They need to be serviced yearly. You simply take it apart, wipe entire dv with a rag and apply some grease (I use Mobil 1 Synthetic, and I think if you go another route a lithium grease is the one to use. But don't quote me on that). Apply the grease on the outside of the piston, inside wall of the dv, and very light coat on top rim. Forge says that you don't need to service till after a year coming from that factory, but that is bull. Apply grease when you get it and put it in. Then wait another year before service. I had my piston get stuck a couple months after installation and caused me a little aggravation till I found out it was the piston of the dv causing so much trouble..
Link
