Results 1 to 16 of 16
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    Front Spacers=Vibration
    Just installed H&R 10mm front spacers, I had to machine off the part that stick out of the spacer and goes into the wheel for it to fit in the wheel. At 60mph on the highway I get bad vibration in the steeing wheel, and when I slow down from higher speeds I also get that vibration in the steering wheel. Anything I can do???
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Veteran Member Four Rings SeKKeY's Avatar
    Mar 06 2005
    MKVI GTI (dd), DTM S4, B6 USP (sold), B5 1.8T (RIP)
    San Jose, CA
    Re: Front Spacers=Vibration
    i had that vibration too..and i was running 5mm spacers in the front (to clear bbk). i cleaned off the hubs really well and stuck them in the back + got new rims and now i have no vibrations anymore. i had vibrations from 55-60 mph
    USP CLUB MEMBER #10
    Stage 2++++++++ JHM B7 S4
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Which RS4 wheels do you have?
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Nov 04 2007
    Minnesota
    Quote Originally Posted by actlsub9 View Post
    They are from lakeshore wheel and tire..... and i can get a spacer to fit inside of thier hub part.
    Current:
    Veteran Member Three Rings SKIDMRK's Avatar
    Sep 14 2006
    Monroe, WA
    put the corner you're working on in the air and loosen the lug bolts while someone is pressing on the brake pedal.
    re-tighten and then re-torque the lug bolts in a star pattern while the car is still in the air and your friend is back on the brake pedal. this should help to center the lug bolts and the wheel to the hub as there will be no additional forces at play.
    epitome - Like McCormicks, we're seasoned
    achtuning - podi
    Apr 12 2007
    Milwaukee
    did you machine off the hubcentric lip that is supposed to fit inside the wheel? that is what keeps the wheel centered to the hub and shaking is wheel not being centered.
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    exactly what skdmrk said
    -Sami-
    Nov 04 2007
    Minnesota
    Quote Originally Posted by infernocl View Post
    Yes, I had to machine that off for it to fit into the wheel
    Current:
    Nov 04 2007
    Minnesota
    Quote Originally Posted by SKIDMRK View Post
    I will give this a shot, it feels like the wheels arnt centered when I drive, I torqued them down the 1st time when the car was on the ground, that may be it
    Current:
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Also concur with SKDMRK
    I had to send back my hubcentric H&R spacers because of them not fittin in to aftermarket VMR RS4 (V1). I didn't want to cut off lips because I don't have access to anything that can machine off precisely. If you just cut them off, that could be causing vibration.
    But in any case, I get bad vibration at about 50-60mph if they aren't centered well.
    I jack up whole end (fr or rr) of car and leave lugs hand-tight and spin wheel as fast as I can to help it center itself. Then, tighten a little at a time in a star pattern. Keep tightening until they are as tight as you can get while on stands. Then lower car until both tires (fr or rr) are on ground- but not taking full weight. Then tighten more in star pattern. Use a torque wrench so you get even pressure on all lugs.
    When I take the xtra few minutes to do this, I have no vibration at all.
    Also, be very sure you don't have even the slightest of debris on the hub, wheel, or spacer.
    My 2004.5 APR Stage 3+ is SOLD
    Feb 19 2007
    Charleston, SC
    just tighten them in the air......dont bother lowering it.
    -Sami-
    Feb 28 2006
    Pittsburgh-Philly
    hard to do when you don't have anyone around to hold down the brake pedal. I only lower enough to get a little tire traction so I can tighten all the way from there. By the time full weight is on ground, they're tightened.
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    impact gun with torque sticks.
    Sep 14 2006
    Monroe, WA
    Quote Originally Posted by rxrep View Post
    If i don't have a helper, I just use a chunk of 4x4 wood, a towel and wedge it between the pedal and the seat. works like a charm.
    achtuning - podi
    Nov 04 2007
    Minnesota
    Well I had my friend hold the breaks and I tightened them in the air, I still have vibration, and the steering wheel shacks back and forth a bit while breaking and at 60mph, not as bad as before though.... I dont know what to do, probley gonna take them off and put the 17's back on
    Current:
    Jun 14 2005
    Anaheim, CA
    The hub on the spacers should be the same size as your hub, so either the spacers were made with too close a tolerance, or the wheels were machines to the correct tolerance, but didn't allow for paint thickness.
    Also, if the wheel wasn't centered correctly, then you would most likely get vibration at all speeds since an un-centered wheel would be the same as a out-of-round wheel. If vibration only occurs at certain speeds, then you might want to check you balance since an out-of-balance wheels wil vibrate badly at it's resonance frequency.
    Brandon @ VMR Wheels
