Results 1 to 11 of 11
    Veteran Member Four Rings Jet Jockey's Avatar
    Jun 17 2004
    2017 B9 A4 Quattro/DSG/Technik/S-Line... 2004 B6 A4 1.8T Quattro race car
    Montreal, Canada.
    NEW MOD... Time for the install of the OMP steering wheel with a SPA quick release...
    First I would like to thank Ben and Marc at <AUTOSPORT SERVICES for their work. Ben is also the technical rep for ECUTEK North America. As such he travels the whole world to train new technicians and program Subaru STIs and EVOs with Ecutek's proprietary software. Also part of the project was Ioan and Joel from TEHCNOART COMPOSITE. They specialize in Carbon Fibre, Fiberglass, and any metal and make basically anything from scratch in their machine shop. Their specialty is prototyping a project from it's beginning on the drawing boards to its completion.
    OK because I backed up my Recaro race seat as far back as I can in the car (right up against the roll cage) my OE steering wheel/column was not long enough even in its fullest extended position. Besides I wanted a race steering wheel with a quick release to be able to get in and out easier.
    First part of the project was to disassemble the OE steering wheel, the control column and the two shafts that link everything together. As you will see this stuff is heavy and as a bonus I was hoping to shed some weight and we did between 5 and 6 pounds when all was done.
    Once all the padding and cosmetics are removed this is what is revealed. You can see the ignition harness the whole mechanism to adjust the steering column and at the back you see to shafts with two universal joints. The whole thing is held in place by four 6mm bolts (two seen here).
    In this picture we see the shaft just before the inner firewall. Notice the “collapsible” mechanism in case of an accident.
    Once the adjustable steering column mechanism is removed you are left with the two shafts.
    Here the two shafts are removed from the car and are about to be cut apart.
    The shafts were then secured on the bench saw to be separated at the proper location. We did not need the portion or smaller shaft but we wanted to keep the “collapsible” portion.
    Here’s the mechanism for the adjustable steering column once removed (no light weight). This is the top view.
    Another angle showing the bottom side.
    Here’s the OE aluminium casting assembly that secures the whole thing to the car. We wanted to use it at first but it would have been too complicated to remove the inner guts. So we decided to make our own by copying it.
    Here’s the initial design of our plate to secure the new steering wheel assembly in place. More holes would be punched out to lighten it and two reinforcement brackets would be welded to the final design to increase its rigidity torsionally. It’s made of a ¼ inch thick aluminium plate.
    So now we need to replace the OE shaft or column that was cut off and measure a new one to the proper length for my seating position. We decide to go with ¾ inch steel tubing.
    To secure the new column we went with this type of bearings, two of them that would be mounted to the new plate in this fashion.
    Close up of the ¾ inch steel tubing with the bearing installed.
    The bearing housing is aluminium with a brass insert covered by a stiff rubber ring impregnated with grease. This provides maintenance free operation.
    Here’s the female part of the SPA quick release. The other end bolts onto the steering wheel.
    Here’s its male counterpart. The shaft is actually bigger than our ¾ inch steel tubing. It will be welded to our new steering column shaft/tubing.
    After the welding and machining to the steel tubing.
    Before we go onto the other step which is the connection of the new tubing to the OE collapsible shaft we need to look how the OE shafts were press fit into the universal joint. The end that will be removed is just below the green mark.
    So the other end of our new shaft was secured in a milling machine to get some custom shaving. LOL.
    Just enough steel matter removed to press fit it into the universal joint.
    Here the new shaft is joined to the universal joint by press fitting it into place.
    Reverse angle or the other side of the shaft/universal joint.
    To be safe of course the outer side was also welded to prevent the shaft from coming out. The two bearings at this point have already been installed onto the shaft.
    Assembling the new shaft and OE collapsible shaft to the new aluminium plate. Shown here is the top side of the plate. The bearings and shaft are on the bottom side of the installation. As you can see more holes were punched out to reduce its weight.
    Here’s the other side or bottom side.
    Here’s close up showing the bearings and the stiffening bars.
    Here it is once installed in the car.
    Another angle.
    Finally the OMP steering wheel. It’s 350mm wide or 25mm smaller than the OE steering wheel (375 mm). It also as a moderate dish to it.
    Reverse side showing the SPA quick release mated to the steering wheel.
    Here it is finally installed in the car. The horn will be wired in with its own quick release at a later date (after the interior paint job).
    Registered Member Three Rings ILikeBigBrakes's Avatar
    Sep 27 2008
    2002 Audi A4 1.8 Q&A
    Orlando, FL
    Re: NEW MOD... Time for the install of the OMP steering wheel with a SPA quick releas
    Looks like a good job, nice!
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    So are you driving your car inbetween all these little project?
    -Sami-
    Jun 17 2004
    Montreal, Canada.
    Not much and not enough.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Looks great Mike!!
    Jun 17 2004
    Montreal, Canada.
    Quote Originally Posted by 400HPA4 View Post
    Looks great Mike!!
    Thanks Greg!
    Veteran Member Three Rings eg6siR's Avatar
    Feb 06 2008
    1993 honda civic Si, 2004 Audi
    pittsburgh pistolvania
    i love your pedal assembly!!! it looks like it would perform very well
    snailspeed.net
    04 1.8t 6spd dolphin grey
    "you can go fast cheap but it wont be perfect, or you can build it right and go fast, but it wont be cheap"
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    I always love these posts. There's no way I'm ever selling my B6 with their shitty resale value, especially after going BT. That's why there's a special Jet Jockey section in my brain's long term memory
    I hope some day there's a Jet Jockey rally car project....
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    Dec 06 2007
    Mike u r the man! looks amazing but see the only reason why this car is so famous is because u do good work u don't cut corners and that is worth any track car here.
    -Kirk
    BetaAlphaTau Member #58
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    I really like that steering wheel
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings Silence's Avatar
    Mar 19 2004
    Vegas
    Like I said, first dibs on your car when and if you decide to sell it. It'll definitely be my track/weekend whore.
    Cheers! David
    ____________________________
    Garage sale! Tons of A4/S4 parts available
