Results 1 to 12 of 12
    Registered Member Two Rings
    Aug 08 2008
    Spain/Dallas TX
    Missfire in cylinder 3
    i swaped coils and even bought a new one but still the misfire stays in cylinder 3, i also bought new spark plugs and NADA nothing still the car runs rough and almost sounds like a modified WRX lol. Does anyone know what other possibilities, Before taking it to the STEALER.
    Thanks in advance guys.
    Aug 11 2008
    Austin, TX
    Re: Missfire in cylinder 3
    Quote Originally Posted by kaka10 View Post
    I would check the ICM next.
    Aug 08 2008
    Spain/Dallas TX
    Quote Originally Posted by techguy512 View Post
    is there any way to check it?? or i have to buy a new one and see if thats it?
    Dec 20 2007
    1999.5 Audi A4qm AEB
    iowa
    You can test an icm by probing with an ohmmeter, one side has 4 spades the other has 5
    Each cylinder is numbered on it so the input and output numbered 3 should have an OL displayed while the others will have similar ohm readings. The extra spade on one side is a ground in the center terminal. If you try testing straight through the circuit for the bad cylinder you would get a OL through the circuit and if you try that circuit through the ground you should get an OL through there also and testing the good circuits should give the same readings as testing the circuits through the ground, at least I did.
    A good icm will have similar ohm reading through all circuits of the icm.
    Aug 08 2008
    Spain/Dallas TX
    Quote Originally Posted by Toyotatech View Post
    sounds complex but i tell one of my friends to help hes know how to use ohmmeters
    Dec 20 2007
    iowa
    It's not that complex I just suck at explaining. Each spade on the icm is numbered, disconnect wires from icm, test straight thru each channel, if the icm is good the readings will all be similar readings.
    Aug 08 2008
    Spain/Dallas TX
    man i got a headache, make me wanna sell it when i fix it lol
    Feb 20 2008
    New Jersey
    i got an ICM for sale if you are interested.
    Aug 10 2008
    sehg
    i had misfires on cylinder's 2 and 4 back in august, turned out to be cracked cylinder lines and had those replaced.
    2009 A3 2.0T Quattro S-Line
    Vancouver, BC Canada
    What exactly are cylinder lines?
    I currently have cylinder 2 and 4 and random misfiring too.
    Quote Originally Posted by B5Quattro190 View Post
    IG:@steadysupreme
    Pics&Detail
    Senior Member Three Rings A4Quattro > all's Avatar
    Sep 23 2008
    Wisconsin
    Yeah i've been having some cylinders misfire too. I swapped plugs and it still happens..
    2004 A4 Quattro
    1.8t 6 Speed Manual
    Established Member Two Rings A4Gasm's Avatar
    Jan 24 2008
    98 Audi A4, 06 Suzuki GSXR600
    Boston Massachusetts
    this happened to me back in may, turned out to be the ICM
    98 A4 1.8TQtip
    Gpop K04 Hybrid / GIAC pump /3.0" magnaflow at the downpipe / Baily DV / AWE Vent Boost Gauge / 17" Gloss Black S4 AVUS / K&N in stock box / Smoked Side Markers / Debadged / 20% Tint / Kamie Grill / Facelift Tails with Foglight Mod / Blitz Dual Turbo Timer
    Buy my cd player and subs please http://www.audizine.com/classifieds/...ct=2353&cat=44
