Results 1 to 22 of 22
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    TBB wont stay on under boost
    Ive put the car under boost 2 times since i installed the boot and each time the car spits air all over. The boot always comes off the throttle body. Considering going back to stock? I just dont want to deal with this. I really want a car i can drive like its ment to be.
    First time it happened i chalked it up to being user error and i didnt tighten it enough. So i made it gorilla tight. The second time im thinking its more than my error.
    Ideas?
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Re: TBB wont stay on under boost
    what clamps?
    Established Member Two Rings caall99's Avatar
    Oct 02 2007
    Boston Area
    you might not be pushing it back far enough onto the throttle body. i noticed that my new (and improved) oem TBB had a ridge on the inner diameter that kind of snapped around the throttle body lip. even without the clamp on i could tell that it was somewhat locked in place. mine has not popped off yet, atleast not with 17.5 psi. :)
    2000 Audi S4 Black/Black
    XS-Power Turbo-Back Exhaust * APR Stage 2+ V5 93 Octane * 710Ns * AWE DTS * Short Shifter * Stern Power Ring, Rear diff. mounts, snub mount
    Aug 18 2007
    Ohio
    I pushed the boot as far on the throttle body as it is possible. I even put the clamp on gorilla tight, which, i admit, the clamp isnt isnt top of the line or any of that business but should do the job adequately. I would like to drive this car as its meant to be and not be scared to hit the accelerator.
    2002 TT Silver 225
    Active Member Four Rings
    Dec 11 2006
    Boston
    constant tq clamps. do it
    Veteran Member Four Rings JMTx86's Avatar
    Oct 03 2005
    Spray hairspray on the out side of the TB then put the hose on.
    00 b5 s4 Single turbo
    1969 Chevy Nova 396 (Full resto, completed in 2016)
    1969 Chevy Camaro 454 (built 454/th400, body is a work in progress)
    11 Chevy z71 5.3 shop truck (Vortech V2 build in progress)
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Never had that problem. My Samco tbb fit really tight and I screwed my clamps down tight.I am spiking at 20 with no problems.
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    You sure you bought the correct TBB?
    --Adam
    Have questions? E-mail me.
    Veteran Member Three Rings JD797's Avatar
    Apr 10 2008
    make sure the clamp holding the boot onto the TB is in a good spot, meaning try having it be the same distance from the edge of the clamp to the edge of the TBB all around, you dont want it to be angled with say the top edge being a lot closer than the bottom edge. and what TBB are you using?
    Feb 17 2004
    Sterling, VA
    Also be sure to clean the throttle body lip really well (use a grease removing cleaner). The oily residue will definitely let it pop off.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Veteran Member Four Rings Videlov's Avatar
    Jul 01 2008
    Chicago, IL, Bulgaria
    I have the same TBB from 034, put it in last week. So far it's been fine, no problems (knocks on wood). I don't know what to tell you, make sure everything kind of snaps in place and all the screws are tightened. Also for the big clamp, I know it's kind of hard to adjust it in place cause you don't have much room to work around, but also double check that its straight, meaning covers all side at the same spot.
    "Some Redbull, some water, some nice fresh house music!"
    2000 Audi S4 (Sold)
    2010 Audi S4 (Next)
    Veteran Member Four Rings Tifosi's Avatar
    Apr 27 2004
    Pacific NW
    Interesting. This is the second complaint in as many days I have read regarding 034 TBBs popping off under boost. The owner of the first thread cited the lack of grooves on the TBB may be the reason, is it true that the 034 TBB does not have the grooves where the clamps sits ? As far as TBB goes, IMO, Achtunning has the best option out there (http://shop.achtuning.com/index.asp?...ROD&ProdID=543).
    Another alternative to TBBs is the APR BiPipes (http://shop.achtuning.com/index.asp?...ROD&ProdID=518), which are on-sale right now. There are plenty of thread on this topic already and like any other product out there, there are arguements from both side. Do a little research and draw your own conclusion on if that is something you are interested. in
    Senior Member Three Rings NorCalS4's Avatar
    Mar 16 2009
    Chico, Ca
    know this thread is kinda old, but bumping it just to tell others that my 034 TBB also popped off. A couple times. every time I put it on, i paid close attention to making sure the clamps were straight (a mm or two from the edge all the way around). I also did it super tight. I put the stock one back on. The stock TBB has the ridge on the inside of the hole that connect to the TB, which I keeps it on, unlike the 034 (or SAMCO).
    Gonna rock the stock one for now. If/when it goes, Ill look into the achtuning one, since it may have the ridge on the inside to keep it on the TB. (can anyone confirm that the achtuning one has the ridge onteh inside?)
    '01.5 Silver S4 6spd
    ~V1 hardwired
    ~AWE Boost gauge in DIY vent pod
    ~ASP DTS
    ~F90BT w/ JL 250/1 & W3 12"
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    I run stock TBB with good spring clams and the boot holds well under stg 3 power. They key is clean clamping area well and use good clams,
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Veteran Member Three Rings mrbogangles's Avatar
    Apr 06 2008
    ;p
    phoenix az, bay area
    you should use a t bolt clamp
    Veteran Member Three Rings NogaroWonda00's Avatar
    Jun 13 2008
    Rocky Mountains
    mine popped off a couple times, turns out it was just me being and idiot and not putting it on all the way, dont be scared! jam that bitch on and take a dv off stick your finger underneath it, see if that edge is actually on the throttle body, mine kept getting rolled under, and poppin off at high boost, but its been well over a year since it happened GL
    '00 Nogaro Blue S4
    Mar 16 2009
    Chico, Ca
    Quote Originally Posted by S4_NE View Post
    Yeah, I cleaned everything well and had good clamps. I have much turbo experience and know how to secure couplings on cars that boost 30lbs.
    Im just gonna rock the stock one. If its good for your stg 3 power, its fine for my stg 1.
    ~V1 hardwired
    ~ASP DTS
    Veteran Member Three Rings laxman851's Avatar
    Jan 09 2008
    2001 S4
    NC
    It also could be from intake manifold spacers couldn't it? If you have thicker spacers it may cause the bi-pipes to pull the tbb off of the tb under boost.
    Aug 18 2007
    Ohio
    I still have the stock one on their because I dont feel like messing with it. It works fine for now.
    2002 TT Silver 225
    Mar 16 2009
    Chico, Ca
    Quote Originally Posted by OldYella View Post
    Should change your sig then...lol..jk
    But yeah, thats what im doing, rocking the stock one. I think if you have the T revised TBB and the new better clamps, the stock one is fine. theres people wit stg 3 running the revised one with good clamps.
    If I have a problem Ill be gettin achtuning or SAMCO, as they both have the retaining ridge to lock it onto the TB. I really like the achtuning one, so thats what ill prob go with that one.
    ~V1 hardwired
    ~ASP DTS
    Aug 18 2007
    Ohio
    Quote Originally Posted by NorCalS4 View Post
    The Samco I have seen doesnt have the ridge either.
    2002 TT Silver 225
    Mar 16 2009
    Chico, Ca
    I have another thread going and people are saying that the Samco has a ridge on the inside of the opening to the TB?
    ~V1 hardwired
    ~ASP DTS
