Results 1 to 3 of 3
    Veteran Member Three Rings nrowensby's Avatar
    May 04 2008
    1999 Porsche Boxster
    Columbia, SC
    Problem with chipped ECU?
    Okay... I have two ECU's one chipped... one stock. When running the GIAC chip, my car will occasionally just shut off. Sometimes it while sitting at a stop light, sometimes when I am cruising down the road at 40, other times while I am doing 80 down the interstate... I see no pattern, it's just like a random shut off... no CEL's. It will also ocassionally buck a couple times while I am driving but continue to run.
    Any ideas? I have never had a problem with the stock ECU...
    ▄▀▄▀▄▀▄▀▄▀▄▀ B8.5 Squad ▄▀▄▀▄▀▄▀▄▀▄▀
    2014 Audi A4 - Stg2 - Monsoon Gray Metallic
    2015 Audi A4 - S-Line - Ibis White
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    Re: Problem with chipped ECU?
    how long have you driven the car with the stock ecu compared to the chipped ecu
    are you missing any screws in the ecu box cover?
    i had a similar issue with water entry on the ecu board due to a missing screw in the box.
    Deactivated Two Rings
    Jun 13 2007
    Buford GA.
    Quote Originally Posted by nrowensby View Post
    It sounds like you have a solder connection that is loose. Check the chip. You should be able to send it back to the GIAC dealer and have them re-solder the Eprom for you.
