Results 1 to 8 of 8
    Veteran Member Two Rings
    Mar 02 2004
    2001 Audi A4 Avant
    Upstate NY
    Vogtland GT Coilovers On and Im Unsure
    So we installed them today and of course ran into all the same problems.
    Its my first time lowered, had stock sport, so Im not sure what to expect. I think its a bit too low right now, about 1 in above the wheel in the back and 1.5 in in the front. It rides nice over bumps, doesnt shake the car or cause it to jump around. Problem is dips, it seems to bounce a bit, even on fairly smooth roads. Is it because its too low? Is it because its new? Im just not quite felling the $1300 love.
    Current:
    2001 Audi A4 Avant, Stage 3 (17 years, 120K)
    Sold:
    1999 Audi A6 Avant, Worn (3 years, 134K)
    1996 Audi A6 Avant (5 years, 155K)
    *(Owned, Odometer)
    Senior Member Two Rings XwalkerX's Avatar
    Dec 04 2007
    2005 s4 avant
    tuffalo, NY
    Re: Vogtland GT Coilovers On and Im Unsure
    do they not offer any dampining adjustibility? (sorry im not to familiar with the vogtlands) i had a similar problem with my avant on kw coils right when i put them on but i just adjusted the dampning and rebound and now im loving life. btw thanks for the avant decal at h20...
    2004 Audi A4 Ultrasport [daily]
    2001 911 Turbo [fast]
    2005 Triumph Speed Triple [faster]
    1995 BMW M3 [sold]
    2005 Audi S4 avant [sold]
    Mar 02 2004
    2001 Audi A4 Avant
    Upstate NY
    Quote Originally Posted by XwalkerX View Post
    Your welcome. I don't know, I was under the impression they would be tuned. I will have to ask the reseller on Mon.
    Current:
    Sold:
    *(Owned, Odometer)
    Mar 02 2004
    2001 Audi A4 Avant
    Upstate NY
    Current:
    Sold:
    *(Owned, Odometer)
    Veteran Member Four Rings Jibberific's Avatar
    May 21 2008
    az
    It might be that the added weight in the back makes it sag a bit compared to if they were installed on a sedan. Your avant looks incredible right now, just if the back was a bit higher and the front was a bit lower it would be perfect. Maybe if the back was higher it would cure the bouncing because the damper would be more in its optimal range. But i can't say for certain.
    All these avant+coilover threads are making me convince myself to spend a bunch of money on a set for my car, shame on you guys.
    {99.5 Avant}
    Dec 04 2007
    2005 s4 avant
    tuffalo, NY
    car looks really good.
    1995 BMW M3 [sold]
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I was reading that those Start-Up Racing Vogtland coil-overs are not adjustable from a damping and rebound perspective.
    Let us know how you like them after you've got some miles on them. I am leaning towards them for my Avant.
    -Doug
    Feb 12 2004
    ‘23 RS5 Sportback '20 Q8 S-Line
    I havent tried this on my stasis but what i am told is to trim the bump stops. if you are hitting them it can cause the pogo effect. i get a little bit here and there.
