View Poll Results: Which Big Break Kit should I get. Consider $ as well as performance
Voters
67. You may not vote on this poll
  • Porsche
    15 22.39%
  • Stoptech
    12 17.91%
  • Stasis
    25 37.31%
  • Brembo
    11 16.42%
  • RS4
    1 1.49%
  • Other. Please State
    3 4.48%
Page 1 of 3 123 LastLast
Results 1 to 40 of 85
    Veteran Member Three Rings Audi Juice's Avatar
    Feb 11 2005
    08 Titanium
    Huntington Beach
    My possible Big Brake Kit options
    Let me start by saying that I'm itching for a BBK badly! I have done hours of searching in the archives and I have seen a lot of conflicting opinions about many of the brake kits available for our cars.
    Here are my options:
    1. Porsche Cayenne calipers and ECS Rotors..NOTE---I have 2 sets of Cayenne calipers that I acquired from a friend who is a Porsche tech, so I would only need rotors. Still not sure if I want to run them or bump up to a higher grade kit. 6 piston
    2. Stoptech
    - Seem reasonably priced, but have heard some negative things overall. 4 piston
    3. Stasis/Alcon
    - Very sweet, but a tiny bit outside of price range. 4 piston
    4. Brembo-Also slightly over budget, but do-able. 4 piston
    5. RS4 Oem set up
    - Cons...Possible master cylinder incompatibility. Wheel offset problems as well. 8 piston
    What do you guys run, or what would you recommend for the B7 that isnt tracked, but very aggressively driven on the street? I average 16-17mpg.
    Finally, budget is $2500 out the door. Oh, and what color should the calipers be for my Ibis? Im thinking silver or black
    Nov 28 2007
    04 S4,Volvo P1800,03 Silverado
    Massachusetts
    Re: My possible Big Brake Kit options
    i would skip ECS. ive heard bad things about their rotors. If you have Cayanne calipers then i say find a porsche or other OEM easily accessible rotor that will work and find a machine shop to make you the correct bracket. With any of the pre made kits, they are all going to be awesome. I love stoptechs
    Feb 11 2005
    08 Titanium
    Huntington Beach
    ^^No brackets necessary. They bolt directly on B6/B7, which makes it even more tempting. Hmmm
    Oct 07 2008
    1995 Audi 90 Quattro
    Purple City
    Quote Originally Posted by Audi Juice View Post
    if they bolt directly up then i would go buy some rotors and put them on. you are halfway there why go out and spend money on another kit? and if for some reason you dont like it then sell it and get one of the other kits
    Veteran Member Four Rings 10MPG's Avatar
    Oct 25 2006
    Current:
    Bay Area CA
    scoop up 1sicknickel's old setup 6 pot brembo setup. u can still have some change for install
    Active Member Four Rings Goped220's Avatar
    Feb 16 2006
    2025 Audi S4, 2023 Audi A4 & 2024 Subaru Crosstrek
    NY/FL
    Stoptech all the way.
    Previous Cars: 2006 Audi A4, 2011 Audi S4, 2016 Audi S4, 2017 Audi A4, 2019 Audi S4, 2023 Audi S4, 2024 Audi S4, 2019 Benz E450, 2015 STI, 2013 370Z, 2013 Benz GLK, 2014 F-150, 2020 Lexus GS350, 2016 Subaru Crosstrek, 2024 Porsche Cayenne S
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    I vote Stasis Alcon but those things are expensive.
    Sep 02 2008
    Boston, MA, USA
    What size rotors do you use with the porsche calipers? standard B7, s4, ??
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    I had these options as well...
    I went with those...
    D2 Racing, 8pot, 330 mm .
    Very very satisfied with those...
    Nov 18 2007
    '02 CBR600F4i
    Orange County, CA
    I'd PM 1sicknickel. Could get his for under budget
    Listen. Download. Discover the latest Hip Hop and Urban Music for FREE http://www.justrhymes.com
    Junior Member Two Rings Kuang87's Avatar
    Apr 01 2008
    Chicago
    How aggressive are you driving on the streets? I went with Alcons and also did the rear upgrade and even though it was a bit expensive, I think it was well worth it because I can stop on a dime and they look awesome too.
    07' Silver A4 2.0T Quattro Tiptronic
    H&R Coilovers, H&R Rear Sway Bars, Carbonio CAI,
    Milltek Exhaust, APR 93 Chip, APR FSI Fuel Pump, Forge DV, 20% Tint,Hi-flow Milltek Cat,
    AWE FMIC, and Alcon BBK
    19" Champion Motorsport RF62
    19" HRE M40
    Registered Member Four Rings D.C. Designs's Avatar
    Feb 28 2008
    Many
    alexandria
    STASIS
    Jun 01 2005
    2003 A4 Avant 1.8TQM, 2010 S5
    St. Petersburg
    Have you considered these? Great kit for your budget including install.http://goapr.com/Audi/products/brake...tml#Stage%20II
    Feb 27 2008
    2017 Q7 Prestige 2010 Audi S5 Cab 2015 A6 Prestige 2007 S4 Avant
    New Jersey
    i love my stasis alcons
    Veteran Member Four Rings praudi's Avatar
    Jul 31 2007
    R8 power wheels , Tiguan and Ferrari F1 power wheels
    Tampa,Fl
    buy sicknickel's bbk
    DUH! an Audi
    los angeles, CA
    alcon FTW!
    casey why you need a bbk though? planning on tracking or racing?
    Veteran Member Four Rings swoardrider's Avatar
    Mar 23 2006
    '06 A4Q 2.0T
    Santa Cruz, Ca
    Quote Originally Posted by Quattro View Post
    alcon FTW!
    Exactly! I would never of spent $4k on my Alcons if I didn't track them once a month. Because you don't track your car at all, it doesn't make sense to even spend $2k on a BBK.
    Save the money for a BT kit or something.
    Since you already have the most expensive part of a BBK, (your Porsche calipers) then grab some rotors that fit and be done with it.
    Your goal seems to be to look better and stop better than stock. Your Porsche set up will accomplish this goal in the most economical way.
    '06 2.0T S-line Tip
    Stasis/Ohlins Motorsports, Stasis 14.5" BBk, Stasis rear BBK, H-sport rear sway, JHM 2+ tune, JHM 4:1 center diff, 18" Wed'sSports w/ 255/30 Toyo R888 (track), 19" Tenzo-R's w/ 255/35 (street), Stern upper arms, upgraded stereo, Huper tint, RS4 grill, JHM HFC, JHM downpipes,OEM S4 exhaust, track goodies
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Quote Originally Posted by swoardrider View Post
    AGREED!
    Senior Member Two Rings jba's Avatar
    Nov 21 2006
    2004 S4
    nyc, ny, us, earth
    Do the ECS kit. If it doesn't work for you, i can heartily recommend a stasis/alcon bbk.
    Active Member Two Rings Bauer's Avatar
    May 10 2005
    Lafayette, CA
    responded to you on the B5 thread....
    Alcon FTW.
    http://www.audizine.com/forum/showth...=233703&page=8
    Bauer
    07 A4 2.0T quattro - STaSIS Motor Sports Ohlins, STaSIS Alcon 370mm, GIAC, AWE exhaust, AMS SS, OEM rear DTM spoiler STaSIS high bias center diff
    03 RS6 She will be missed
    01 S8
    01 S4 KO4's, Awe fueling kit, Revlover cams, STaSIS Alcon 6 pot 355 rotors, STaSIS Motor Sports Ohlins, STaSIS LSD, STaSIS 4:1 DIff, STaSIS Custom built trans w/shorter gearing, custom exhaust, Recaro's, RS4 IC, RS4 bumper...ect, ect (Sold to Chip Herr...now she is being properly driven)
    Veteran Member Four Rings johnnybravo!'s Avatar
    Feb 20 2006
    323 EASTLOS, CALIFAS
    Ya what he said..but..if u desire a bbk the Stoptech 332mm/355mm 4-piston/black calipers is a proven setup...believe me u wont exceed the capabilty of the ST's..to spend more $$ on 6-piston is overkill..but sure looks pimp
    SRM K24 - Bosch 1000cc - Rods - 2.8 Cams- RR STG 4 clutch - AA-built 01E+4:1 - OS Giken LSD - ER IC's - JHM SS - SRM DPs - Vibrant 3" - Vast W/M - RS4 Y-Pipe - ASP MAF - APR Bi-Pipe - Ohlins MS Coilovers - AP Racing BBK - 034 Rear Sway
    C7 A7 Silver- Jackal STG 2+E40 Shane Horning ported s/c Merc HX- Pierburg 100-3 - Eibach Springs- OZ 20" UL wheels/Michelin PS4s- Eurocode Sway Bar- Borla- IE Intake
    Audi. Truth in Understeering.
    Feb 11 2005
    08 Titanium
    Huntington Beach
    Quote Originally Posted by 10mpgS4 View Post
    Ive already talked to him, but his post was just a feeler. He isnt ready to sell yet.
    Quote Originally Posted by yettavr6 View Post
    Most kits have 352x32mm rotors for these calipers.
    alcon FTW!
    I can push these brakes to the limit now just driving on the street. Just thought it would be safer and more fun, plus look cool. The most important reason is to reduce unsprung weight though. Even though the bbk is bigger you will be shedding pounds off each corner, and that will translate into noticable differences in acceleration/handling.
    Jun 21 2008
    NYC | ATX
    So you guys are telling me that my 911 Calipers would bolt directly onto my B7 without brackets? If so I"m doing this tomorrow! Do I need bigger rotors or keep the stock ones?
    Feb 11 2005
    08 Titanium
    Huntington Beach
    Quote Originally Posted by NYSpeedRacer View Post
    No, just the Cayenne calipers bolt directly up. The 911 calipers(993 ones at least) need a custom bracket in order to mount. I also have a set of yellow 996 calipers that were part of the PCCB carbon ceramic kit. I dont want to have to worry about finding brackets though. The Cayenne way seems easier for me.
    Yes, you need bigger rotors. Looks like the only two options are the ECS rotors, or getting a set of oem porsche rotors redrilled. Also, one of the Porsche techs I know said they pulled this conversion off with RS4 rotors. Im going to look into that a bit further
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    just save your money and go with the porsche calipers. can't go wrong. they're basically brembos
    Nov 25 2007
    Whats the part # for the Cayenne brake calipers? how much do they usually run?
    I was thinking of doing S4 upgrade on my B7 A4 S-line but if Porsche caliper is a direct bolt on and accepts bigger rotor I might go that route instead. Anyone know the price difference?
    Registered Member Three Rings Jason@PenskeAudi's Avatar
    Dec 19 2006
    West Covina
    STaSIS.
    Penske Audi West Covina -- Now Open!!!
    Audi A3 2.0T (Oettinger/Stasis/Falken/Volk Racing/GIAC/VF Engineering/EuroSport)
    Senior Member Two Rings mtxsho93's Avatar
    Sep 20 2008
    93 SHO, 02 A6 2.7T 6MT
    South Jersey
    Contact Todd Cook at http://www.tceperformanceproducts.com
    Ian
    Veteran Member Four Rings JBM's Avatar
    NorFOLK, VA
    Funny nobody has said Rotora-355MM 6 Piston come in special colors such as Gold, DK Blue, Chrome, etc etc.
    I can meet that budget of yours btw.
    Nov 25 2007
    Quote Originally Posted by mtxsho93 View Post
    Ian
    I had Wilwoods on my VW mk3 Golf 2.0t and they were good but after about 2000 miles they started to make noise.. it was very annoying and many other people with that setup said the same thing. Also they need to be rebuilt frequently.
    For Race purpose, they cannot be beat as pads are easy to swap out when you get to the track!
    Sep 20 2008
    South Jersey
    Quote Originally Posted by Maverik869 View Post
    Which calipers were you using? I had the Billet Superlites which flexed and creaked and were generally a very poor design. I've been running the forged Superlites for a few years now without a single issue (knock on wood).
    Replacement costs, pad choices and availability can't be beat with the wilwoods. IMO, their better calipers are just as good as brembo/AP/StopTech for a fraction of the cost.
    Ian
    Nov 25 2007
    http://www.momentummotorparts.com/store/braking.asp
    Senior Member Three Rings tdavit's Avatar
    Aug 27 2005
    CT, FL
    im pretty sure that the only way that the calipers mount up without a bracket is if you are using stock size rotors. because the bracket is to move the caliper further from the center point (axle center) and correct the offset if needed.
    Sep 20 2008
    South Jersey
    Oh ok, those are the Dynalite's. I'm not a big fan of those for anything that's driven on the street. From Wilwood's site: "The time proven Dynalite caliper design is stronger and lighter than ever - ideal for Late Models, Modifieds, Sprints, Road Racers and Dragsters."
    The Superlite series and better are much more suitable for heavier street cars.
    Ian
    May 10 2005
    Lafayette, CA
    Ian
    Wilwood is nowhere near the quality of Brembo or AP.
    How I would rank
    Alcon
    Brembo (depending on level - their race stuff is great but like 8k)
    AP
    Movit
    StopTech
    Wilwood
    Brembo and Alcon are very close....it just depends on which Brembo you are going with as there are many different levels. The OEM stuff is just OK, IMO. Alcon, Brembo and AP race stuff is very good but super spendy.
    Bauer
    01 S8
    NorFOLK, VA
    What I'm getting once the market bounces back. 355MM, 2 Piece H2 Pad so ST60 config selection. 6 pistons and I'm getting it for $2525 ;) Oh you can get it in Blue,Red,Green,Chrome,Yellow,Gold,Gunmental..and black.
    Oct 16 2006
    Long Beach
    2. Stoptech
    3. Stasis/Alcon
    5. RS4 Oem set up
    [SIZE="5"]What do you guys run, or what would you recommend for the B7 that isnt tracked, but very aggressively driven on the street? I average 16-17mpg.
    Have you taken a look at this particular Brembo option?
    ***May not be an exact example for your vehicle.
    320x32mm 4-piston Brembo Gran Turismo system
    Retails for $1995.
    Red - Black -or- Silver ... Cross-Drilled -or- Slotted
    Comes complete with Brembo 4-piston calipers, 1pc. oversized cross drilled OR slotted rotors, street performance /or/ race pads, stainless steel braided lines, and all necessary mounting hardware.
    Engineer with attention to proper piston area and disc diameters to maintain optimum brake bias and compatibility with factory master cylinder, ABS and traction control systems.
    The intention was to provide a cost effective solution, engineered and manufactured by Brembo, as an alternative to systems of lesser quality that may or may not be ideally suited for your application.
    With a budget of $2500, you are not very far off of a Grand Turismo brake kit with 2pc. fully floating discs.
    Retails $3195
    There are plenty of Authorized Brembo dealers who sponsor/advertise on this site than can help you out with sales and technical support as well as pricing.
    Mar 11 2008
    07' A4 S-Line ti avant
    Toronto Canada
    [IMG][/IMG]
    Go this way. You won't be disappointed.
    Sep 20 2008
    South Jersey
    Quote Originally Posted by Bauer View Post
    How I would rank
    Alcon
    AP
    Movit
    StopTech
    Wilwood
    I was referring more to function vs. cost. That said, Wilwoods or Brembos will still stop the car and can be spec'ed out very similarly. The other brands are high quality but I've never had an issue with my Wilwood forged superlites.
    Ian
    Veteran Member Three Rings vwong's Avatar
    Apr 03 2006
    '10 S4, '09 335i, '98 Prelude
    Quote Originally Posted by JBM View Post
    Don't waste your money on those. Their quality is nowhere near the quality of the Brembo, Alcon, AP, etc. They are not engineered properly, and not test-proven. There is a reason for the low MSRP.
    2010 Audi S4 6MT
    2009 BMW 335i Coupe 6MT
    YouTube Channel
