Results 1 to 6 of 6
    Veteran Member Four Rings A4 Effort's Avatar
    May 28 2007
    '99 A4 2.8 / '07 A4 S-Line Avant / '09 A4 S-Line 2.0
    Mt. Airy, MD
    Doing my control arms this weekend - quick questions
    So i've decided to tackle the installation of my new control arms and TRE's this weekend. Since i don't have a Bentley manual, i will be using the DIY write-up found here: http://www.audiworld.com/tech/wheel43.shtml
    2 quick questions:
    1) Is the removal of the knuckle/rotor assembly necessary, or does it just ease the installation process?
    2) I understand it is best to torque the control arm bolts while they have a load on them (ie: car sitting on all 4s). I don't have a pit to gain access to the arms from underneath, so i'm scratching my head at this one. Can someone explain how to best torque the control arms with the car on the ground? I don't see much room to work given that my car is lowered, and the wheel is in the way. I'm thinking turning the wheel in each direction would give me clearance enough, but would like to get your thoughts.
    | 2007 Ibis Ti S-Line Avant | APR Stage 2+ | APR HPFP | 034 HFC | Forge DV | Stasis Exhaust | KW V1 Coilovers | SPC Adjustable Control Arms | 19" MRR GF6s | 034 TIP | 034 Sway Bar & End-Links | K&N Drop-In | Deval CF Front Splitter | Relak CF Sideskirts | S4 Recaros | TT-Sline MFSW | P3 Vent Gauge | RS4 Grille | RS4 Fog Grille Mod | RS4 Pedals | RS6 Shift Knob | OEM+
    Veteran Member Four Rings le91688's Avatar
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    Re: Doing my control arms this weekend - quick questions
    make your own write up with lots of pics :) I imagine ill have to do this soon too
    Account Terminated Three Rings lotusgardener's Avatar
    Dec 24 2006
    1997 Audi A4
    NW & NE
    2) You can have the car on jack-stands then jack up on the strut. This will put load on the arm.
    Oct 15 2006
    From a few to one...
    Arlington, VA
    Quote Originally Posted by A4 Effort View Post
    what about putting it up on ramps? that should keep the suspension loaded while give you some clearance...
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - APR Stage 1 ECU/TCU, APR Intake
    May 28 2007
    Mt. Airy, MD
    Quote Originally Posted by lotusgardener View Post
    Quote Originally Posted by NyteEscape View Post
    Two very good ideas - thanks! I should have thought of that, but i have a tendancy to overcomplicate things at times. I might go with the ramp solution as this would give me an excuse to finally go out an buy a set.
    Dec 14 2006
    Halifax, NS, Canada
    i suggest taking out cv from the hub. I poped my cv off axles when trying to put lowers in.
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
