Results 1 to 12 of 12
    Established Member Two Rings TGabriele's Avatar
    Jan 08 2007
    Trip Computer Upgrade
    I have searched and couldn't find the answer I was looking for, so I figured I'll turn to the Guru's here at AZ.
    I currently have a loaner car from the local Audi dealership and the trip computer has a few more functions than mine that I would love to add. In addition to the standard stuff I've got, it also has a trip odometer (in addition to the one next to the odometer), a screen with a digital speedometer, and a built-in menu screen that allows you to change the display (i.e., add or remove functions from the 2 trip computers, change the date/time format, language, etc.)
    Does anyone know if I can upgrade mine to this? If so, how? Would it be that I have to replace a control module or the entire instrument cluster? Or is this functionality stored in the main computer for the car? Thanks in advance for any helpful advice.
    P.S. - I have a 2004 A4 3.0Q with the Trip Computer & functionality that it came with back then.
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    Re: Trip Computer Upgrade
    bump, is there a way to display current speed on the main screen?
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
    Jun 08 2008
    Calgary AB Canada
    dont think so, only average speed
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    Kinda off topic, but my uncle got his b5 s4 to show boot and vacume, can ours do this?
    Please Drive Right
    Veteran Member Four Rings Undisputed's Avatar
    Jun 29 2008
    05' A4 USP, 00' Suburban, 07' Tahoe
    I remember a thread on that a while back. It was showing how to do it on a B5 but nobody seemed to have done it for the B6. The B5 mod looked to be extremely difficult and time consuming though.
    05' USP 6MT-REVO Stage II- Racetec- Stoptech 332- OCarbon Fiber Interior Trim- B7 RS4 Steering Wheel- VMR Boost Gauge- Siemens 380's- Bailey Motorsport DV- NGK Copper Plugs- LED tails- and a few other things
    -Damon-
    USP CLUB MEMBER #927
    Aug 26 2005
    What is the loaner? Regardless, there is no known way to change the display of the DIS, in the fashion requested. There is a method of using the DIS to display whatever info desired, but it requires add-on hardware and specialized programming on the added hardware.
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Can you expand on this?
    I have always wondered if there was a way to change the "welcoming screen" to read something more personal.
    *referring to the "push clutch pedal in" screen
    -Sami-
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by Pothole View Post
    That is EFu 4U and is only available on the B5 chassis.... clicky click
    -Doug
    Jan 08 2007
    The loaner I had most recently was an '08 A3 2.0T, but I've had an '08 A4 2.0T Q w/TPMS (which I don't have, unfortunately) before and it's trip computer did everything the A3's does, except for the digital speedometer.
    No one knows whether the Trip Computer is controlled by the ECU, a Trip Computer module, by the instrument cluster itself, or by some other means? I was hoping to hear that it was the instrument cluster as I was planning on changing it out for a Color DIS model.
    Jun 02 2008
    LOL why can I only think of dirty things to make my car say
    Please Drive Right
    Aug 26 2005
    Quote Originally Posted by TGabriele View Post
    The various information displayed by the DIS, is configured by the DIS display electronics inside the instrument cluster, using signal inputs from several sources, primarily the engine ECU and the ABS controller, for MPG and average speed data. The radio sends RDS information via the infotainment CAN buss. The MPG and Road speed data is sent to the IC from the engine ECU and the ABS controller via the power train CAN buss.
    Jun 30 2007
    Raleigh, NC
    ^so setup sending units for the things you want to display, find a way to tap into the same bus which is communicating with the DIS, and create a protocol which can talk to the DIS from the sending unit. right?
    doesn't seem too hard does it? lol
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
