Results 1 to 18 of 18
    Senior Member Three Rings Muck_and_Grind's Avatar
    Jun 09 2008
    2001.5 Audi S4 (on stands), 1989 Grand Wagoneer, 2007 B9 Tribeca
    Lodi
    tearing apart the B5 S4 sunday
    had JHMotorsports do the aux water pump, SMIC and shifter and oil change for a wonderful college affordable price and now i have to change the head gaskets. stopped by JHMotorsports today and he had everything i needed to get the job done on sunday. cheaper than taking it to a shop. i got a guy that is certified to work on vipers coming over to see what he can do without pulling the engine. JHMotorsports always has the hook ups. on everything. i think everyone should help them get control of the west coast and support your local JHMotorsports, oh wait the only JHMotorsports.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: tearing apart the B5 S4 sunday
    Quote Originally Posted by Cbowerman View Post
    i got a guy that is certified to work on vipers coming over to see what he can do without pulling the engine. .
    :facepalm:
    try again homie. "while anything IS possible id say this is not something I'd try." -Adam Hernandez, Master Technician VW
    Veteran Member Three Rings ThePaintballGuy's Avatar
    Mar 14 2007
    Phoenix Arizona
    I replaced (well had a shop replace) the headgasket on mine without pulling the engine.
    josh
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by ThePaintballGuy View Post
    josh
    have you ever broken a manifold/head stud because you were wrenching on the nut at the wrong angle?
    Jun 09 2008
    Lodi
    Quote Originally Posted by ThirdStrike View Post
    :facepalm:
    you know, were just going to nut it up and go at it. i live down the street from JHMotorsports. come on now, just a phone call away
    Established Member Two Rings jstrat812's Avatar
    Mar 09 2007
    Scottsdale
    Have him put a Viper engine in!
    Jun 09 2008
    Lodi
    no. i would rather keep the s4 engine. it kind of fits
    Established Member Two Rings S obsessed's Avatar
    Sep 27 2007
    North Dakota
    I also pulled my heads without removing engine. I then replaced the manifold studs with bolts. much easier.
    2001 s4 6sp stage 3
    Jun 09 2008
    Lodi
    is that why you dont have a engine in your car?
    Sep 27 2007
    North Dakota
    No. I tore the heads off last year to replace bent valves from broken timing belt due to an accident from previous owner (I bought car wrecked). I am in middle of stage 3 upgrade and the motor is actually back in car, just not hooked up yet.
    2001 s4 6sp stage 3
    Jun 09 2008
    Lodi
    Angry Re: tearing apart the B5 S4 sunday
    http://www.audizine.com/forum/images...s/banghead.gif so my dad came over so we could start tearing apart the s4 today. we got the bumper off and called JHM a few times for some help over the phone and away we started tearing the motor out. 15 minutes later my dad yells... fuk this $h!t, call Jason and see how much he will charge us to do the whole thing. now i have to wait until after the 22nd to take the car to JHM and have him do it. atleast he has a college discount for me. http://www.audizine.com/forum/images...es/thumbup.gif to JHM
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    It's a hard life....
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Veteran Member Four Rings S-Power's Avatar
    Jan 11 2008
    034 Stage 3
    CA- San Jose
    No doubt, JHM is awesome Jay And Matt are ballers.....
    Senior Member Three Rings theboogieman1's Avatar
    Jan 08 2007
    02 Audi S4
    Pacifica, CA
    They've been real good to me as well. Looking forward to getting back out there for some more work.
    02' Black S4 6spd / JHM "Stage 3" / JHM "Solid" Shifter / VAST Stg. 3 Clutch and LW Flywheel / Vogtland GT's / 034 Track Density Motor Mounts/ AWE DTS / JHM FMIC / Hawk HPS Pads / H-sport sways / SSAutochrome TB Exhaust
    Jun 09 2008
    Lodi
    Quote Originally Posted by Stampy View Post
    no, you have no idea. it is costing me so much money. my girlfriend is hating the car and wanting me to get ride of it because it has and is going to cost about 3500 to get it to run, right; that is without timing belt, turbos, water pump.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    15 minutes! Damn your dad has less patients than mine.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Jun 09 2008
    Lodi
    yeap. none at all. he works for freightliner and racecars; thats about it
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    it took me less than two hours to pull my motor out...just follow some diy's and it will be easy..dont give up
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
