Results 1 to 11 of 11
    Established Member Two Rings A4donkey's Avatar
    Sep 24 2005
    Anywhere
    2005 CVT problem
    CVT problem was well known in B6 from 2001-2004, some mechanics said those from 2005 or even the B7 cvt are using different hydraulic pump design which eliminate the fault where B6 use to have.
    I just wondering how many 2005 CVT owner in this forum having problem .
    Established Member Two Rings cgmiller63's Avatar
    Jul 01 2008
    2006 Audi A4
    Southern California
    Re: 2005 CVT problem
    What type of problem are you having?
    Sep 24 2005
    Anywhere
    So far no problem, just wondering if I should sell it b4 it happens, due to very $$$$$ for the repair...
    Veteran Member Four Rings Erocko's Avatar
    Feb 16 2008
    Honolulu, HI
    I have a 2005.5 and haven't had any trouble with my CVT with Revo.
    Current: 2019 B9 A4 Quattro
    Former: 2016 8V A3 Quattro, 2011 Mk6 GTI DSG 4-door, 2005.5 B7 A4 2.0T FWD CVT
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    I don't have CVT, but I haven't heard about any problems with them from members here since I've been very active on here for a year now
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    I have an 06 CVT, and from personal experience I can tell you, this tranny can take a beating.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Sep 24 2005
    Anywhere
    Sounds like Audi really made improvement from B7 generation (7speed CVT).
    Am I too early for this conclusion?
    By the way how often do you guys change the CVT fluid?
    Senior Member Three Rings fromGMCtoAUDI's Avatar
    Feb 03 2008
    '08 audi A4 2.0T
    alexandria, VA
    Quote Originally Posted by A4donkey View Post
    Well it isn't really 7 speed, actually it has unlimited shift points since it's variable. When it's in sports mode, it simulates a 7 speed gearbox.
    Btw HID, wow dude how much are you putting to the crank? I heard the CVT handles maximum 300 hp/300 tq you seem to have exceeded it.
    Oct 14 2006
    MK6 Jetta
    South,FL
    Im putting down crank whats on my sig, and an unhealthy amount of torque.
    -EI AL CAI.
    -Driver Mod.
    Veteran Member Four Rings gaede's Avatar
    Jun 06 2008
    fourbanger
    Carlsbad, Ca
    06 CVT no problems.
    Sep 24 2005
    Anywhere
    Quote Originally Posted by fromGMCtoAUDI View Post
    when I say 7 speed , it only make it easier to distinguish its generation with its preset configuration, since its from 2005.5(B7). By knowing its stock preset , you can tell its year and model.... there is no stock 7speed setting B6 right?
