Results 1 to 38 of 38
    Veteran Member Three Rings f15046's Avatar
    Oct 30 2007
    Griffin, GA
    2001 A4 Gt2871R build Unitronics MAF-LESS tune
    I haven't posted too much about installing a Garrett gt2871r on my 2001 A4 quattro. I am still running stock internals for now, until I build a spare AWM engine that I have.
    Parts:
    -Garrett gt2871r (t25 flange) exhaust housing adapter to V-Band
    -PES manifold
    -custom made water and oil lines (from Summit Racing)
    -Unitronics BT tuning (MAF-LESS, eliminate SAI, )
    -550CC Genesis injectors
    -Greddy Profec B Spec II EBC
    -3" exhaust system
    -Electric fan (eliminated engine driven fan)
    - Walbro 255lph fuel pump
    - Custom 3" Downpipe
    I am sure there are a few other parts I am forgetting to put on the list. I installed this at the end of June 2008, and have put about 6000 miles on this setup. It runs great! If anyone has any questions or suggestions, let me know.
    By the way I bought most of this stuff used and spent a total of about $2900. The tuning and injectors alone were $1250
    I do work around the South East on your 1.8t or 2.7t, PM for more info
    ** 2001 A4 TQM
    -Fully built 2.0, GT3076, SPA mani, custom 6-puck clutch, Unitronics tune, Walbro 255, and much more
    Jan 25 2006
    A4 2.0T
    MD
    Re: 2001 A4 Gt2871R build Unitronics MAF-LESS tune
    Should spool nicely...
    Why 550cc injectors?
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Uni 630cc file, 630cc Injctors and Snow STG2 with a dual nozzle setup.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Might want to relocate your intake filter, that thing is just going to suck up hot air coming out of your radiator. I relocated my outside temp sensor to that spot and saw temps of 50 degs higher then the actual outside air temp in front of the radiator.
    Oct 30 2007
    Griffin, GA
    034 motorsports recommended the 550cc injectors, and I've never heard anything bad about the 550's. Is there any difference b/t the Uni 550 file and the Uni 630 as far as power?
    I will reconsider building an intake. Even where the filter is now, I am only seeing Intake temps that are 10degrees above the outside temp. So I would say that's not too shabby.
    ** 2001 A4 TQM
    Sep 24 2005
    always in design
    I don't recall UNI specifically tuning a 550cc file. Intake temps make the world of a difference.
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    are there any advantages for going with a bottom mount manifold instead of a top mount? i see more top mounts on members cars than i do bottom mount.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Sep 24 2005
    always in design
    Quote Originally Posted by zrowcool View Post
    Most are running the ATP, which is side mounting. PES used on this setup was 2nd hand, PES only sells kits unless Tony has decide to sell the Mani alone. The top mounting are all T3 flange GT30 or larger setup Tunnin either one f many Tubules available of the SPA cast Mani (I think there are 4-6 of us now).
    Jan 25 2006
    A4 2.0T
    MD
    BATS probably wouldn't fit on a bottom mount setup.
    Jul 07 2004
    socal
    Quote Originally Posted by Don Supreme View Post
    Correct. Just not enough room to fit the turbo next to the frame rail, plus the runners hitting the compressor housing becomes an issue since the turbo needs to be located further back because compressor housing is much larger and to allow room for the much larger inlet hose/pipe. Even the side mount log manifolds like the ATP and ATP copy place the turbo too far forward to put a 4" inlet hose/pipe or a big enough filter onto the inlet.
    Veteran Member Four Rings .Mad Hatter.'s Avatar
    May 07 2007
    which route are you going with the intake/TIP?
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    nice!!!1
    VIDEOS!!!!!
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Jul 07 2004
    socal
    Quote Originally Posted by unorthodoxa4 View Post
    He is running a mafless tune which means he can just throw a filter onto the turbo inlet.
    May 07 2007
    ah good point...i didnt even think about that.
    ok, for arguements sake, if you were say running the UNI 630cc file with the 3" MAF housing and TIP with the same turbo, which would be the best source of air intake?
    Oct 30 2007
    Griffin, GA
    You would have to make your own intake for that setup. Right now I am just running a filter on the turbo.
    I will get some vids eventually.
    ** 2001 A4 TQM
    Established Member Two Rings eurojuce's Avatar
    Nov 19 2008
    VW B5.5, 96' Volvo 960 wagon, 07' RC46 (VFR800)
    NC
    Quote Originally Posted by f15046 View Post
    Hi
    This is where I want to go eventually, right now I'm running a GT28R setup (GT2871R is next step). Question, with your MAF less file, how does it run? I heard that I should stick with the MAF for daily driving...what's your opinion.
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    WTF is that gasket that you're using for the turbine outlet?!?
    Please tell me you will get a real gasket and that is not RTV red?
    Oct 30 2006
    B8 A4 Avant 6spd
    Quote Originally Posted by 317ssayzarc View Post
    Ahaha, certainly looks like it.
    -18 718 GTS
    Oct 30 2007
    Griffin, GA
    I drive mine daily everyday, 4 days of the week are 100 miles round trip. It runs perfect and has never missed a beat.
    Yep thats red RTV, and it hasn't leaked.... YET. But yeh next time I screw with the exhaust I will be putting a gasket in there.
    Another update: I replaced the 1st O2 sensor (wideband sensor) just for the hell of it b/c the car has 120,000 miles on it. The car seems to be a tad more powerful and more responsive.
    ** 2001 A4 TQM
    Jan 25 2006
    A4 2.0T
    MD
    Is it just me or is the compressor wheel on that turbo a little fucked up?
    Oct 27 2007
    In the lab
    Well you are lucky that those two flanges are well machined, because that RTV has long since burned off
    How's your mpg?
    Oct 30 2007
    Griffin, GA
    Yeh the turbo fins are fudged up, only on the very tip, the part you can see through the inlet of the compressor housing. I bought it that way.
    I get around 25-26 MPG for half city driving and half highway. If it's straight highway miles it well get 30mpg.
    ** 2001 A4 TQM
    Registered Member Two Rings a418ts's Avatar
    Dec 25 2008
    A4 2001 1.8t Sport Quattro TIP
    Chi-town
    i really dont know abotu a MAFless tune, but what does it do ? like what difference does it make.
    I'm getting a similar kit like this so i want to know what will be best for the best performance but without effing up my engine.
    Jul 07 2004
    socal
    Quote Originally Posted by a418ts View Post
    Just means that the ECU isn't dependent on readings from the Maf sensor to adjust fuel or adv timing. This is all done by the ecu using speed density and using the 02 sensor as the main sensor for hitting the right AFR.
    This means there is 1 less sensor that can go bad causing the car to run worse and less restriction in the intake system for the turbo which means better flow and more power.
    Not 100% sure the TIP cars can be tuned mafless seeing that the TIP controller does depend on the MAF when it comes to choosing gears. I guess this is something one of the tuners would need to answer.
    Veteran Member Four Rings adr3naline fix's Avatar
    Dec 17 2008
    Sold 01 1.8T, 05 Mini Cooper S JCW, 04 ZX10R Track
    Milwaukee
    I have almost the exact same build! awesome stuff
    My car is SOLD
    2001.5 1.8TQM || GT2871R Hybrid Elim @ 24psi | Unitronics Custom | 307awhp | etc | $15k+ in parts alone
    Oct 30 2007
    Griffin, GA
    MAFLESS-ftw! Its damn good setup, great daily driver, and super fun to drive. You should post up your build.
    ** 2001 A4 TQM
    Sep 22 2008
    Nor Cal, Petaluma
    Don't mean to get off topic sorry for the newb question but can pre-2000 engines run a mafless tune?
    Sep 24 2005
    always in design
    Quote Originally Posted by Cecchini View Post
    NO, not unless you add a MAP and go SEM.
    Oct 30 2007
    Griffin, GA
    I don't think so. The reason the 2001's can is they have a wideband o2 sensor that the ecu uses to keep the Air/ fuel ratio in check. The 2000's ECU uses a narrow band o2 therefore must use the MAF to keep things in check.
    ** 2001 A4 TQM
    Established Member Two Rings blkb6a4's Avatar
    Feb 24 2008
    2001 audi a4 1.8t quattro
    Minnesota
    2001's also have a map sensor
    2001 Santorin blue :91 oct APR chip, atp 3" test pipe, APR stealth cat back, "dope" rear emblem, painted grill, clear corner mod, custom center vent VDO boost gauge, H&R race, 034 Snub, 034 n75H, Southbend stg5, Stoptech stage 2, A8 fat fives, CXracing 2.25 FMIC, DDM 5k HID.
    I am currently accepting donations for my BT fund PM if your interested in helping
    Sep 24 2005
    always in design
    Quote Originally Posted by blkb6a4 View Post
    He has a 99' gents, not a DBW (2000-2001).
    Dec 17 2008
    Milwaukee
    I should! When it isn't -9*F with a windchill of -31*F so I can get some close up pics! :(
    My car is SOLD
    Oct 30 2007
    Griffin, GA
    go ahead and write a description and post up, you can add pics later.
    ** 2001 A4 TQM
    Established Member Two Rings Pscheoverdrive's Avatar
    Jul 10 2007
    2011 A4, 2008 A4
    Rockville, MD
    I'm running a GT2871 Elim, but here's my setup:
    You'll have to excuse the DV return hardline. :P I have an ATP 3" TIP kit, but I ended up cutting it down a lot. I was having trouble trying to snake the 1" DV return line around two 90%%d angles b/c it kept crimping, so I went to Lowes and bought some plumbing fittings. :P For some reason, ATP's elbow has the DV return line on the wrong side of the elbow, but I imagine the use the same elbow for several kits and they're just saving money on machining or something.
    Jul 10 2007
    2011 A4, 2008 A4
    Rockville, MD
    Oh, and my intake temps are typically less than 10%%d F less than ambient with an Evo Racewerks Comp FMIC.
    Oct 30 2007
    Griffin, GA
    Well a little update.
    The car has been running great. The setup ran a 13.4 in the 1/4, with a 2.0 60ft time.
    Well I want more power. So I will be building a 2.0 with a GT3076R.
    I talked to Unitronic about their 830cc file and this will be what I go with.
    Here are a couple of pics of the turbo.
    ** 2001 A4 TQM
    Registered Member Three Rings seanriv's Avatar
    Jan 07 2008
    2001 Audi Allroad, 2015 Mini Cooper
    San Francisco,CA
    I think that 2871 still has some power in it. A 12 second 1/4 should be reachable. Congrats on going bigger though.
    Sep 14 2006
    Lansing, MI
    excellent choice for BAT set up...gt30r with a 2.0.
    SOLD
