    Veteran Member Three Rings Outkasted's Avatar
    Feb 12 2004
    01 986 Boxster/ Unrestricted Hayabusa
    suspension noob needs help
    I just bought a set of coilovers used. I recieved them with no wrenches. I noticed that the perches seem to be rusted in place because i can not get them to move. My question is the rear shocks are seperate from the springs and i noticed that i can push and pull the cylinder piece or shaft in the middle with next to no effort. Should u be able to move this that easily or is the shock blown and i just got ripped off.
    Always looking for the next project
    Feb 12 2004
    Re: suspension noob needs help
    anyone? Come on someone knows the answer this is a fairly easy question.
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    What brand are they?
    If the perches are rusted, soak them in some PB Blaster, that may help to free them up.
    Generally, most shocks should have some resistance when compressing the pistons by hand. Some will be harder than others, it depends on the design of the shock.
    Feb 12 2004
    so you can move them by hand. That is what i really needed to know. I don't see any leaks or anything just wasn't sure if you are suppose to be able to do that. Thany you very much.
    Feb 12 2004
    oh yeah koni shocks
