Results 1 to 2 of 2
    Senior Member Three Rings Insomniac's Avatar
    Jun 03 2008
    Hershey
    Vacuum Line Size?
    I want to fix up my vacuum lines on my 2.8 30v. The oem rubber hoses are pretty old and crusty. Here's a pic of the lines I'm talking about (blue lines):
    Are these lines from 034 the right size?
    http://www.034motorsport.com/product...ducts_id=18194
    or should I get these oem cloth covered ones http://www.034motorsport.com/product...roducts_id=202
    free earl
    Jun 01 2008
    Apopka, FL
    Re: Vacuum Line Size?
    silicone will out-last the car itself.
    cloth covered rubber is better than un-covered rubber because it protects the rubber from heat and the elements which is the major source of failure, but it will still dry out because that's what rubber does naturaly.
    this is a good case of more-expensive does not mean better.
