Results 1 to 9 of 9
    Veteran Member Four Rings AB18's Avatar
    Dec 17 2004
    US
    What value do you guys use in vag com with the window/vagcom mod?
    Ive tried a few different ones and still not working. Right now i tried 16204, im using the info off rosstechs site, any ideas?
    2001 S4 6sp...has a few goodies...and JHM shifted
    Tons of parts for sale..
    GIAC A box ECU for sale-350shipped.
    http://www.audizine.com/forum/showthread.php?t=170072
    Jun 14 2007
    2000 S4
    Connecticut
    Re: What value do you guys use in vag com with the window/vagcom mod?
    From Ross Tech...
    35-Central Locks: -- KWP-1281
    VAG-COM Works fine (note: pre-'97 A4's may not have this module).
    Recode locking options
    [Select]
    [35 - Cent. Locks]
    [Recode - 07]
    Enter the coding below
    [Do It!]
    Write down the existing coding for future reference.
    S4, A4 1998+ with Concert/Symphony radio, anti-theft system and keyless entry
    Standard Coding: 16140
    Add the following options to your coding number:
    +64 Windows up, sunroof close, and windows down with remote.
    -04 One touch unlock of all 4 doors and trunk
    -1024 Remove horn honk when arming
    +32 Auto lock/unlock of doors (Doors lock at 15 mph and unlock when key is removed)
    Take the standard coding for S4.....16140
    Use a calc to total up what you want then go for it!
    Jun 14 2007
    2000 S4
    Connecticut
    I see that you actually posted the correct number :-p.... After me NEVER getting the dam window thing to work, I finally got it. Say you want the windows up. Your car is unlocked..... Hit the button once and thats it, it will lock the doors.... Then once it locks, then press and hold the button down (lock button) and they will go up..... Other way for down. Unlock by pressing once, THEN hold unlock and they should go down.... I always thought mine was broken because I would hold the button locking my car but they would never go up. it needs to be a seperate hold lol
    Feb 17 2004
    Sterling, VA
    I liked this combo the best on my B5:
    -Window control with remote
    -1 touch unlock of all 4 doors
    -No horn sound when arming
    -Lights flash when arming
    Code = 15176
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Jun 14 2007
    2000 S4
    Connecticut
    i like the auto lock @ 15... makes me feel all warm and fuzzy hahaha
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Just add +64 to whatever value you have to get window control.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Veteran Member Four Rings HighDesertAudi's Avatar
    Mar 09 2005
    NorCal
    It's pretty straight forward. As Daft stated "15176" worked well for me.
    Previous Audi's
    1999 Audi A4 1.8T Quattro 5spd Laser Red
    2000 Audi S4 6spd Nogaro
    1990 Coupe Quattro 5spd Lago Blue
    2000 Audi S4 6spd Laser Red
    2004 Audi S4 6spd Dolphin Gray
    2004 Audi A4 6spd Brilliant Black
    Jan 29 2007
    08 S4 00 S4
    MD
    Ya know, I've never tried to put the windows up after this mod, down works fine. I'm gonna have to try it now...
    08 S4- Stock SOLD
    Dec 17 2004
    US
    Thanks guys, ill give that other code a try and report back.
