Whats up everybody. It's an exciting time for the 4.2 motor and the supercharger thats headed down the pipeline is going to rejuvenate the 4.2 scene. Many of the challenges facing the 4.2 are the same as what i faced with the 3liter. That said, leads me into why i'm writing this and to also raise some questions about the challenges that the 4.2 motor faces.
Ok, everybody knows that the 4.2 S4 is a great motor and the following is solid and loyal. Many have wanted more power and now there is a S/C headed for the 4.2. As with many N/A motors there is just not enough strength in the bottom end to hold up to high boost levels. It's human nature to keep pushing the envelope and Hp junkies will try to push the motor beyond the limits of what the stock S/C kit from VF is putting out. I.E. Smaller pulley will be the first question many will ask. If i raise the boost level by dropping the pulley size what will happen? Well lets start with the Eaton [email protected] running the VF kit and from what i've read maxes out around 9psi on this kit. The M90 is a great blower and is capable of much more boost to the tune of 16+psi. So as you can see the M90 has plenty of head room to up the boost. That said you can start to see how under worked the blower is with the VF kit and for good reason. IMO VF knows the 4.2 can handle some power but not as much as they probably would like. Yes the VF kit will give most folks the added power that there looking for but there will be those who will want to take it further and IMO this is where the problems begin.
As i stated ^^^N/A motor sometimes have a weak bottom end and are suspect to blown pistons under high boost levels . Everybody knows the stock VF kit will suit most folks but there are those that will say 500bhp is just not enough. I ran the M62@5psi maxing out around 9-10psi on the 3liter with no added mods other then a cat-back to start and as long as i did not create anymore power i was safe to a point but once i made a set of Dp's/catless and ran Supersprint headers for my car the power was there and you could feel by dropping the cats the car felt even more ready to bounce. Well once i did that i was breaking piston and it was not from the tune but because i had reached the limit of what the N/A 3liter could handle. IMO the same issue may come up with the 4.2. FYI as far as i know i'm the only person building built 3liters and now i have two built 4.2's to add to the list. What about the stock clutch on the S4? IMO just like the 3liter the stock clutch will do but it's probably not the best choice after adding an extra 100+hp's plus more TRQ it's something to think about. Heat is the enemy. I know the VF kit has a cooling system to aid in keeping normal operating temps but a oil cooler is something to think about? I could go on and on about furthering the performance of the 4.2 but i'll leave it at that for now. BTW i'm also a authorized dealer for Overland Parts.
Built 4.2 part list:
New OEM block
New OEM FFcrank
New OEM seals
New H-beam rods
JE 9.1 F/piston/pins
Deck cooled at customer request
Factory bore
Still looking for a head stud kit
Current project.
Built 4.2
Stock heads
RS4 FW/clutch
RS4 motor mnts.
Oil cooler
Dp's/catless
Supersprint cat-back
VF kit when its ready(possible port/polish of the M90 if Stiegemeier feels its going to improve performance will see what they say once the kit is ready)
Smaller pulley when VF kit is ready
Not sure if we will run meth on this set up yet still much to consider
Innovate wideband,oil pressure, boost gauge kit
Stasis cntr-diff-chng
SShifter
Waiting on you VF...lol
