Results 1 to 25 of 25
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    time for new tires. suggestions?
    Alright so im finally done with my stock pirelli P6's at 21k miles. I'm in the market for some new tires but I don't know what to get... and that's where you guys come in.
    I need UHP all season tires that have very good dry and wet traction with light snow capabilities. it doesnt snow much here in socal but whenever it snows in the mountains, i'll be snowboarding. I don't really care about how good the snow traction is.. as long as it's capable of doing so.
    cliffs for the lazy:
    I want a tire that has excellent dry/wet weather traction, with snow capabilities.
    so far i'm looking at:
    Toyo Proxes 4. Heard they have soft side walls though.
    Falken 912
    any suggestions?
    Active Member Four Rings Goped220's Avatar
    Feb 16 2006
    2023 Audi S4, 2023 Audi A4 & 2016 Subaru Crosstrek
    NY/FL
    Re: time for new tires. suggestions?
    Bridgestone Potenza RE050A Pole Position
    Previous:
    2006 Audi A4 Stage 3 6-Spd, 2011 Audi S4 6-Spd, 2016 Audi S4 6-Spd, 2017 Audi A4 6-Spd Stage 2, 2019 Audi S4 Stage 1, 2019 Benz E450 Stage 1, 2015 STI, 2013 370Z, 2013 Benz GLK, 2014 F-150 FX-4, 2020 Lexus GS350 F-Sport
    Senior Member Two Rings 4ringsinLA's Avatar
    Sep 26 2006
    B7 A4 Avant
    socal
    You should definitely check out the BFG super sport a/s. Great tires and can be had for a good price. On a cosmetic side, the side profile of the tire looks sleek and nice as well
    Nov 15 2007
    Quote Originally Posted by Goped220 View Post
    those are so expensive >_<
    Veteran Member Four Rings johnnybravo!'s Avatar
    Feb 20 2006
    323 EASTLOS, CALIFAS
    Of the 2 go with the Falken..
    SRM K24 - Bosch 1000cc - Rods - 2.8 Cams- RR STG 4 clutch - AA-built 01E+4:1 - OS Giken LSD - ER IC's - JHM SS - SRM DPs - Vibrant 3" - Vast W/M - RS4 Y-Pipe - ASP MAF - APR Bi-Pipe - Ohlins MS Coilovers - AP Racing BBK - 034 Rear Sway
    C7 A7 Silver- Jackal STG 2+E40 Shane Horning ported s/c Merc HX- Pierburg 100-3 - Eibach Springs- OZ 20" UL wheels/Michelin PS4s- Eurocode Sway Bar- Borla- IE Intake
    Audi. Truth in Understeering.
    Veteran Member Four Rings Six Speed Turbo's Avatar
    Feb 09 2007
    Hopes, Dreams, Tools, Car Parts
    Killeen, TX
    Falken
    2016 S3 Prestige - Glacier White Metallic, APR Stage 3+, APR TCU upgrade, APR CAI, APR FMIC, APR Catchcan, APR Lowering Springs, P3 Guage
    YouTube Channel https://www.youtube.com/channel/UC88...LbgXXvRHPvW3Xw <---SUBSCRIBE
    Veteran Member Four Rings MAlby7's Avatar
    2017 Infiniti Q50S (HIS), 2014 Nissan Rogue (Hers)
    Woodbridge
    That has 0 snow capability. Also the Falken 912's won't be too good in the snow either. My uncle put them on his Accord but he only runs them in the summer.
    My suggestion would either of the following:
    BFG g-Force Super Sport A/S:
    Yokohama Advan S.4.:
    Michelin Pilot Sport A/S
    Senior Member Three Rings Blarg's Avatar
    Sep 08 2008
    Kansas City
    I'm going with the new Goodyear Eagle GTs, good reviews and great price!
    Sold - 2006 A4 S-line Quattro 6M Nav
    Nov 05 2007
    Oregon
    Would have to disagree with everyone else above:
    http://www.tirerack.com/tires/tires....+F1+All+Season
    These are what I'd suggest. Good reviews from colleagues on other Audi forums, in fact I've never heard a negative review from an owner of these. Understand that none of the tires you're looking at are going to be quite as sticky as a summer tire, but I think you know that. These are definitely the way to go, and not outrageous via TR.
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    continental conti extreme contact
    TEAM|AXION
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    i was really happy with the falken ziex's, i had both the 512 and the 912.
    they're a little loud, but that's pretty much the only downside that i could really see with them. they gripped well in dry and wet. the sidewalls were stiff enough that they didn't feel sloppy in hard cornering. i had them on a rear wheel drive car, and i could get around just fine in a few inches of snow. i'm sure with quattro, they'd be fantastic.
    i have not tried the toyos, but i've heard good things.
    Registered Member Four Rings
    Apr 24 2007
    Great Lakes of SoCal
    Where are you getting the tires from? PM me if you need a place
    Got Oetty?
    www.DiscountTires.com
    Just updated!!
    Feb 16 2006
    NY/FL
    MAlby7 I know these tires are not for snow. But you can get away with it i have done it. As for the all season i would go for the Potenza RE960AS Pole Position.
    Previous:
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    www.edgeracing.com has really good prices on falkens
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    so you want all-seasons? give us a price range per tire...
    May 22 2008
    2013 Audi S4 IceSilver MMI/SD/DSG/AK
    Bay Area
    I really like my proxes 4's I recommend tham :).....
    Ice Silver S4 Black Int. Sport Diff DSG, B&O, Nav, Advanced Key
    Feb 16 2006
    NY/FL
    Toyo sucks. I had the T1R and I hated them. Tires are one of the most important things on a car. I would not cheap out on them.
    Here is some good Info:
    The Potenza RE050A Pole Position features a higher 90% silica content tread compound molded into an asymmetric tread design with stable shoulder elements, large tread blocks and a continuous center rib on the outboard side to provide responsive handling, high-speed stability and traction on dry roads, while wide circumferential and lateral tread grooves pump water out from under the tire’s footprint to minimize hydroplaning and aid wet traction. Another continuous circumferential rib adjacent to the inside shoulder blocks enhances wear quality to help reduce noise throughout the life of the tire, especially on cars with alignment settings that specify negative camber. The tire's structure includes twin, handling-optimized steel belts reinforced by spirally wrapped nylon to stabilize the tread area and enhance traction, high-speed capability and ride quality while minimizing weight. The fabric cord body and higher sidewall reinforcement helps blend uniform ride quality with steering response and lateral stability.
    This place has Bridgestone tires for about $25.00 less than tire rack which is unheard of. Everyone tries to match tirerack’s prices.
    http://www.roadwaywholesaletire.com/
    Previous:
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Quote Originally Posted by MAlby7 View Post
    You can tell from the treads this tire will not be good throwing water or snow which usually means the water may trap in the treads and when it comes back around the water/snow has no where to go..
    Mar 14 2005
    stl mo
    i had these on the b6 and liked them quite a bit:
    Bridgestone Potenza RE960AS Pole Position
    2003 Platinum Grey MKIV Jetta 1.8T Tip[sold]
    2002 Dolphin Grey B6 A4 1.8T 5spd Quattro[sold]
    2005.5 Quartz Grey B7 A4 2.0T 6spd Quattro[sold]
    2011 Brilliant Black 8p A3 S-Tronic Quattro
    Woodbridge
    Quote Originally Posted by Sanjman View Post
    And where does this educated guess come from? Check out the wet traction rating on tirerack and see if your opinion still stands: http://www.tirerack.com/tires/tires....odel=ADVAN+S.4.
    Nov 15 2007
    Quote Originally Posted by nsmith12 View Post
    my budget is 150 a tire.
    Nov 15 2007
    anyone ever tracked with any all-seasons? :D
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    $150 for a 235/35/19?
    Veteran Member Three Rings Audi Juice's Avatar
    Feb 11 2005
    08 Titanium
    Huntington Beach
    Toyos will be the lightest out of the ones you are considering. Thats enough to sway me.
    Hey Kevin, I'd really like to go for a ride in your car again to see what the PSS9's feel like.
    Also, if you want to just do Pirelli again it would be a lot cheaper since you have that full size spare in the trunk. Im so glad I have an extra PS2 back there.
    Jul 30 2008
    08 Passat 2.0t
    Near Mountain Creek
    Don't get Falken 912. I have them. I don't want to think about driving them in the snow, ice, or slush. Also, they aren't that good for Autocross. Falken recommends the 452 (and Azenis 615) for autocrossing.
    The siping is very minimal, M+S rated? I call B.S. in terms of actual usefulness in the winter. Along that note, don't bother with Pirelli P-Zero Nero M+S.
    You won't want the Kumho ECSTA ASX--- soft side walls are common with many Kumhos
    How about Goodyear Eagle F1 All-Season? Though I am not a goodyear fan.... they are supposed to be the best of the compromise tires
