Results 1 to 20 of 20
    Veteran Member Four Rings Rapter's Avatar
    May 01 2004
    2009 honda CRV
    Jersey
    Yes another brake pad replacement/DIY post?
    Ok boys and girls I'm in need of new front brake pads and hopefully not both pads and rotors. I have that low brake light on thinking of doing it myself. I've done some searching on here, AW and even been linked over to Vortex. While I am a complete newb to brakes. I've done some minor bolt in mods(Coilover install, clear corner mod, Audio install). If need be I will take it to my mechanic, but I rather fail first trying to learn how to do it myself rather than have him do it right off the bat.
    Questions...
    1. First which DIY are you guys using (preferably an S4 is used in the DIY)?
    2. Do after market pads differ much from OEM as far as physical and install procedure? I'm looking into Hawk HPS and read something about having to cut some sensor off or something like that?
    3. How can you tell when you need new rotors? I also briefly read that some people were having problems because they didn't replace both pads and rotors due to high mileage(which I have 105k).
    4. Is bleeding the brakes necessary? If so I'm assuming that will be in the DIY?
    I'm sure I'll have more questions, bu that should be good for now.
    TIA
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: Yes another brake pad replacement/DIY post?
    Quote Originally Posted by Rapter View Post
    http://www.audiworld.com/tech/wheel39.shtml
    The shape and install are exactly the same. The only difference would be if the aftermarket pad you buy (which are far superior to OEM pads in performance aspect) don't come with brake wear sensors, you will have to short the sensor, or you will always have the "low brake pad" warning in the LCD screen like you have now. I think it explains it in the DIY above.
    A good rule of thumb is replace rotors every other pad replacement. If you don't know when the rotors have been changed, change them. Especially if they are OEM, as they are known to warp in higher mileage.
    You should bleed your brakes at a minimum of once every three years.. minimum.
    I don't think it's covered in the DIY, but here is another generic one that should give you the idea. You will need another person to help you (step on the brake pedal) bleed.
    http://www.popularmechanics.com/auto...o/4213448.html
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    May 01 2004
    2009 honda CRV
    Jersey
    Quote Originally Posted by Rated S View Post
    Does anyone know of any aftermarket pads with sensors like OEM? If so who sells them and are they low dust no squeal? This is purely for street my car will never see a track.
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    I know PBR and EBC have sensors.
    May 01 2004
    2009 honda CRV
    Jersey
    Ok so I can go with...
    PureMS:
    PBR Ultimate Ceramic Front Brake Pads
    SKU: D420RU
    Our Price: $103.95
    Or...
    TireRack:
    Hawk HPS Street brake pads
    Price: $147.00 (axle set)
    Estimated Availability: In Stock
    Manufacturer Part #: HB363F.689A
    Both of them have the sensors so are the Hawks worth the extra $4X.00?
    Jun 24 2008
    http://awe-tuning.com/pages/shared/p...&IL=MintexPads
    Those do too.
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    I have PBR Ultimate Ceramics.
    The break in squeel is crazy loud, but they are awesome pads.
    I also broke them in..literally at an autox event, so that didn't help the squeel.
    Jan 11 2007
    Salt Lake City, Utah
    When I see PBR I think Pabst Blue Ribbon ha
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    May 01 2004
    2009 honda CRV
    Jersey
    I'm about to order the hawk pads, will I need to buy brake fluid? If so which one should I go with? She will never see a track so I won't need anything extreme.
    TIA
    Veteran Member Three Rings Bimmer2Audi's Avatar
    Sep 10 2007
    2001.5 Audi S4
    G.R. Michigan
    DO NOT get the Hawk HPS pads!!! It was the worst decision of my life. They've been squeaking constantly for 3k miles and leave dust everywhere. I'll be changing them asap.
    B5 S4 6MT Stage 2+
    JFONZ GWERKS-AWE Twin 1-SSAC-JHM FMIC-H&R Springs-BBS CH's 18x8.5
    May 01 2004
    2009 honda CRV
    Jersey
    When putting on the new pads do you need to put that little leather like cover back on the back of the pad? The cover is between the back of the inner pad (back side of rotor) and the brake caliper piston and has a cut out for the two bumps that back pads have. Please help at that point right now and not sure what to do.
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Uh, no car I've ever changed pads on has had this leather pad. I would say leave it on, unless it doesn't let the pad fit. Might help with squeeling.
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    PBR Ultimate Ceramics i use them, good pad but they do squeel some,
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Established Member Two Rings rick_chicago's Avatar
    Apr 29 2008
    B5 S4 (Stg 2), Honda CR-V
    Chicago (NW)
    Did you get the Hawk HPS pads or something else?
    I do not use any type of leather backing with either my HPS or HP+ pads. Just swap 'em back and forth and do some bedding.
    Stg 2 B5 S4
    May 01 2004
    2009 honda CRV
    Jersey
    Yep I went with the Hawk HPS with sensors from tirerack. I was set on those, but then bimmer2's post made me have second thoughts. Then I talked to a couple people and every one said they're pretty much the best all round pad. Just got done bedding them and so far so good. Turbo swap here I come.
    Here is the leather/sand paper looking patch I was talking about.
    Aug 06 2008
    Canadia
    you should also lubricate the 3 sliders to ensure even pad wear between the outside and inside pads.
    you should also put some lube on the sides of the pads where they sit in the caliper bracket or they will rust, not move properly and then start making a ridge in the bracket itself. contributing to poor brake modulation and uneven pad wear.
    if your going to re-use the rotors, scuff them with some 100 grit sandpaper to remove the glaze otherwise the pads won't break in properly and most likely squeal like a SOB.
    I flush my brake fluid every year, 2 or 3 years your fluid will be black and full of water that corrodes the internals of your brake system causes seals to leak and ultimately brake failure.
    change your fluid BEFORE it turns black.
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by Bimmer2Audi View Post
    I'll second the squealing and the dust. But they are still the best pads I've had. I can deal with both of those issues.
    08 S4- Stock SOLD
    Apr 29 2008
    Chicago (NW)
    Everyone has a favorite pad. I think the HPS are great, but also don't doubt there are others that are also great. I have zero squeal, low dust and great initial bite with them.
    I still have my HP+ pads on from the last track event this year, and my wheels are practically black from the dust, I squeal at stoplights - my laziness provides quite the illustrative example.
    I'll just swap 'em back when I switch to the winter wheels in a few weeks.
    It'll take at least a liter to 1.5 liters for a full flush. I'm trying the Brembo SportEVO 500 from Tire Rack, but there are others that folks prefer most. My understanding is the Castrol SRF fluid is the best there is, but it's $80 a liter.
    I use a power bleeder - my wife won't come out to the garage at 10pm to pump the pedal. I use a jack, jack stand, AND I slide the wheel underneath so daddy always comes back in one piece.
    FYI - the brake fluid eats paint like gummi bears.
    Stg 2 B5 S4
    Senior Member Three Rings Boosted-S4's Avatar
    Aug 03 2008
    Silver S4
    The best pads u can get and even come with sensors is the PBR ULT Ceramics!! I have them on my car front and back and they are awesome..i have had them for 5k and no squeel whatsoever...They stop like crazy and makes the brake pedal have a nice braking feel!!!
    They are totally shimmed for noise reduction!! Since u are changing the pads and still have oem rotors u should defenetly change them!!! Believe me..u will notice a great diference!!!For better offcourse!!!
    Not putting down hawks but i have had a couple of buddies with s4s that had bad experiences with them!!!It even damaged their expensive brembo rotors!!!
    Aug 06 2008
    Canadia
    I really like PBR pads, I haven't had much luck in the noise department (especially on my girlfriends escort) but they work really really well.
