Results 1 to 6 of 6
    Senior Member Three Rings TheWrightAudi.'s Avatar
    Aug 07 2008
    White Rock
    valeo projector headlight quick question
    two piece to one peice install...so all the wiring is done, the head light fits perfectly, and the turn signals dont fit into the housing.. searched and couldnt find anything specific. and its getting dark out and i wanna finish up soon lol
    1999.5,1.8T,5speed,quattro.
    Understeer -is when you go off the road and see the tree that kills you
    Oversteer-is when you go off the road backwards and dont see the tree that kills you
    Veteran Member Four Rings oneohone's Avatar
    Nov 13 2007
    Baur TC2 / W221 S600
    Dallas, TX
    Re: valeo projector headlight quick question
    Cut the fender up!
    Daily - 00' Audi A4 1.8t Quattro 5mt Laser Red Avant
    In.Progress - 00' A4 2.7t Swap (w/ K04's)
    Dec 05 2007
    You can not just plug the facelift headlights into the prefacelift chasis. You have to cut the fender. And no, there is no avoiding it. Here is the write-up on it. But there are a few things not needed on that thread along with some missing pics. There is no reason to remove the front bumper other than fear of damaging it (cutting into it, hitting the paint and chipping it, or dinging it with the sawzall). What pic is missing is painter's tape placed around the headlight housing as not to damage the paint on the fender while cutting.
    Just take your time while cutting and you can make a perfect fitment. Don't cut too much. Cut little by little to you get it just right (you can cut trim off, but not add on). Take your time with it. When done, make sure to use spray paint around the area you cut (and allow to cure) as to avoid rust before you install the headlights. I am no painter, but I am sure there is a rust protective primer, use OEM color (there is a web site, but am too lazy to search for it right now that has perfect matching paint), and clear coat.
    Aug 07 2008
    White Rock
    NOOOOOOOOO sorry my bad i guess it was a bad picture!!
    i allready cut and it fits fine the TURN signal bulb does not fit into the housing, the three tits dont line up! sorry again
    Dec 05 2007
    I had that same problem with my Valeo US spec to Ecode swap. The connector was different for the US spec and Euro spec. I ended up usiing my US spec turn signal socket, and the 3 guides did not line up perfectly with the Ecode housing. What I did was dremel one of the guides off, and have had no issues as of yet. 2 of the guides will line up and 1 will not. That is the one I dremeled off.
    Aug 07 2008
    White Rock
    k thanks alot thats all i needed to know
