Results 1 to 10 of 10
Thread: Cyl #5 misfire
    Veteran Member Four Rings zz2h33's Avatar
    Jul 28 2008
    2002 Avant 3.0L
    Chicago, IL
    Cyl #5 misfire
    Going to lunch today, CEL started blinking and engine runs like crap. Obvious misfire. Took it to AutoZone and its coming up as #5 misfire. I just put new Denso Irradiums in maybe 300 miles ago. Couple questions:
    - Could it be the Denso's? Anyone else have problems with them?
    - Maybe coil pack?
    - Are the cylinder locations on these engines the same as american engines where #1 cylinder is front left bank, then #5 would be rear left bank (sorry, i'm a newb with the german cars)
    - Am I risking any damage if I drive it home like this so I can work on it?
    Thanks.
    02 Avant 3.0 // Avant Garde Member // 3.0 Group Member
    Veteran Member Four Rings IronAudi's Avatar
    Jun 13 2007
    Middletown, CT
    Re: Cyl #5 misfire
    switch the coils around and clear the codes. pull the battery then turn it on and see if it moves. If its not to far you should be ok, dont run 80 miles or anything
    2018 C7.5 A65 3.0 S BB Bone Stock - for now.
    2008 B7 A4 2.0 T Brilliant Black|20% Tint|18" RS4 Reps LE|Bone Stock Brand new old Engine.
    Jul 28 2008
    2002 Avant 3.0L
    Chicago, IL
    Re: Cyl #5 misfire
    ^Thanks! I'll try that.
    I just did a little googling and i found something that said the cylinders are numbered as follows:
    3 6
    2 5
    1 4
    (Radiator)
    Can someone confirm this? This is a different arrangement then typical American engines.
    Thanks.
    Veteran Member Four Rings HTA A4's Avatar
    Jul 11 2008
    2002 1.9L HTA3076R A4
    Illinois
    Re: Cyl #5 misfire
    I get a Cyl. 5 misfire everyday.. I feel you.
    Anthony
    Eurocode Tuning | fifteen52 | Speed Freaks Fabrication
    BetaAlphaTau Member #41
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    Re: Cyl #5 misfire
    Quote Originally Posted by GTRS A4 View Post
    your Cyl 5 is never firing, lol. it's spinning instead, count your turbo as Cyl 5. J/K
    you should replace the CP and see what happens next.
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Re: Cyl #5 misfire
    Quote Originally Posted by zz2h33 View Post
    Thanks.
    Good thing you don't have a typical American car!
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Jul 28 2008
    2002 Avant 3.0L
    Chicago, IL
    Re: Cyl #5 misfire
    ^Yeah, like my trusty 3800 SC'd Regal that has been getting me around the past few days since the Audi has been broke down :(
    It was indeed the coil pack, i swapped it between #4 & 5 and the problem moved. BTW, the arrangement of the cylinders is what i posted above for everyone's info.
    Sep 23 2006
    Houston TX
    Re: Cyl #5 misfire
    3 6
    2 5
    1 4
    (Radiator)
    Thanks.
    That is correct
    Senior Member Three Rings ProJect_*A4*'s Avatar
    Jun 01 2008
    2011 BMW M3 Comp. Package
    Re: Cyl #5 misfire
    i had the same issue the other day.
    cel went on and engine was tweakin out completely.
    borrowed an obd2 scanner from schucks and had readings of cylinder 3 misfiring...
    replaced all the coils and plugs with some new njk's 6E's and the car idles/runs so much smoother.
    loving it!
    Good luck!
    German Engineering
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Cyl #5 misfire
    coilpacks ftl
    - Clint
