Results 1 to 20 of 20
Thread: Boost Leak???
    Senior Member Two Rings p.tony's Avatar
    Sep 02 2007
    2000 s4 Stage 3, 1997 Lexus sc300 na-t, 2004 Touareg v8, 2007 Corvette
    Baltimore, MD
    Boost Leak???
    So i think i have a boost leak. My car kinda wants to stall at idle and ive lost a couple pounds of boost. Never had this experience if its the case. Ive done a search but the threads ive come across havent been too informative. Looking for confirmation and help on how to do a pressure test to find the leak. Thanks
    00 C5 2.7t //Stage 3//
    Senior Member Two Rings Jayco88's Avatar
    Jun 02 2008
    2000 S4
    Re: Boost Leak???
    i've had many boost leaks, but my idle has never been affected..
    -It's got nothing to do with your vorsprung durch technic, you now.-
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: Boost Leak???
    I've had plenty of misfires (feels like the car is about to stall if bad enough) becuase of boost leaks.
    Do a pressure/smoke test.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Veteran Member Three Rings JD797's Avatar
    Apr 10 2008
    Re: Boost Leak???
    no boost gauge yet? id vag it if possible, or at the least visibly inspect all the hoses and connections for any tears or loose clamps or something
    Oct 05 2006
    Baltimore, MD
    Re: Boost Leak???
    Hey, i'm in Baltimore and can help you with a pressure test this week if you would like. I have already made the AWE style tester which makes it very easy.
    Sep 02 2007
    Baltimore, MD
    Re: Boost Leak???
    Quote Originally Posted by JD797 View Post
    I have a boost guage thats how i know i have lost some lbs of boost
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    Re: Boost Leak???
    What's your vacuum?
    --Adam
    Have questions? E-mail me.
    Sep 02 2007
    Baltimore, MD
    Re: Boost Leak???
    When it feels like its going to stall it goes to 12-14 in vacuum.
    Sep 02 2007
    Baltimore, MD
    Re: Boost Leak???
    Quote Originally Posted by speedracer9k View Post
    That would be great. Im in class mon and weds after work but any other day is cool. Thanks
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    Re: Boost Leak???
    I would say first thing, double check your mods.
    Confirm your Forge's aren't leaking and are snug. Make sure your intake setup looks good still - MAF/clamps/intake etc are all snug and clean - including the plug to the MAF and any other hoses/connections in the area etc.
    Then take off and inspect your throttle body boot (TBB) if you haven't had a chance to yet.
    If nothing obvious, then pressure test.
    Good luck.
    Brilliant Black 2001 S4 - 6MT <3
    Oct 05 2006
    Baltimore, MD
    Re: Boost Leak???
    I'm available on either Tuesday or Thursday evening after 7:30pm. I do most of my work at my uncles Jiffy Lube after hours. What part of B-more are you located in?
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    Re: Boost Leak???
    Quote Originally Posted by p.tony View Post
    Is this on or off throttle? (Guessing off) If so, you do have a boost leak and the car is trying to compensate.
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Sep 02 2007
    Baltimore, MD
    Re: Boost Leak???
    Quote Originally Posted by OldYella View Post
    Off would be correct
    Sep 02 2007
    Baltimore, MD
    Re: Boost Leak???
    West. By liberty road and wabash. What area are we meeting in?
    Sep 02 2007
    Baltimore, MD
    Re: Boost Leak???
    Had a torn F-hose and TBB.
    Sep 14 2006
    14 GLI
    Re: Boost Leak???
    Sounds about right. Glad to see you've fixed your problem and thanks for updating the thread
    --Adam
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Re: Boost Leak???
    Grab some Samco's from awetuning.com. They sell both the TBB and Fhose separately so you don't have to buy the entire $400 kit.
    Or just do the Fhose delete.
    Sep 02 2007
    Baltimore, MD
    Re: Boost Leak???
    you know whats crazy ive had my car for about 3 years and these were my first 2 ever and ive torn the boot again but replaced so its number 3 boot/leak and ive got another pending. So about 4 in a months time.
    Sep 19 2008
    Toronto, Canada
    Re: Boost Leak???
    Where were your other leaks?
    Sep 02 2007
    Baltimore, MD
    Re: Boost Leak???
    i got one in the tbb again and the other i havent found yet
