    Sep 04 2008
    2004 Audi A4
    Brooklyn NY
    Pic request of B6 A4 sedan with B7 Sport susension
    Thanks
    Jan 10 2007
    VA
    Re: Pic request of B6 A4 sedan with B7 Sport susension
    It will look exactly like a B6 with sport suspension, except it will probably sit a little higher. I know its a direct swap and you won't have any problems, but for some reason every B7 sport or s-line sits higher than the B6 sport and ultrasport.
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    My friend on his b7 took 03+ sport suspension with my 02 springs in the front to let it sit a little lower. It doesn't sit as low as my car did with suspension which is surprising because his car is heavier in the front with the 2.0t and 6 spd i would guess.
    but like he ^^ said it will sit a little higher then a b6 with the same suspension.
    Sep 04 2008
    2004 Audi A4
    Brooklyn NY
    Pics?
    Established Member Two Rings audimcnasty's Avatar
    Jul 20 2008
    black B6, white Q5
    chicago
    don't do it. it'll still look like non-sport...
    this guy from AW did it
    Clicky Click for thread
    my advice is to wait until a set that matches your exact setup comes along (ie - if you have a b6 1.8t sedan w/ quattro, DON'T get a sport suspension off a b7 or 3.0 or avant or fwd etc.)
    - eddiemcnasty
