Results 1 to 10 of 10
Thread: DIY request
    Veteran Member Three Rings dak360rt's Avatar
    Apr 17 2008
    Sacramento, Ca
    DIY request
    Does anyone know of a good diy article for installing the AWE boost gauge into the center vents?
    Marty
    Light Silver Metallic - 2001.5 S4 - APR Stage 2+
    Piggy Pipes --- CC Mod --- Darintake --- Samco TBB
    AWE Boost Gauge --- 1 touch rear windows up
    JHM Weighted Shift Knob --- JHM Solid Short Throw Shifter --- Custom Straight Pipes
    Senior Member Two Rings Splinter's Avatar
    Jan 31 2008
    B.C., Canada
    Re: DIY request
    They have a pretty good install pdf on their website, go check it out.
    Apr 17 2008
    Sacramento, Ca
    Re: DIY request
    I've seen that one, and they actually printed it and sent it to me with the gauge, its pretty good I just wanted to know if there was another one too.
    The more info the better, its my first boost gauge install and I want to be more than well informed.
    Marty
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: DIY request
    Drive down to Los Angeles, and I'll help you do it .
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Active Member Four Rings RogueStatus's Avatar
    Nov 13 2007
    B5 S4 Avant
    Boston
    Re: DIY request
    the directions they send you are perfect. you shouldnt need anything else...
    ...if you do,not to be an asshole,but have someone else do it
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    Re: DIY request
    This DIY on the install is kinda funny!
    "How to be an idiot and install an AWE boost gauge. (long)"
    http://forums.audiworld.com/s4/msgs/1979928.phtml
    Brilliant Black 2001 S4 - 6MT <3
    Sep 21 2008
    new braunfels
    Re: DIY request
    the directions are in fact flawless... print it out in color off their website instead of the B&W - it's really pretty simple...
    but here's a DIY for you....
    1. Open hood
    2. remove trim piece to take off battery/ecu cover plastic thingy
    3. remove ECU cover
    4. remove far left vent
    5. remove center vent
    6. remove far right vent (just makes it easier, not necessary.
    7. pull ENTIRE vent housing straight out towards you, gently but firmly. (yes the ENTIRE thing comes out)
    8. Remove the lower kick panel below steering wheel
    9. throw away the wire that they sent you, it's too short to do it PROPERLY
    10. drill 13mm or 1/2 inch hole in the fart left (driver side) air duct
    11. feed vaccum line and your NEW wire through there, it will poke out just about where your right knee would be around... easy enough to find.
    12. run wire and vacuum hose over to other side. near the fuse panel
    13. run power and ground wire as described in the instructions
    14. run vaccum hose up through ECU cover
    15. cut off the two nipples on the grommets as described in instructions
    16. run vacuum line as instructed
    17. (optional - I'm fat so I had to do this...) - remove intake y pipe thingy for easier access to the vacuum line
    18. cut vacuum line that connects to the FPR right in the middle - if it's the original line it's covered in a webbed cloth that will basically fall apart.
    19. Put Provided T in the cut line, with bottom part of the "T" facing towards the fire wall
    20. connect vaccum line for gauge to the bottom part of the "T"
    21. you're done under the hood... don't close it all up yet until you verify.
    22. Back inside, pull the slack out of the wire and the vacuum hose so you have all the extra coming out of the vent hole, put the provided grommet over the wire and vaccum hose and use it to seal off the hole you drilled... this can be a MAJOR pain in the ass to do.. (Note the instructions tell you to pull all the slack OUT of the vent, i chose to do it the other way around because it was easier for me to cut the wire and hose appropriately from the vent rather than under the dash and under the hood...)
    23. Cut the vacuum line and wire so you have approximately 5-8" of EXTRA, note if you are putting in the MIDDLE vent you need about 8" maybe 10, so don't cut until you are ready to put it all back together - I chose to put in the LEFT most vent because it was easier to view - the middle vent put it just outside of my peripheral vision... in fact I started with it in the middle and ended up moving it
    24. Cut hole in the vent shut off as instructed, and location for zip tie as well... This is the most hacked up part of the entire install... Honestly if you NEVER shut off those middle vents I would say don't cut the hole... just my take on it. In retrospect I wish I hadn't.
    25. Feed vacuum lne and wire and all that stuf back through the vent housing either middle or left, your choice, figure out how much extra wire/vacuum you need and cut the rest off.
    26. I chose to SOLDER and shrink wrap, the install instructions tell you to use some clips, I started by doing this but they vibrate and cause a rattle, and frankly the clips suck., the downside is that if you solder you have to unsolder to remove... A better option would be to solder LONG wire to the gauge before you start and put clips down under the dash which would make it a bit easier to remove in the futre....
    27 - Once you have attached the vacuum line, set everything in the dash loosly and start the car, be sure the gauge lights up, and you read vacuum/boost...
    28. close it all back up and go check your boost... bone stock my AWE gauge showed a peak of about 10-10.5 when it was cool tapering down to about 8.5 - when it was hot the peak was below 10.
    Now seriously, if you can't use these isntructions and the included instructions (which are EXCELLENT by the way) then you probably shouldn't be doing it...
    Peace - Z
    Veteran Member Three Rings JD797's Avatar
    Apr 10 2008
    Re: DIY request
    http://forums.vwvortex.com/zerothread?id=2365126
    just skip the whole cutting the vent and painting the gauge parts, it's pretty straightforward. A tip: to get the tubing from under the steering wheel area to the engine bay, get some light going through the engine bay side hole and get one of those thin metal coat hangers and bend some of it straight and tape the end of the tubing to that, much easier to maneuver it through that way
    Apr 10 2008
    Re: DIY request
    and to tap the T-hose in, under the upper right engine bay cover is a cloth hose, the only one under that cover, use that. and do it in daylight, lol. GL
    Apr 17 2008
    Sacramento, Ca
    Re: DIY request
    Thanks for the reply the AWE instructions seemed very complete, and i have a clear idea about what needs to be done, its just my first time so im a little nervous but ive built engines and wired home theaters so i cant imagine that i cant do it. Just want to be equiped with all the knowledge that i can so that if a problem arises handling it wont be an issue.
    That audiworld diy is classic, if that guy can make it happen im sure ill be fine lol
    Thanks again for the help
    Marty
