Results 1 to 6 of 6
    Veteran Member Four Rings lrg8683's Avatar
    Nov 02 2005
    S4
    VA
    light squeal? vacuum leak?
    in part throttle holding anywhere between 5-10 psi i hear like a light squealing sound..sounds like it's coming from the the rear of the enging.. could it be a vacuum leak? or the hoses associated with the n75 and MBC..
    there's no noise at full boost, and no loss of power either.
    -Luis
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    Re: light squeal? vacuum leak?
    ar eyou talking about turbo spool, i notice din your sig that you just went stg3, K04's with Dp's will sound louder that stock K03's
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Veteran Member Three Rings RuS4ty's Avatar
    Mar 13 2006
    VA / MT
    your turboz are blown
    could be vacuum leak, what vacuum is the car sitting at at idle/peak boost? pressure test yet?
    another thing it could be is the tranny, sometimes they have a dull whine when they are crapping the bed.
    *NEW Addition: Misano Red RS4
    01.5 S4
    For sale(pm me for details):
    FRONT AIRBAGS !CHEAP!
    Stock S4 swaybar
    "I'd have one of those... if I were the sort of person that looked at my sister and thought, mmm..." - Jeremy Clarkson about the Roush Mustang.
    Veteran Member Three Rings VinNyS4's Avatar
    Nov 07 2007
    New York City
    i just put in a mbc and took out my n75 yesterday and im getting the same noise. its like a hum or a squeal can really describe it and it only happens at 5-10psi and i think its right when i left off the throttle
    10 b8 s4 6MT sprint blue / black & silver
    Nov 02 2005
    S4
    VA
    Quote Originally Posted by RuS4ty View Post
    it's def. the sound of air like escaping from a tiny hole.. idle is 21 in hg and boost holds at 22 just fine.. but at part throttle it's like a tiny squeak
    -Luis
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    could be the sound of air passing over the holes if you have drilled numerous holes for the darintake mod.
    Could be air being bled from the mbc.
    B5 S4 AWE Stage 3 - sold
