Results 1 to 4 of 4
Thread: Eneos 0W-50...
    Sep 16 2008
    B6 S4 Avant Nogaro 6-speed MT
    Normal, IL
    Eneos 0W-50...
    Anybody using it for their S4 engines? I have a bunch left over from my last car.
    Dec 05 2006
    So. Cal.
    Re: Eneos 0W-50...
    number 1 oil in japan. supposed to be some really good stuff. never used it in my german gar.
    Veteran Member Four Rings PetrolDave's Avatar
    Jan 14 2007
    SOLD: 2006 B7 RS4 Avant
    Hampshire, U.K.
    Re: Eneos 0W-50...
    I would say that 0W-50 is too viscous, the recommended oil for the S4/RS4 (in the UK at least) is 5W-30.
    Sep 16 2008
    Normal, IL
    Re: Eneos 0W-50...
    True, but the actual oils that fall into the recommended oil rating VW/Audi recommends for this car are all 5W-40 oils for the most part. Check out the list in this thread...
    http://www.audizine.com/forum/showth...light=oil+type
    I think this Eneos 0W-50 is best of both worlds - top lubrication properties on cold startup and in the winter as well as viscosity to handle very high engine temps (check out your under hood temps - I'm betting our S4s operate at a higher temp than most cars).
    Thinking bout using this stuff.
