Results 1 to 7 of 7
Thread: inspection help
    Mar 23 2008
    Queens Ny
    inspection help
    i have 2001 audi a4 1.8t with a apr chip. my car is due for an inspection but when i hook up a scanner up to it the computers still show a not ready. i have driven well over 300+miles after i have switch back to non chip mode am i missing something or will the apr chip make me not pass inspection..
    Dec 05 2007
    Re: inspection help
    Why would it show not ready? On what component are you getting this for? If you clear any fault codes, then you have to wait to have them show readiness again (couple days for me). I have my ECU flashed, HFC, and Exhuast done and show readiness via VAG com for engine components. And in NY, you are permitted to have one of the readiness off and still pass.
    Mar 23 2008
    Queens Ny
    Re: inspection help
    i had no cel. when it was time to get an inspection i switched over to stock mode and hooked up a scanner and saw my computers wasnt ready so drove about 400 miles and still they are not ready yet ? do i need to lock it on stock program ?
    Dec 05 2007
    Re: inspection help
    It is not about mileage, but about time. You have to wait a couple of days. You could have the car sit in the garage for a couple of days and drive no miles and the Vag Com will show readiness.
    And going on speculation, I am thinking that maybe the ECU restetted via APR chip design after you switched the modes. And that is why you don't have readiness. But this is just a guess. FWIW, I live in NY and my inspection is over by the end of this month and need to renew it. I have readiness for all components and my flashed k03s stays in that mode.
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    Re: inspection help
    Which readiness tests are you failing?
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Mar 23 2008
    Queens Ny
    Re: inspection help
    i forgot but 3 were not ready. whats the easiest way to make them clear just waiting instead of driving it ? i always you have to drive the car to make them ready. so the apr chip wont make me fail inspection correct ? meaning it wont matter if i was in chip mode or not ?
    Oct 11 2008
    us
    Re: inspection help
    Utilizing an MSD Launch Control device enables a driver to find the best launch rpm for his/her Mustang, and allows the driver to be consistent by leaving at the same rpm every time. Street cars benefit from a two-step because most of the time the car doesn't have a dedicated drag-race suspension
    ________________________
    seitensprung test
    iced tea
