    Veteran Member Three Rings ZEUSROTTY's Avatar
    Feb 19 2008
    Bolingbrook IL
    cel light for misfire on 5 and 6 on a s4 4.2
    I replaced the coils and the plugs, and i still have it... What should I check next?
    Would a clogged converter cause this? fuel filter? pump? Help?
    2010 S4 DSG Mods None yet...
    Gone 2004 S4 Mods: tinted 25%, APR Dowpipes, w/custom custom cat back including Magnaflow x-pipe Magnaflow bullet mufflers and Flowmaster D40's . Stock intake, APR Reflash - Hotchkins Sways - Koni Yellows front and rear - H&R Springs - Goodrich brake lines - Hawk+'s - Nitto NT05's for the street and 01's for the track. 18" R8 Reps... More to come!
    Sep 23 2006
    Houston TX
    Re: cel light for misfire on 5 and 6 on a s4 4.2
    first time this has happened? no other codes? Besides checking for vac leaks, maybe compression test? Pretty easy DIY and tester is only about $25.
    Veteran Member Four Rings trexturk's Avatar
    Mar 20 2007
    '11 Sprint Blue S4, 03 996 Targa
    Chicago Burbs
    clogged converter
    Nov 28 2007
    04 S4,Volvo P1800,03 Silverado
    Massachusetts
    Quote Originally Posted by trexturk View Post
    clogged converter
    when you say converter.... what do you mean?
    Mar 20 2007
    Chicago Burbs
    the converters are clogged up not allowing the car to breath
