Originally Posted by
B6_Rakete
I pumped a tank of Sunoco 100 octane gas ($7.49/gal) into the S4 the other day when I was running on fumes to see what the stock computer would make of it. I was really surprised at the difference, the car was *much* faster as compared to running on the normal "Premium" 91 octane crap we get here in CA. It felt like the car had another 20-30HP easy, which I really didn't expect without a special APR/GIAC/Whatever tune.
I was desperate to maintain the extra HP tonight while at Shell filling up on crap and ended up pouring in some STP Octane Booster (with no advertised octane increase estimates on the bottle or on the website:
http://www.stp.com/fuel_octane.html) that they were selling at the station for $5.83. The whole bottle was supposedly good for 15 gallons of gas.
Anybody know which octane booster gives the highest octane bump without clogging/burning/choking the cats?
Two things here:
1. Octane boosters add such a small volume of high octane product that it does very little to a full tank of gas. Adding a quart of 108 octane booster to 16 gallons of 93 octane fuel, for example, will raise the octane to about 93.3.
2. Whether or not fueling up with real 100 octane fuel will yield a benefit all depends on whether the ECU is engineered to be able to advance timing and/or alter air:fuel ratios based on the use of 100 octane. The burning of 100 octane will change the the signal coming from the oxygen sensors. If the ECU can adapt and respond to the altered inputs in a power producing manner, you will see a gain. If, however, it won't advance timing any more than what is seen with 93 octane, than adding 100 octane will do nothing.
It would
appear that the S4, and certainly the RS4 are both capable of advancing timing with 100 octane beyond the level of what is seen with the burning of 93 octane.
