Results 1 to 9 of 9
    Aug 18 2008
    SoVA
    Need help deciphering some DTCs
    My MIL came on the other day, so I hooked up the VAG-COM and here is what I found:
    6 Faults Found:
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 008 - Implausible Signal - Intermittent - MIL ON
    16685 - Cylinder 1: Misfire Detected
    P0301 - 008 - Implausible Signal - Intermittent - MIL ON
    16691 - Cylinder 7: Misfire Detected
    P0307 - 008 - Implausible Signal - Intermittent - MIL ON
    16686 - Cylinder 2: Misfire Detected
    P0302 - 008 - Implausible Signal - Intermittent - MIL ON
    16689 - Cylinder 5: Misfire Detected
    P0305 - 008 - Implausible Signal - Intermittent - MIL ON
    16687 - Cylinder 3: Misfire Detected
    P0303 - 008 - Implausible Signal - Intermittent
    My first thought was coilpack given VAGs track record with coils over the last few years. Then I realized that there are misfires in 6 cylinders, and it seems pretty unlikely that 6 coils went bad. I looked up the DTCs in the Bentley manual, and this is what it said:
    Misfire Detection
    Check fuel injectors
    Fuel injectors, removing and installing
    Fuel rail with fuel injectors - component overview
    Ignition coils with power output stages checking
    Overview of component locations
    Has anyone here experienced this issue? It seems to come and go. The MIL came on about three weeks ago and promptly went back off a few days later. Being the lazy procrastinator that I am, I waited for it to come back on before checking the DTCs. I'm thinking that it must have something to do with the fuel rail, but I guess it could be six bad coilpacks...lol.
    Oct 11 2007
    Suburbia
    Re: Need help deciphering some DTCs
    Is there a noticable loss of power? Just curious....
    Aug 18 2008
    SoVA
    Quote Originally Posted by WinterRunner View Post
    no, but it does seem to run a little rough at start up. in my google searches i found someone who had the same DTCs and they were caused by a bad MAF. I think I'm going to disconnect it and see if the DTCs go away.
    Aug 18 2008
    SoVA
    I have changed the plugs since the first time the MIL came on, so it's most likely not the plugs.
    Veteran Member Three Rings ChronicTeutonic's Avatar
    Apr 11 2008
    1978 MGB, 2006 Vespa LX-150
    Pasadena, CA
    You tried checking the coils? The manual has a section that details the procedure. You don't need many tools, a test light and a voltmeter. I'm almost thinking that with so many out at once you may have a fried ECU??
    2005 Brilliant Black B6 S4 Avant - K&N Drop-In, Thermal R&D cat-back, VAGed, Höen Xenonmatch Fogs
    2009 United Grey MKV GTI - 18 in. Hufs, APR Stage 1
    ChronicTeutonic's Past Teutonics:
    BMW 2002 (x2), VW Microbus, BMW 320i, VW Corrado G60, VW Jetta IV
    The Avant Garde
    Aug 18 2008
    SoVA
    Quote Originally Posted by ChronicTeutonic View Post
    no, i haven't done the test procedure. i guess i could swap coils from one of the misfiring cylinders to one of the good and see if the misfire moves to the other cylinder. i really don't think that's the problem though. i just ordered a new MAF. hopefully that will solve the issue. otherwise, i may have to resort to bringing it to the dealer.
    Jan 30 2009
    2004 Nogaro Blue Audi S4
    Wisconsin
    Did you find out what was causing your random misfires? I am having the same problem and was hoping you had some success in tracking down the source.
    Dec 05 2006
    So. Cal.
    did this just happen on startup or while driving the car? Also, what kind of car do you have.
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    Quote Originally Posted by webstir View Post
    This guy hasn't posted in the forums since 10/30/08, you should probably send him a PM to get any chance of a response.. The PM will send him an email, where as the post in the forum will not unless he is subscribed to the thread. Good luck!
    2013 White 911 4S
    Gone but not forgotten:
    2015 Sepang Blue S3 - 1 of 5 exclusive edition
    2004 Nogaro Blue S4 Avant w/ Noggy interior
    2005 Moro Blue S4
