Results 1 to 6 of 6
    Registered Member Two Rings NRogge's Avatar
    Oct 08 2008
    99 A4 and 89 240sx
    Atlanta
    Gas Tank Problem
    Hey guys. I have a 99 A4 quattro v6 2.8L 30 valve. the gas tank is messed up because when i am filling up my gas tank it clicks off like it is full, every dollar or so. so i pull it out, and you can hear a bit of air coming out. So I guess it is a ventilation problem. can anyone help me out?
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    Re: Gas Tank Problem
    Change the charcoal canister. Its under the rear round plastic panel in the back. Look from underneath the car.
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    Oct 08 2008
    99 A4 and 89 240sx
    Atlanta
    i have looked under there before but everything looked fine. is it something on the inside of the canister?
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    Don't stick the nozzle completely in, pull it back just a little. Works for most.
    This is somewhat common. I'm sure you'll find some more info if you search.
    Senior Member Two Rings tonelee1316's Avatar
    Oct 11 2006
    rancho cucamonga
    try starting the car for a few seconds when that happens with the cap off. it works for my friends a4
    Genesis Autosport
    Evolution Racewerks
    Oct 08 2008
    99 A4 and 89 240sx
    Atlanta
    alright thanks guys.
