Results 1 to 13 of 13
    Veteran Member Four Rings wofman's Avatar
    Apr 01 2008
    2010 Jetta TDI
    Exhaust Installed
    After some indecision, back & forth the new pipes are on! AWE downpipes finally installed -- no more check engine lights and no more confusing the ECU, pure free-flow. Then did swap for almost new Milltek catbacks, modded the valence accordingly, and voila: the car gives something in between a purr and a gentle growl. Deep sound, not obtrusive, no drone at cruise rpm (which is not necessarily all that low an rpm ).
    Heading out for road trip for several days as soon as these are posted below. Still have the gutted downpipes (OEM -- cleared out completely), but those piggies are going to market.
    Have great weekend, all!
    wofman
    Nothing going to bring it back: 2000 C5 2.7T 6sp MT
    Ming Blue, S6 Blades, EuroSpoiler,
    GIAC-93, AWE DPs to Milltek Catback,
    RS4 Clutch, JHM DT-Stabilizer, VAST Short-Shifter,
    H&R Sways, Eibach Pro-kit, Bilstein Sport Shocks, etc., ...
    NOW: '10 Jetta TDI w 6MT, Revo Tune Commuter Car
    Veteran Member Four Rings audirs's Avatar
    Mar 22 2005
    Kitchener, Ontario
    Re: Exhaust Installed
    awesome, enjoy your trip. we want to hear some sound clips when you get back!!
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    how much louder is it with the DPs? i have a milltek catback, i know its not exactly the same, but i know milltek designs all their catbacks to similar noise levels. Just wondering if it would be worth it to install cut outs for that roar when necessary.
    Senior Member Two Rings African2.7T's Avatar
    Dec 18 2007
    B5 S4 Laser RED
    PA
    Warren look really good. give me a call when you come back
    MK4 GLI Blue lagoon
    B5 S4 Laser RED
    Past Rides
    C5 A6 2.7T
    B5 S4 Santorin Blue
    MK4 JTI VR6 Money Green..lol
    Senior Member Three Rings TWINTURBOA6's Avatar
    Nov 20 2005
    Audi A6 2.7T Quattro + more : )
    Rockville,Md
    Thumbs up Re: Exhaust Installed
    NIIIIIIIIIIIIIIIIIIIIIIIIIIIIICE Exhaust set up!! Please post up some videos!!! cruising, startup, b/w shifts, and wot please!!! that'd be awesomme ....does it backfire at all??
    Apr 01 2008
    2010 Jetta TDI
    I think this is directed to different thread??? (wot = Endeee)
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    wot = wide open throttle
    open that sucker up!
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Veteran Member Four Rings deucescorner's Avatar
    Aug 26 2008
    None
    None
    looks good man, can't wait for the sound clip
    Wofman, do you know if the lower part of your bumper are just connect through clips or screws or is it part of the actual rear bumper.
    I've been wanting to expose my exhauts but I have a 2000 model
    Apr 01 2008
    2010 Jetta TDI
    "wot" - got it. Was thinking of the cut-off system allowing shifts with accelerator floored to hold boost.
    It's actually not very loud, though sound got deeper as I used it -- harder driving loosened up cells cats in AWE, I think. I think downpipes/cats get louder with a break-in. But no backfiring. Much more sedate than that (Milltek has has resonators and mufflers, though some take out res's to change that). Idle is quiet, dull rumble (quieter than magnaflow) but I do hear more when I get on it hard, for sure. I was near Blue Ridge Parkway and got all over a twisty run to climb up to parkway (Rt 80 - NC; great road!) a few weeks ago, on way back from there did some great back roads in Va, WV and Md, then Cliffs of Insanity. Tone clearly was deeper after that along with some highway miles. And some gurgling when accel is released and revs drop, but not a lot. I plan to get on it a bit more.
    I'll see if I can get somebody to drive it while I stand by at Poker Run in a couple days. Geezers don't know audio clips but I'll look into it.
    Bumper (valence) was modded with cutouts, sanded for smooth edges, and valence repainted (Sam at EliteMotorsNJ). Looks stock, right?
    Glad you like it!
    wofman
    Mar 22 2005
    Kitchener, Ontario
    Quote Originally Posted by deucescorner View Post
    think its all one piece man
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Apr 01 2008
    2010 Jetta TDI
    yes - missed that -- "valence" is integral (but cut-out is not expensive); I used to think downturns "kept the stealth", but if you look around since 2000 every car has pipes exposed, dual exhaust look, and it is no longer some sort of advertisement of a fast car, or anything like that.
    Veteran Member Four Rings ENDEE666's Avatar
    May 04 2007
    A6 2.7T 6MT Modded. Allroad 2.7T 6MT.
    LI,NY
    Looks great man!! Congrats!
    01 A6 2.7T, blk/blk, 6MT, SSP Tuned!, 3,996 lbs w/ me, full weight, street tires, 29+lb wheels.
    Ran an 11.8 @ 119 at MIR - Sept 2008. FIRST A6 IN THE 11's!
    Also 04 Touareg 4.2 89k with 22x10s
    Apr 01 2008
    2010 Jetta TDI
    Endeee -- going for the ride with Poker Run tomorrow morning? (see tri-state forum sticky thread for details -- supposed to be nice, sunny day)
