 30
    Veteran Member Three Rings pa4ul's Avatar
    Mar 20 2008
    03 Audi A4 1.8T/ 72 Ford F-100
    south
    my mechanic is going to get sued!
    MY damn mechanic is going to get the fuck sued outta his ass. he had my car for a month said he was goin to fix the studdered now my car shacks like no one elses buisness and is makin a loud knock sound from the airbox. What the hell is a matter with him. im almost positive he grinded down my tb butterfly plate cuz i see more markings on my coilpacks that look almost identical to the marks on the tb. Hes got it coming to him. Any idea though what the noise from the Airbox could be?
    Jun 08 2008
    Calgary AB Canada
    Re: my mechanic is going to get sued!
    WOW! he fucked up your throttle body!
    Mar 20 2008
    south
    ya dirty style. fuckin a hole grinded down the plate and told my dad that i had probbly done it on my own to try to increase the air to gas mixture. damn theif
    May 24 2007
    Southern California
    Quote Originally Posted by pa4ul View Post
    what an idiot. yea only at idle?? lol
    Kyle
    2.0L Revo GTRS Eliminator
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    Dick move and a half....thats like 40 more hp at idle hhahahahahahahaha
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    WTF?? why would he touch that part of the TB. what was the reason you brought the car in to this guy's shop?
    {99.5 Avant}
    Mar 20 2008
    south
    cuz it had a small studder and i couldnt find out why it was studdering. I had already replaced coilpacks airfilter fuelfilter sparkplugs and still no fix. Ive checked for vaccume leaks and fixed a few valves that had been corrided and still it studders. So i took it to this guy that supposdly works on audis and blah blah calls me a month later and says the tb had been grinded down and accused me of doing it. I told him to put the tb back and no touch it anymore. I went to pick up my car and now it shakes waaaaay worse then what it had. It use to be driveable, a small studder only at idle and now it shakes all the time even while drivin down the highway and it cannot even hold a steady idle. i order a new tb off an audi tech and am going to replace it on my own and see if that is it. I hate this damn shit i want a new car. someone have any idea why it studdered before even after all the fixes?
    Jul 09 2007
    01 A6 4.2 QUATTRO
    Portland, OR
    umm all i have to say is wow, being a professional automotive technician, i cant possibly imagine why you would take that butterfly valve off and grind it down??? if it was a problem from the get go you would just sell a throttle body and be done, and a month?? This guy officially goes down as a hack, its people like this that give good mechanics like myself bad names.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Lets not start bashing this guy, there's no proof it wasn't like that before.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    I just dont see why he would have grinded it down......
    You say there was small studder before you took it to him, which could have been a minor crack/chip in the butterfly valve, and over that month the rest of it just crumbled away. (Into your engine, which could lie more problems....)
    -Sami-
    Mar 20 2008
    south
    well it came back way worse then it went in so he obviously did something to screw it up!
    Veteran Member Three Rings eg6siR's Avatar
    Feb 06 2008
    1993 honda civic Si, 2004 Audi
    pittsburgh pistolvania
    he said the guy told him it was grinded down and that was the problem.... it looks like it wasnt even removed to grind it, thats why the rough ass cuts from the die grinder are still there...
    snailspeed.net
    04 1.8t 6spd dolphin grey
    "you can go fast cheap but it wont be perfect, or you can build it right and go fast, but it wont be cheap"
    Jul 09 2007
    01 A6 4.2 QUATTRO
    Portland, OR
    well someone is lying here, and if you yourself grinded down the throttle body and took it to the mechanic to find out what is wrong that is about as retarded as it sounds, and it sat a month at this guys shop?? in this economy?? hell i know how slow every shop is right now. i guess the tb coulda been jacked from the get go, but something seems o so fishy about this.
    Feb 19 2007
    Charleston, SC
    I went to school to get my automotive technology degree, so I have seen some dumb f^vking "mechanics"; and I cannot see anyone of those people doing something as retarded as grinding down the plate.
    something indeed sounds fishy
    -Sami-
    Mar 21 2006
    Lakeland, FL.
    Someone was trying to raise the idle or lean it out at idle. Since my cam install I've have a hard warm start issue, give it some gas and it'll fire right up. I've been thinking is drilling a small hole in the TB plate to lean it out at idle/start up.
    I'm back bitches!
    Veteran Member Four Rings Redgoat's Avatar
    Sep 16 2005
    Quote Originally Posted by dirtybrd View Post
    Someone was trying to raise the idle or lean it out at idle. Since my cam install I have a hard warm start, giving it some gas and it'll fire right up. I've been thinking is drilling a small hole in the TB plate to lean it out at idle/start up.
    LOL why not just trade with this guy?
    -Karl
    NWQuattro - Northwest Audi Club
    USP CLUB MEMBER #8
    BetaAlphaTau member #10
    Mar 21 2006
    Lakeland, FL.
    Hahahaha
    I'm back bitches!
    Nov 12 2007
    '03 A4 1.8TQM
    Washington
    i did it!
    got you good
    Looking to buy USP Front.
    Mar 21 2006
    Lakeland, FL.
    Can you post a better pic of the area that was gound down?
    I'm back bitches!
    Aug 26 2005
    If you drill a hole, then the ECU can't control idle speed and the idle speed will be to fast. Instead, consider using a start up air throttle bypass valve. A 12vdc solenoid valve with a ~1/4" orifice, connected with hose barb fittings, to connect to the intake manifold anywhere downstream of the throttle valve. Then, connect the solenoid to energize with the starter solenoid. While cranking, the bypass valve will be open admitting the extra air flow needed, then as soon as the engine starts releasing the key closes the bypass extra air and stops the starter at the same time.
    Apr 12 2007
    Milwaukee
    can just tweak ch 4 and ch5 on lemmiwinks to lean out idle, and even tweak ch8 to lean out baseline mixture (effective on low maf reading such as idle)
    Mar 20 2008
    south
    look all i know is i never messed with the tb. never really had a reason or intention to until i heard what i heard from this guy. he marked the coil packs the same way the marks are on the tb. there scratched into the part. i didnt touch a damn thing if thats wat some of yall are insisting. when i took the car in it had a small studder. like i said now it has a loud knocking coming frm the airbox the car idles rougher then hell it can barely even stay on it sounds like. when i drive a let go of the gas the car shakes and studders and it had never done any of this until i got it back from him. before i took the car to him it had a studder only when in park and when i turned on the aircondition the studder went away completly. now it always shakes even while driving.
    Sep 16 2005
    Cheer up ... at least your Throttle body is happy
    -Karl
    USP CLUB MEMBER #8
    Aug 26 2005
    Quote Originally Posted by infernocl View Post
    Most tuners are now blocking any changes to the adaptation channels by lemmiwinks or similar programs.
    Nov 12 2007
    '03 A4 1.8TQM
    Washington
    i before e except after c
    Mar 20 2008
    south
    Quote Originally Posted by Redgoat View Post
    lol that makes me feel a little better
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    Pictures don't work... As usual, Pr0n is late to the party.
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Jul 09 2007
    01 A6 4.2 QUATTRO
    Portland, OR
    how about pictures of the coil packs as well, i mean if u got evidence lets see it all.
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    Quote Originally Posted by brewmastr View Post
    you're not a good mechanic, you work on benzs :P
    Veteran Member Four Rings JMRQuattro's Avatar
    Jul 04 2008
    Seattle, Washington
    ^^ haha.
