Results 1 to 4 of 4
    Veteran Member Three Rings bmags88's Avatar
    May 12 2008
    B6 1.8T A4 / 06 Lincoln Navigator(Ultimate)
    Massachusetts/S Shore
    Best settings for a Nikon D40
    So I want to take some good pics of my A4. I have a Nikon D40 but, have no idea what i should set it to if i wanted to use a sunrise or sunset backdrop. Can anyone help me?
    - Mags
    2003 1.8T A4 Quattro
    18" B5 RS4 Gunmetal Reps / K&N Drop-in / Helix Ecode Reps / Forge DV / DTH side skirts / 6000K Lows / OEM S6 LED DRLs / CF Beltline Trim / Blacked-out upper/lower grills / Parrot MKi9200 / Podi (Stewart Warner) Gauge
    USP Lower Front / S4 Grill
    Feb 17 2006
    Re: Best settings for a Nikon D40
    best mode to set it to is - PRACTICE
    photo's are 90% the person behind the camera, than the camera itself.
    Veteran Member Three Rings endlesswinterco's Avatar
    Sep 18 2006
    Baltimore, MD
    ^agree 100%
    Arsenal Gunners!!
    06 Acura TSX
    SOLD: 98.5 2.8Q Laser Red
    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    I agree with the above comments. Go out there, put the camera into manual mode (yes...even the focus) Basically you have ISO, Shutter, and Aperature. Play with the settings and see what works best.
    DSLR's are inimidating at first but you get used to them quick.
    here are some basic tips:
    1.) If you are going to have a long shutter then use a trip pod
    2.) Read online about DOF (depth of field) and the exposure triangle
    3.) play with all the settings on your camera and read the manual
    4.) Go out and practice.
    If you are going to shoot duing a sunset, make your back is to the sun, otherwise your car will be a silloutte.
    I coud go on but you get the idea.
