Results 1 to 13 of 13
    Registered Member Two Rings Sick_Boy's Avatar
    Oct 11 2008
    01 A4 1.8tqm
    St. Charles IL
    problem with an 01 a4
    i got a 01 1.8tqm and i had a cel due to a o2 sensor so and today when i tried to reset my ecu by unhooking the neg. on the bat. i must of messed something up cause when i reconnected the bat. and started the car it wouldnt idol it would just die. i could keep it running by giving it gas but it just wouldnt idol. heres a lil vid of what it is doing http://www.youtube.com/watch?v=RhJ9IrBnS0g. is it possible the my MAS got messed up?
    Established Member Two Rings Kaytek's Avatar
    Nov 19 2005
    Ottawa, Canada
    Re: problem with an 01 a4
    Did you first put the key in the ignition and turn it to the 'ON' position but without starting to let the ecu run a throttle body alignment? Don't know if that would do it but it's worth a shot.
    Also, if you scanned the car and knew you had a CEL due to an O2 sensor, why not clear the CEL with the scanner/VAGCOM? Why unhook the battery?
    Cheers,
    Kaytek
    2001 1.8TQ Tip - GIAC X - Startup Racing Vogtland GTs
    Oct 11 2008
    01 A4 1.8tqm
    St. Charles IL
    i had autozone test it and i didnt know that you could clear the cel with the scanner but thanks man, i didnt turn the key in the one position im trying it now. how long should i leave it in the on position b4 i turn my car on?
    Nov 19 2005
    Ottawa, Canada
    Just leave it for a little while; I guess until the beeping noise changes. Word to the wise though, get a VAGCOM. Even a cheap Ebay cable and VAGCOM shareware software. Makes life so much better when you can check things immediately yourself.
    Cheers,
    Kaytek
    Dec 05 2007
    It is the throttle body adapt. If you remove the negative from the vehicle, or cut power you need to place the key in the starting position for maybe 3-5 min for the throttle body to adapt to the ECU.
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    throttle adaptation was not done.
    Oct 11 2008
    01 A4 1.8tqm
    St. Charles IL
    ok guys i let it recalibrate for about 5 mins and its still running like shit. i found a vac line off but when i put it back on nothing happened. is there some kinda anti theft that i need to clear up? and when i attached the battery shouldnt it of asked for my security code on my head unit cause it was working fine when i turned the power back on
    Established Member Two Rings A3toB5's Avatar
    Sep 22 2008
    99 A4 1.8t & 95 Golf 2.0
    Queens Get The Money
    Question.. the throttle body reset is for a drive by wire or cable ?
    Oct 11 2008
    01 A4 1.8tqm
    St. Charles IL
    drive by wire
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    I had the same type of issue and it ended up being a huge boost leak and my MAF was dumping too much fuel and couldn't compensate. Might want to try looking for that. Only takes a few minutes to run a boost leak test. Here's a video of mine stalling out: http://www.youtube.com/watch?v=VTG5tOGNh7o
    Oct 11 2008
    01 A4 1.8tqm
    St. Charles IL
    well my dv is ripped in two right now but its been that way for a week with no issues and i was told its fine to drive on as long as its not like a hour drive. but my 004 comes tomorrow
    Registered Member Three Rings Rhinop21's Avatar
    Mar 04 2008
    West linn, Oregon
    Well theres your problem. palmface now.
    http://i200.photobucket.com/albums/a.../dopeaudi3.jpg
    1998 A4 sold
    1995 Talon tsi awd. 6 bolt swap.
    Oct 11 2008
    01 A4 1.8tqm
    St. Charles IL
    yeah i feel like a dumb ass. i just dont get why it was running like a champ for the whole week it had the boost leek
