Results 1 to 20 of 20
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Quick writeup on swapping window switches, etc
    got sick of my peeling window switch and arm rest (especially the arm rest)... changed the parts and did a quick writeup.. nothing too complicated
    http://www.a4mods.com/index.php?page...wswitches.html
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    Veteran Member Four Rings gq9's Avatar
    Nov 07 2006
    02 A4 1.8t
    New York
    Re: Quick writeup on swapping window switches, etc
    Props to you. Thanks.
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    awesomeness
    I needed this about a few months back....that one harness I COULD NOT get off...
    Another thing is, I had trouble removing the whole switch....its seemed stuck in there, even though I tryed to unclip it from those four points!
    -Sami-
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    I OWE YOU MAN!!! Im actually starting this in the morning and wanted to get directions now you saved my ASS....
    Veteran Member Four Rings chadb2434's Avatar
    Oct 07 2008
    East Texas
    Thank you! Your site is very helpful and this just made it better! Keep it up!
    02 A4 3.0Q6MT
    -chad
    Veteran Member Four Rings golgo13's Avatar
    Apr 29 2007
    Tampa Bay
    what about easy go to links to the best spots to get the buttons?
    great job btw
    SweetnLou!
    Veteran Member Four Rings RAVI's Avatar
    Jan 29 2006
    hella stock parts
    bay area-livermore-ca
    props for this.. need to do this myself! thanks man
    '02 Audi A4 1.8BTQM
    Registered Member Three Rings int2str's Avatar
    Jan 16 2007
    2002 Audi A4 3.0 Quattro (M)
    San Diego, CA
    Do you have part numbers and prices for the parts you ordered?
    2002 Audio A4
    3.0 Quattro 6-Speed
    RNS-E GPS, MP3 + Bluetooth
    19" VMR RS4 reps w/ Toyo T1R's
    LED tail lights
    Dec 06 2007
    yo Martini how do i set up my A4mods crew account? i donated and i forgot lol.
    -Kirk
    BetaAlphaTau Member #58
    Apr 12 2007
    Milwaukee
    the single switches on other doors require slight mod to the harness using a 3 pin cd cable thing from a computer.
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Yeah thanks Martini for all the DIY on the a4mods site. I always look the new write ups.
    Going to donate also, supporting the DIY's that bail me out of problems. Thanks
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Quote Originally Posted by AudiA4Turbo22 View Post
    just send me pics... [email protected]
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Quote Originally Posted by int2str View Post
    i didn't post the part numbers, etc... because the parts can be color specific... like I said in the writeup, I had a VIN split and would have gotten the wrong color if I just used my color code... however if you order from DTH, etc, you can give them your VIN and they can get it right.
    Senior Member Two Rings [IX]'s Avatar
    Mar 09 2008
    Florida
    Me and me son hust did this on monday. You do not need to remove all of those torx to remove the armrest. Just push down on the buttons and it pops out. Just remember to connect the wiring harness to the new switch assembly before re-install
    <<NO SIG>>
    Dec 19 2007
    York, PA
    part number(s)?
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Quote Originally Posted by [IX] View Post
    as you will see in the writeup, I replaced more than just the switches.
    Jun 11 2008
    Williamsport, Pa
    great writeup martin. oh just 1 question do you proofread your articles? found a type-o in the clutch install 'pressrue' by your star diagram
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Quote Originally Posted by fire27 View Post
    I typically run spell check before I post them... but I can't say ive done it on every article. Spell check gets annoying because there are so many words/ acronyms which it doesn't know... so you end up clicking "skip" or "add" a million times
    most of the time im just trying to get them done... if I take my time, and wait too long after the install to put the words on the page, then I forget what I was even taking pictures of
    Every now and then ill go through and re-edit the articles, etc.
    I have to add some thing to each article, so I'll do the spell check on them before I re-upload.
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    switch p/n ws 8z0 959 851 F 5PR, however, I would not recommend ordering anything unless you order by your VIN
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    This is not a solicit to sell, but I will gladly provide the part numbers for anyone that asks...like Ryan stated though, it is best to use the VIN number to avoid purchasing the wrong part...electrical parts are NOT refundable at the dealer.
    VIN number assures you get the correct part if you order online.
    You can PM me or email me at [email protected]
