Results 1 to 22 of 22
Thread: MPG down?
    Nov 12 2007
    san francisco
    MPG down?
    I have a 1.8T FWD. I calculate MPG after I fill up my tank and I remember getting close to 31 mpg before. Recently it's down to 27-28 mpg. The only thing I've changed recently are my wheels from 16" to 17", both were stock wheels.
    Oh, and I also got a GIAC chip a while back but my mileage stayed constant after I added it so I doubt it's a factor.
    I just hit 50k. What kind of mileage are you guys getting with just a chip?
    Veteran Member Three Rings 02B6's Avatar
    Nov 05 2007
    Toronto, Canada
    Re: MPG down?
    try changing the fuel filter. noticeable when i did it.
    2002 (B6) 1.8TQM...H&R - S4 Spoiler - 6k HID - open cone filter - Forge Splitter - avic d3 - podi/SW
    Nov 12 2007
    san francisco
    Re: MPG down?
    Is it pretty easy to replace? I used to do it all the time on my Corrado.
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    Re: MPG down?
    NOTICE TO ALL:
    I don't know if it's country-wide or state by state but gas stations do use a better mix in the summer to cut down on smog in the heat. You tend to get better mpg using it. When they switch back, which they are probably doing about now, you're going to get slightly less mpg.
    I have to reason the OP probably drove a different mix of gasoline and city/highway. That's not a really big change in mpg. I wouldn't even flinch.
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    Established Member Two Rings A4donkey's Avatar
    Sep 24 2005
    Anywhere
    Re: MPG down?
    The wider tyre you have the lower MPG it goes.
    Established Member Two Rings samaritano's Avatar
    Jun 05 2007
    Miami, FL
    Re: MPG down?
    I noticed the same in my car but I was thinking it was due more to the fact that I did the N709 mod. My average has gone down quite drastically.
    Edgar
    Nov 12 2007
    san francisco
    Re: MPG down?
    Quote Originally Posted by A4donkey View Post
    Interesting.
    So Samaritano, you noticed it after changing wheel sizes?
    Jun 05 2007
    Miami, FL
    Re: MPG down?
    Not really. Tire width stayed the same. I need to undue that N709 mod and drive for a week or so.
    Edgar
    Nov 05 2007
    Toronto, Canada
    Re: MPG down?
    i have heard on engine upgrades (ie. meaning mainly more boost) say there fuel mileage was better than when it was stock. ??? anyone confirm?
    Nov 22 2006
    Re: MPG down?
    As long as you stay out of boost, your mpg is the same. Makes sense, right? No boost means no extra fuel for extra boost.
    2002 A4 TQMS
    Senior Member Three Rings kastro's Avatar
    Mar 20 2008
    04.5 1.8TQ Tip A4 Black -
    Ottawa, Ontario
    Re: MPG down?
    air filter most likely.
    Nov 12 2007
    san francisco
    Re: MPG down?
    Quote Originally Posted by kastro View Post
    Just ordered a K&N from Amazon.com, $47 free shipping. Hope it works. I wonder how dirty the stock one is...
    Veteran Member Four Rings Arclight's Avatar
    Dec 20 2006
    8VS3
    Re: MPG down?
    When is the last time you changed your plugs? Hopefully they were done at 35K as per the manual, otherwise, your gas mileage will continue to drop. I had the same issue and this was the resolution...right back to 31-33 highway
    For Sale: HRE 501s, 19 X 8.5 and 19 X 9.5
    Nov 12 2007
    san francisco
    Re: MPG down?
    Yeah the plugs were done at at around 25k actually. I do have a set of new plugs on hand, I might just throw em in.
    Dec 31 2006
    boston, ma
    Re: MPG down?
    Quote Originally Posted by samaritano View Post
    what is this mod?
    Jun 05 2007
    Miami, FL
    Re: MPG down?
    I meant to say...
    N249 mod
    Edgar
    Dec 31 2006
    boston, ma
    Re: MPG down?
    I meant to say...
    N249 mod
    that is definitely your problem...when i did this mod my mileage went down a ton...i just reversed it the other night and its back the where it was....and the car runs better also.
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    Re: MPG down?
    mpg is not whats important, you need to be worrying about how to make it go faster, not trying to make her drink less gas.
    Senior Member Two Rings inaforest's Avatar
    Sep 10 2008
    is full of junk.
    Los Angeles, CA
    Re: MPG down?
    I don't think it's the n249 mod. I did it two weeks ago and have noticed no change at all.
    Dec 18 2007
    nj
    Re: MPG down?
    Quote Originally Posted by eclimax13 View Post
    more performance normally does mean lower mpg....... even if you are just talking factions.
    and yeah, unless your pushing a larger turbo the N249 removal isn't gonna do much. removign the N249 just allows you to hold your boost longer since the ECU won't have the ability to control when the system dumps all the pressure out though the DV.
    Dec 31 2006
    boston, ma
    Re: MPG down?
    Quote Originally Posted by widgget View Post
    if that is all you care about..why did you buy an a4...i bought the a4 for mpg and awd first...so far all performance mods i have done have increased my mpg while driving normal, except the n249 mod which did nothing really but f'up my mpg...the car runs better and get much better mpg without this done
    Dec 18 2007
    nj
    Re: MPG down?
    When i wrecked my M3 i wanted to get something AWD, went shopping for a S4, saw how much of a bitch they were to work on and that i could get an A4 with some mods and be faster then the S4 anyway :P
    so now i have AWD and VROOOOM where my 95 M3 only had the VROOOOM! with a stage 3 setup on my 1.8t i still get better MPG then the BMW 3.2L inline6.
