Results 1 to 6 of 6
    Senior Member Two Rings al3x's Avatar
    Oct 08 2007
    Norway
    Installing HID in S4 fogs
    Hey,
    Just wanted to know if anyone has any tips regarding installing a HID kit in the S4 fogs?
    Seeing as how you need to pull wires back and forth to the ballast I really can't figure out how to do it.
    Only solution I see is to cut away part of the back piece:
    Wasn't too sure if this thread should be in the S4 section or not.
    Oct 08 2007
    Norway
    Re: Installing HID in S4 fogs
    Almost 60 views and not a single idea? =/
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    try asking in the S4 forum
    TEAM|AXION
    Oct 08 2007
    Norway
    Guess so, figured I'd try in here since so many are running S4 bumpers and fogs.
    Veteran Member Three Rings xraycer2012's Avatar
    May 28 2008
    B8.5 S4
    You are going to have to drill a hole in the back. There's no getting around that. What HID kit did you get or better yet, do you have any pics of the kit you bought and some other angles of the back piece of the fog light. I'm not familiar with S4 fogs, but I should be able to help you if you have some more pics.
    ‘23 RS6
    '14 S4 Nogaro Special Edition - Sold
    Oct 08 2007
    Norway
    Quote Originally Posted by xraycer2012 View Post
    Yeah, that seems to be the only way to do it. Cut of part of the backside and run the cables and then I'll have to figure out a way to keep the bulb in place.
    Don't really have any other pics atm, but the HID kit is the same as every other set (H7 bulb).
    Thanks for the reply btw :)
