I just installed new pads and turned the rotors on all four corners but now my driver side brake is squeaking and I also hear a clicking sound when it gets below say around 10 mph to a stop. I removed the driver side pads and put more brake lube on the back and sides but that still didn't fix the problem. The only thing I can think of is that the rotor is bent a little on the edges because I had to use a hammer on the top (not on the surface) to break it loose. Would that eventually wear itself down or do I need to get new rotors for the front? I thought something might be loose but I tightened everything up so I don't think that is it. Maybe the brake hardware is worn out, like the spring? Any other ideas?
