Results 1 to 28 of 28
    Dec 31 2006
    boston, ma
    DIY: Crystal Mod (seat mod)
    heres the entire mod to get rid of the lumbar and get better holding seats...
    start off from behind the seat and pry the back off....there are three clips at the top and then pull up
    make sure your lumbar is all the way down and back and disconnect the cable that activates the lumbar, pushing the lumbar piece helps
    now disconnect the middle spring, again pushing or compressing the black lumbar support is helpful
    now the lumbar support should slide to the left and unclip at all 4 corners
    before you can remove it..disconnect the second cable
    to get it out..turn it sideways and remove
    now you can stop here and be happy or take it a couple of steps further to get back in the seat more...your choice...heres the next step
    the two bars going up can be disconnected and brought back...these go straight up and where they connect, they curve back and then up again...a little tricky to get them out...you have to reach up, push forward and pull down...you'll also want to pull the black plastic piece in front of you to allow clearance for the new position...once the two wires are disconnected pull down and slide into the two slots near the headrest holes..you'll feel these holes when you pull back the plastic piece
    now tuck the lumbar wires off to the sides, they fit nicely and then you'll have the finished product
    last step:...put your seat back on again and enjoy your new sportier seats...
    this is what you should have left over...should take you no more than 30 minutes a seat
    enjoy..and i guess i should put: im not responsible for damage to the car or your back from you doing this..do this at your own risk
    Veteran Member Four Rings jon102034050's Avatar
    Oct 02 2006
    MN
    Re: DIY: Crystal Mod (seat mod)
    hmm, interesting looking
    A4 1.8TQ - RS4 Sway - Avic-D1 - Neuspeed Sports - Bilstein Sports - Joey Mod
    Senior Member Three Rings ProJect_*A4*'s Avatar
    Jun 01 2008
    2011 BMW M3 Comp. Package
    quick question... by removing these things what do you gain? (better holding seats?)
    and is it worth it?
    German Engineering
    Veteran Member Three Rings ehfour's Avatar
    Feb 19 2005
    2002 A4 1.8T
    Vancouver
    Interesting
    Wish a had done this. Instead of buying Non Lumbar seats!
    Dec 31 2006
    boston, ma
    Quote Originally Posted by ProJect_*A4* View Post
    and is it worth it?
    hell yes...you sit more in the seat enabling the sides to hug you more..if i had to describe the difference..it would be like going from stock to stage 1+...its a huge difference..
    best thing to do if you want to try it is do it to one seat and sit between the two...you'll feel the difference, but you'll notice it the most when you drive...its very easy to do
    0h..and i named the mod after my gf
    Veteran Member Four Rings EUROaleksey's Avatar
    Aug 10 2007
    Toronto, Ontario
    sweet dude!!!!!!!!!... im doin it!!!!!.. and im gettin a helmet!!!! ill be like a schumacherrrrr!!!!!!!!! !! in my 170 hp audiaa!!!! FAK!!!!!!
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    You will also get a bar on the bottom of the seat back jamming you in the ass
    Veteran Member Four Rings SeKKeY's Avatar
    Mar 06 2005
    MKVI GTI (dd), DTM S4, B6 USP (sold), B5 1.8T (RIP)
    San Jose, CA
    im going to try this...my lumbar support doesnt do much for me anyway
    USP CLUB MEMBER #10
    Stage 2++++++++ JHM B7 S4
    Dec 31 2006
    boston, ma
    Quote Originally Posted by 400HPA4 View Post
    no problems with this at all...seat if much more comfortable..what bar are you talking about?
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    There is a bar that runs along the base of the seat frame, you will start feeing it, trust me.
    Dec 31 2006
    boston, ma
    so you've done this before...
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Not by choice, the lumbar support broke, so I removed it. I do not like the feel of the bar jabbing me in the tailbone.
    Dec 31 2006
    boston, ma
    if you removed it, then im still not sure which bar you are talking about..are you talking about the bar in the square
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    No, I am talking about the seat frame itself. When you remove the lumbar support, it allows you to sit further back in the seat, bringing your ass closer to the hard steel.
    Dec 31 2006
    boston, ma
    hmmm, maybe by leaving the lumbar frame installed is the reason i dont feel this...ive done both front seats and pushed myself back and no problems with either...the wire frame still offers some support when sitting back which is why i didnt want to remove it completely
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I drove my car with the broken lumbar (same feeling as removing the lumbar) and had absolutely no support for my back. It felt like I was sitting against a black hole.
    The top of the seat was pressing into my neck (since it doesn't move) and my lower back was in the back seat (not literally, but pretty damn far from the upper seat).
    Drove 2.5hours like that and my back was fucked for a week. Just like when I get in a GM, Ford or Chrysler rental....
    Guess my lower back is just very sensitive from all pinched nerves over the years.
    Now, the Recaros I had in my MKII GLI were the bomb. Lumbar support, side bolsters and thigh bolsters. You didn't move once you started throwing that car through turns. I had someone offer me $3k for those seats (in 2003).
    -Doug
    Dec 31 2006
    boston, ma
    ^^^once again...you leave in the lumbar frame so this does not happen
    Veteran Member Four Rings AvanTTix's Avatar
    B9.5 Q5 55 TFSIe, B6 A4 1.8T Avant, MKI TT 1.8T 225hp Roadster
    San Francisco, CA
    Quote Originally Posted by eclimax13 View Post
    here's my mods to get better holding seats and it goes for me and all my passengers...
    Stage 2 - S-line seats...
    Stage 3 - Recaro seats...
    MY2022 B9 Q5 55 TFSIe: Daytona Gray||7-Speed S-tronic||Prestige||Black Optic||Sport Plus
    MY2003 B6 A4 1.8T Avant: DenimBlue||Ebony||5-Speed MT||Quattro||Premium||Sport
    MY2002 MKI TT 1.8T Roadster: BrilliantWhite||RedAmber w/ Baseball Optic||6-Speed MT||Quattro||Premium
    Veteran Member Four Rings a4wd's Avatar
    Jul 27 2004
    B6 1.8TQM 5speeeeeeeed
    Bay Area 925
    Doesn't get better than that. I sat in that interior and its so immaculate and OEM. Best interior hands down!!!
    another stereotypical Audi
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Not to mention it's bad for your back.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Dec 31 2006
    boston, ma
    Quote Originally Posted by dirtybrd View Post
    i guess it depends on your body shape..my lumbar was hurting my back
    Veteran Member Four Rings QuattroRocket's Avatar
    Sep 01 2004
    2103 S4, 2014 Nissan Pathfinder
    Vancouver Canada
    As usual one of tyhe nicest A4's around.
    After years of patience I may be getting my payoff ... apparently a buddy's friend is gettin an RS4 from the US and intends on ordering the Euro S4 seats and has "no use" for the RS4 Recaros so I may get REAL lucky and pick em up for close to nothing !!! Heres hoping !!!
    Quote Originally Posted by Avantéix View Post
    Gone but not forgotten : 2000 A4, 2002 A4, 2004 A4, 2013 S4 Premium, 2013 Q7, 2017 SQ5 Dynamic Edition
    Current Audi : 2017 RS7
    Registered Member Two Rings
    Feb 07 2006
    ouellette
    where's a good place to source s-line seats, and S4/RS4 seats?
    Aug 26 2005
    Note item "3", that installs instead of the adjustable lumbar support, "4".
    Veteran Member Three Rings PhunkFX's Avatar
    Oct 11 2005
    2019 TTRS, 1989 VW Cabriolet, 1986 VW GLI, 2015 Cayenne Diesel
    Post Falls, ID
    what happened to the pics? Booo.
    -Ricky
    2019 Audi TTRS Prestige | Stage 3
    2015 Porsche Cayenne Diesel | Stage 2
    2015 VW Golf SEL TDI 6MT | Stage 2
    1986 VW Jetta GLI Wolfsburg Pirelli w/11k Orginal Miles
    1989 VW Cabriolet | 1.8T K04 w/nitrous
    Dec 31 2006
    boston, ma
    oh shit..i didnt know when you delete them from photobucket it gets deleted here...sorry bout that...im still very happy with how this turned out...been about 3 weeks, no problems whatsoever, no poking...and they hold much better than before
    Dec 31 2006
    boston, ma
    all fixed
    Oct 11 2005
    Post Falls, ID
    ah thank you
    -Ricky
