Results 1 to 9 of 9
    Senior Member Two Rings DOBERMAN@UA's Avatar
    Sep 15 2008
    A6 c6 3.0 Tdi (300hp)
    Ukraine, Kiev
    tire size for 18x8 et 45
    I bought new silver OZ Ultralegera 18x8 et 45 for my b7 .
    What tire size would you recommend?
    I'm considering of 255/35/18 for rear and 245/40/18 for front.
    Any suggestions?
    A6c6 3.0 tdi(300hp), koni sport shocks, eibach pro kit springs, q5 4pot brake calliper, a8d3 sport seats
    Veteran Member Three Rings outlaw77's Avatar
    Jun 19 2007
    2010 Camaro SS/RS 6.2 V8 Inferno Orange Metalic 400rwhp 400tq
    Langley BC Ca.
    Re: tire size for 18x8 et 45
    235's are all you need. Tops.
    07 Ibis White S-Line 6smt - APR 93,91,89 - APR snub mount - 19" Sportec Mono 10's - H&R springs - RS4 rear sway - RS4 pedals -
    Veteran Member Four Rings Glassnpowder98's Avatar
    Mar 07 2008
    Audi A4 B7
    VA
    I have the ultraleggera's as well but they are 19x8. I'm rocking 245/35/19 BF Goodrich T/A kdw's and couldn't be more happy. If you look at them from the front or rear, the sidewalls and tires are pretty much lined up perfectly. No stretching or whatever the opposite of stretching would be?
    05.5 A4 2.0T Brilliant Red 6MT: Put some money and time into it...
    The only standing start, straight line racing I enjoy is on the way to the first corner.
    Jan 01 2008
    Long Island NY
    235/40/18 All Around. Do not use different tire sizes.
    Sep 15 2008
    Ukraine, Kiev
    Quote Originally Posted by Auditude2.0T View Post
    Why I shouldn't? any pros cons? In one forum I found that it is best set up to have a little wider tyre for rear.
    Quote Originally Posted by Glassnpowder98 View Post
    I ll pick them up only on tuesday, beforethat I do want to find out what tyre size do I need
    Now I have 18x8.5 ET50 ABT wheels, with 235/40/18 and I have some problems with outsides of tyres(it wears much faster then other part of tyre, maybe it is because of suspension(I have stock))
    Quote Originally Posted by outlaw77 View Post
    Pros cons?
    Senior Member Two Rings jayM's Avatar
    Jun 29 2007
    on an 8" wheel width, i second 235/40/18 all around. As far as i know, the only time you should use diff widths is if you are running a staggered setup ie 8.5" or 9.5" rear. But running a staggered setup on our quattros is a whole different can of worms.
    2012 Mercedes-Benz C350 4matic Sedan
    2006 Audi A4 2.0t quattro - Sold
    Vancouver, Canada
    Senior Member Three Rings atop's Avatar
    Jun 09 2008
    North Hollywood
    Mine is 35mm F with 245x35x19 continental tires.
    and the rear is 40mm with 275x30x19 Falken tires.
    A T O P
    Senior Member Three Rings fromGMCtoAUDI's Avatar
    Feb 03 2008
    '08 audi A4 2.0T
    alexandria, VA
    I'm running 235s on 18"/8.5" and they match perfectly.
    I read somewhere that too much rubber is bad for handling and if you check the wheel/tire guide in the b6 faq section, 235 is the perfect width for 7.5"-8.5" wheels
    Sep 15 2008
    Ukraine, Kiev
    Quote Originally Posted by jayM View Post
    Any links? I don't understand..
    Quote Originally Posted by atop View Post
    For how long do you use this set up? Any problems?
