Results 1 to 12 of 12
    Senior Member Two Rings roTTirocket's Avatar
    Mar 18 2007
    02 Audi TT 225QR, 96 C36 AMG
    Hayward, CA
    DV making sputtering noises
    Well the title explains my question. Every time I shift gears, instead of the typical "whoosh" sound, I get a sputtering sound from the dv. Then once the engine is warmed up, it goes back to the normal whoosh sound..and the sputtering magically dissapears! Can someone give me some insight on this?
    Instagram: Rysidhu
    Registered Member Four Rings D.C. Designs's Avatar
    Feb 28 2008
    Many
    alexandria
    Re: DV making sputtering noises
    make sure its installed good and if there's a leak
    Mar 18 2007
    Hayward, CA
    yea i checked for any loose connections..everything seems ok to my best knowledge. It never had a problem before, just happend recently. And like I said earlier the strange thing is, the sputtering only happens when the engine is cold, once it warms up its perfectly fine.
    Instagram: Rysidhu
    Mar 18 2007
    Hayward, CA
    *bump
    Instagram: Rysidhu
    Active Member Two Rings DannyAudiTT's Avatar
    Jul 23 2008
    Audi TT
    Hunters Creek Orlando
    same thing happens to me
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Needs lubed IMO. How long have you had it installed.
    Lubricate the bore and moving parts lightly w/ synthetic high temp grease (Mobil 1, etc) once per year. Period.
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
    Deactivated Three Rings
    Jun 15 2007
    2007 GTI 2.0T
    Charlotte, NC
    buy an R1, no maintenance at all, diaphram based.
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Quote Originally Posted by GMP - Matthew View Post
    Less than stellar performance in the TT world (AW) reported using the R1. No personal experience, but I've avoided them.
    Diaphragms tear (ask your GF!) and require maintenance just as much as pistons and o-rings.
    Jun 15 2007
    2007 GTI 2.0T
    Charlotte, NC
    R1 requiring maint.? I dont think so, and are we talking about the same R1s that are also used on 700hp+ Porsch 996TT's?
    Veteran Member Three Rings joe@vwvortex's Avatar
    Feb 12 2004
    2008 Cayman S, 2014 Q7 TDI and 2000 Boxster S race car
    Cowtown
    Yes - the ones that at least 6 or 7 TT owners that I know of have sent back to APR for new springs and even then couldn't get rid of the honking issue. I'm a big APR fan - but the DV isn't one of the items i'd be the least bit interested in. I've run Forge DV's since 1998 on all my 1.8T (6 of em) - so you have to lube em ever 5k - takes about two minutes. They always hold boost and they rarely if ever fail and they don't honk.
    Mar 18 2007
    Hayward, CA
    yea its been in there for a really long time...i guess lubing it wouldnt hurt
    Instagram: Rysidhu
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    (kindly) what we think is not born out by what we observe. Can't explain it, but "it is".
