Results 1 to 7 of 7
    Veteran Member Three Rings fitch303's Avatar
    Jan 03 2008
    Columbus, Ohio
    do the rear speakers produce more bass then the fronts?
    I was playing around with my radio controls today and noticed while changing the output from front to rear that about 80% of the bass comes from my front door speakers and when output is changed to the rear I hardly have any bass at all, just treble or whatever. non bose symphony
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    Re: do the rear speakers produce more bass then the fronts?
    yep mines the same way...almost sounds like there not even on but when u go back to fronts, its bumpin
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Quote Originally Posted by fitch303 View Post
    Did you mix up front and rear in this question? The title asks if there is more bass from the rear.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Jan 03 2008
    Columbus, Ohio
    Sorry, I turned the bass to max and then moved the sound from front to back and when the back was on then no bass at all (just treble) and even with all the speakers on and sittign in the back the bass is coming from the front. I just figured since there are oem subs with an amp that the rear speakers would produce way more bass then the fronts.
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    Same way in my car (with Bose), fronts fo all the work, pretty sure the sub is for show, lol, dont get me wrong it sounds good, but it doesnt hit very hard
    Please Drive Right
    Jul 30 2008
    2003 A4 1.8TQM5
    PA
    Well the stock sub has a lot working against it.
    -Free air
    -Small Diameter
    -Cheap
    -Not much power
    Jan 03 2008
    Columbus, Ohio
    you're correct, but it's almost as if I don't even have a rear sub.
    what are the front door speakers rated at compared to the rear deck in terms of wattage?
