Results 1 to 40 of 53
Thread: So I was Bored
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    So I was Bored
    So I was bored and didn't want to sit inside when the sun was still out for the last few times. I looked for something to do and saw my stock wheels just sitting there. Well this is what they were, and what they are now:
    When I first got the car:
    After Tonight:
    The usual things!!
    Resistor Install
    Nov 12 2007
    Grand Junction, CO
    Re: So I was Bored
    How did you do that?
    Registered Member Four Rings D.C. Designs's Avatar
    Feb 28 2008
    Many
    alexandria
    Re: So I was Bored
    ^ x2
    Feb 16 2008
    Oakdale, MN
    Re: So I was Bored
    Quote Originally Posted by AudiWxGuy View Post
    Cleaned the wheels (soap/water/wheel cleaner), Sanded them down with 320 paper and water (by sanded i went through and tried to get it a little rough for the primer to catch on). cleaned and wiped dry. 3 layers of primer, 5ish coats of Duplicolor Wheel Paint (found at your local hardware store) Graphite was the color i used, 2 Clear coats just to be sure.
    For the center caps, I did the same thing but took out the rings and the outer ring out and plasti-dipped those and when all was done just snapped them back together.
    The usual things!!
    Resistor Install
    Registered Member Two Rings dubfreak75's Avatar
    Aug 14 2008
    '06 A4 B7, '04 Tahoe
    Spokane Washington
    Re: So I was Bored
    Can you post a full pic of the car with them installed?
    Feb 16 2008
    Oakdale, MN
    Re: So I was Bored
    Quote Originally Posted by dubfreak75 View Post
    I'll see what I can do tomorrow for you. They weren't fully dry so i was careful with the one i put on and wanted a quick pic to see how they looked on. Tomorrow they should be fully dry!!
    The usual things!!
    Resistor Install
    Veteran Member Three Rings jimmya4's Avatar
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    Re: So I was Bored
    AHH i want to do this so badd. worried about depreciation of the value and everything. too cheap to buy new rims though. did you just use tape to prevent the primer from hitting the tires? cant wait to see pictures of the whole car.
    2005.5 Quartz grey A4 Quattro 6mt/ REVO stage II
    Feb 16 2008
    Oakdale, MN
    Re: So I was Bored
    Quote Originally Posted by jimmya4 View Post
    Ha, I hear you. I wasn't sure how it was going to turn out but I lreally like how they turned out. Once you sand there is no going back. There was a write up on Audiforums a while back and the guy used notecards standing verticle and little bits of tape to hold them all together. He, as did I, put them in the little lip opening between the tire and wheel. It worked out extreamly well. Nothing on my tire. I would also put something down under them as i didn't so i have 4 circles on my garage floor. Oh well.
    The usual things!!
    Resistor Install
    Veteran Member Three Rings Clown4's Avatar
    Aug 29 2008
    '08 Quartz Gray S-Line B7 2.0T
    Rainbows and Unicorns
    Re: So I was Bored
    HAWWT.
    looks so much better than the stock color~
    looks nice with and without the wheelcap!
    2008 B7 A4 Quartz Gray 2.0T Quattro 6-spd MT.
    Full S-Line | Special Edition | Technology Package | HomeLink
    ____The Last of B7._
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Re: So I was Bored
    Pretty good DIY, just use those as the winter wheels anyways. Can't wait to see how the finish holds up and some full car pics
    Sep 02 2008
    Boston, MA, USA
    Re: So I was Bored
    Damn, those look really good. I want a set now! I might have to go get a used set off ebay and do this for a set of winter wheels. I have the Ti wheels with summer tires so i'm gonna need to do something soon.
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    Re: So I was Bored
    Nice...I hope they dont start chipping here and there...
    I will paint mines the ritght way on Monday...However it will cost a biiiiiiit more
    Veteran Member Three Rings G18's Avatar
    Feb 12 2004
    Re: So I was Bored
    lookin good....love the contrasting color on the center cap
    Registered Member Three Rings turbo4s's Avatar
    Mar 27 2006
    AUDI B7 S4 / MKV GLI
    Re: So I was Bored
    looks great man. you did a great job. thumbs up
    _______
    Artic White B7 S4 Fully Loaded
    Mods= Titanuim RS4 Grill
    Salsa Red MKV GLI Fully Loaded
    Mods= Revo Stage III KO4, Carbonio, AWE Full Exhaust, AWE FMIC, H&R spring & Sways, AWE Vent Guage,
    ECS Blacked Out Coners, ECS Snub Mount, KMD Fuel Pump, KMD Cam Follower
    Feb 16 2008
    Oakdale, MN
    Re: So I was Bored
    Yeah they will be the winter wheels. We shall see how they hold up. The tires need a shine up and the car needs a wash. But as promised.....
    The usual things!!
    Resistor Install
    Aug 14 2008
    Spokane Washington
    Re: So I was Bored
    looks pretty tough, nice job!
    Jun 02 2008
    Greece
    Re: So I was Bored
    mmmmmmmm....very nice without the center caps on...
    Veteran Member Three Rings Josh_877's Avatar
    Aug 24 2007
    Chicago Suburbs
    Re: So I was Bored
    Ive been thinkin about doin this for a while but i dont have the balls to do it myself. i like how the stock dual 5 spoke wheels look on a lowered car and when they are dirty (that grey color) they look sick.
    Veteran Member Four Rings whitevdub's Avatar
    May 10 2007
    Long island
    Re: So I was Bored
    looks good...i like the stock rims on your car better than i do your other aftermarket rims. this color just blends in with your car, its great. nice job
    Veteran Member Four Rings Bllzll's Avatar
    Jun 09 2008
    b8
    Re: So I was Bored
    damn i absolutly love it. i think gunmetal looks great on light silver cars... i would do this in a second but i dont want to make my car so difficult to sell when i get rid of it one day.. so id rather just save for other rims..
    but damnnn i love it! some spacers would look spot on
    Feb 16 2008
    Oakdale, MN
    Re: So I was Bored
    Quote Originally Posted by Bllzll View Post
    Thanks. Glad everyone likes them! I was thinking about spacers. If I could get some used I would do it. But I don't think I'll buy them new.
    I too was worried about resale but figured I would try and sell to another fellow audi lover that would like everything i've done to it, instead of parting it out.
    The usual things!!
    Resistor Install
    May 10 2007
    Long island
    Re: So I was Bored
    so you said the audi rings in the center caps just pop right out?
    Veteran Member Three Rings Elohite's Avatar
    Jan 14 2008
    San Antonio, TX
    Re: So I was Bored
    Digging the centercapless look.
    Garage Inc | APR | Britalman | 034| Stasis | Volk |Rotora | Deval | EuroGear | DTH | Thule | Forge | BSH | AWE | Evoms | H&R | Pioneer | JL Audio | TMA | ZiZa | KLight
    Veteran Member Four Rings UnkleGatsby's Avatar
    Jan 09 2008
    S8
    Ketchum Idaho
    Re: So I was Bored
    Sick! looks aggressive. If you leave the center cap off you should get some colored lug nutz. I suggest red or somethin. I did this to my car also.
    Senior Member Two Rings jba's Avatar
    Nov 21 2006
    2004 S4
    nyc, ny, us, earth
    Re: So I was Bored
    Looks awesome, nice job!
    Veteran Member Four Rings EMAXX's Avatar
    Jul 12 2008
    Re: So I was Bored
    Those look really good. I've been thinking about painting mine, but like many people have said, I just don't have the balls to do it... Do they look shiny or is it more of a flat finish when you look at then close?
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Re: So I was Bored
    They turned out very well, I painted my stocker on my B5 gunmetal also and I loved them.
    May 24 2007
    Southern California
    Re: So I was Bored
    nice. you should have taped the tire off so the paint didnt get all over the tires. you can definitely tell.
    you can scrub off the paint on the tires though with a little elbow grease
    Kyle
    2.0L Revo GTRS Eliminator
    Feb 16 2008
    Oakdale, MN
    Re: So I was Bored
    Quote Originally Posted by whitevdub View Post
    Yes, Just flip them over and you will see 4 tabs that hold it in place. Kind of hard to get at i just used a screw driver and it worked fine.
    Quote Originally Posted by EMAXX View Post
    Far away they look flat but as you get really close to them they are a little shiny from the clearcoat
    Quote Originally Posted by A4natomical View Post
    It is just the clear because i had run out of some and then found some more and had already untaped everything and said screw it. But in person they don't look bad and it rained and took most of it off!
    The usual things!!
    Resistor Install
    Veteran Member Three Rings Nico's Avatar
    Mar 02 2007
    Sydney, Australia
    Re: So I was Bored
    Looks incredible - totally transforms the car. Good work.
    Veteran Member Four Rings AvantNoir's Avatar
    May 22 2007
    Santa Monica CA
    Re: So I was Bored
    JOBWELLDONE!
    I'm currently working on the same project. Mostly to fix the curb rash.
    Trying to decide on color. Tried the graphite. Like it, but, I've already stripped it off to reshoot black. Wife wants me to put them back to silver.
    I might wind up going with graphite now that I've seen it on your car.
    Like the contrast of the rings on the center caps. Excellent idea.
    Just call me Mr. Page 2
    2005 USP A4 Avant 1.8T Follow me on instagram @m27autowerks
    Veteran Member Four Rings fusionx's Avatar
    May 17 2008
    07 A3 2.0T
    Socal / Boston
    Re: So I was Bored
    looks really good dude very good job. Any way you can post some pictures with the center caps on? I think it would look 10x better with them on
    07 A3 2.0T S-line - REVO stage 2 - GIAC DSG Flash - AWE downpipe - Custom staggered quad-tip exhaust - H & R springs - H & R sway bar - Neuspeed CAI - fog housing LEDs - VMR boost gauge - JL 12'' Sub w/ Precision Power Amp
    Instagram: @superseany
    CanyonRacerMotorsports
    Project Matte Black: COMPLETE
    Veteran Member Four Rings Vorsprung's Avatar
    Feb 26 2008
    Raptor, FD RX7
    Long_Island/NY
    Re: So I was Bored
    Looks really good. I kinda like em without the centercap on.
    -Ian
    Senior Member Two Rings gervi's Avatar
    Nov 20 2007
    2006 Audi A4 2.0T
    Winnipeg, Canada
    Re: So I was Bored
    That looks really badass, definitely very original. I think Audi should of sold the A4 with wheels in that color. I always liked gunmetal wheels on our Quartz Gray cars and it helps to hide the ridiculous brake dust that builds up on our wheels.
    Really good job man, with spacers and a drop they look like race spec wheels.
    Feb 16 2008
    Oakdale, MN
    Re: So I was Bored
    Quote Originally Posted by fusionx View Post
    I'll see what I can do for you.
    Quote Originally Posted by gervi View Post
    I hate the brake dust its aweful. I agree that they should have come this way from the factory! I wasn't sure how they would look on the grey car but I think i now want my summer wheels similiar to these!
    The usual things!!
    Resistor Install
    Veteran Member Three Rings jahciple's Avatar
    Mar 10 2008
    08b78ea42t6mtnq
    Long Beach, CA
    Re: So I was Bored
    x2
    Driver: Dustin
    Projekt: Audisciple
    Gamertag: JAHciple
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Re: So I was Bored
    Quote Originally Posted by jahciple View Post
    x2
    He did post full car pics up above
    Veteran Member Four Rings Erocko's Avatar
    Feb 16 2008
    Honolulu, HI
    Re: So I was Bored
    very cool. I think I like them without the center caps as well. Great job. That really sets off those wheels, then, in turn, your ride. Sick
    Current: 2019 B9 A4 Quattro
    Former: 2016 8V A3 Quattro, 2011 Mk6 GTI DSG 4-door, 2005.5 B7 A4 2.0T FWD CVT
    Registered User Two Rings john@fifteen52's Avatar
    May 02 2008
    B7 A4, Mk3.5 Cabrio, Mk5 Jetta
    White Plains, MD
    Re: So I was Bored
    Very nice color choice! I don't think this will hurt the resale value later (at least, not as much as black wheels would) as long as the finish holds up, but it won't cost much to give them a good recoat after a while.
    Veteran Member Four Rings SilverB7FL's Avatar
    Feb 19 2007
    Built Twin Turbo 350Z
    S. Orlando
    Re: So I was Bored
    they look really good! I love gunmetal on silver and grey colored cars. You'll have to let us know how they hold up over time. I hope they don't get rock chips.
    Girls love Audi too.
