Results 1 to 6 of 6
    Registered Member Two Rings
    Oct 30 2006
    former s4 owner
    farmington, MI
    Whats the difference between RS6-K04's and RS4-K04's???
    im about to go stage 3 relatively soon and was looking at my available options and saw some sets of RS6-K04's and RS4-K04's...I was wondering if anyone knows the exact difference between these turbos. and opnions on if the performance difference is worth the extra $$$....i was also looking into the different softwares available....i was thinking of either ASP or VAST also input on that would be very helpful
    Veteran Member Four Rings pit viper's Avatar
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    Re: Whats the difference between RS6-K04's and RS4-K04's???
    The RS4 is a direct bolt-on, no modifications needed.
    The RS6 has a different CHRA, with a bigger compressor wheel, and has a larger turbine housing that requires you to weld a new flange onto your downpipes.
    I've only seen 1 set of dyno's from straight RS6's, but the spool up looks to be quite a bit slower.
    Oct 30 2006
    former s4 owner
    farmington, MI
    do you have any input about my question on the software subject....I am mostly considering ASP or VAST..
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    Quote Originally Posted by 1 point 8 tee View Post
    Nope. I'm in the same boat myself, picked up a bone-stock 2.7 A6, been doing a ton of research on turbos, tuning, etc...
    Veteran Member Three Rings 2ndEngineS4's Avatar
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    Some info I found:
    Specs:
    As follows in comparison to a regular RS4 K04.
    Compressor wheel OEM RS4: 40mm inducer, 51mm exducer
    Compressor wheel JHM RS6: 42mm inducer, 56mm exducer. The turbine housing a/r is also much larger. There will be a lot of gains on the hotside due to its larger size. Works with K04 inlet pipes and stock exhaust manifolds, coolant and oil lines
    Tuning: I would personally choose Vast, but Jason can certainly give you more details.
    http://www.jhmotorsports.com/shop/ca...products_id=18
    JHM.Vast.034.ER.SR.AWE.RS4.Apikol.APR.Innovate.Stg III
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    I think ASP kit is a compleat one as is Vast, they should have OTS tune to start with, also I belive EPL can tune for you as well,
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
