Results 1 to 20 of 20
    Veteran Member Three Rings audidrver's Avatar
    Mar 31 2007
    CA
    Check out my system!!!
    Thought i would share my trunk with you guys?
    What do you think?
    Veteran Member Four Rings rudtf's Avatar
    Dec 27 2005
    07 A4 2.0TQM S-line Ti Ibis
    Ft lauderdale
    Re: Check out my system!!!
    i got the same system as you!
    very stealth man.
    Veteran Member Three Rings Audi Juice's Avatar
    Feb 11 2005
    08 Titanium
    Huntington Beach
    what woofer did you put in the bose location? What amp are you running?
    May 27 2007
    New York
    Where did you hide the amp?
    Ive been trying to find a place to hide my amps that wont cause them to overheat...
    Veteran Member Four Rings harryd14's Avatar
    Jun 30 2008
    Atlanta, Ga / Norwich, England
    yeah what woofer did you install? i wanna know cuz i was thinking of changing the stock one out for something a little more powerful
    A4 2.0Tq 6spd - Dolphin Grey
    AWE Exhaust - V708 18x8.5 - Dynavin Navi - Carbonio CAI - Blacked Out Grill - Retrofit Bi-Xenons - Passport SRX
    Smoked Reflectors - 7500k Fogs - LED city lights - CF rear lip spoiler - Tint
    Mar 31 2007
    CA
    Oh ya you can't see anything....here are the rest
    Kappa perfect 12 and alpine PDX 1.6
    Veteran Member Four Rings Erocko's Avatar
    Feb 16 2008
    Honolulu, HI
    wow, that's pretty slick.
    Current: 2019 B9 A4 Quattro
    Former: 2016 8V A3 Quattro, 2011 Mk6 GTI DSG 4-door, 2005.5 B7 A4 2.0T FWD CVT
    Veteran Member Three Rings outlaw77's Avatar
    Jun 19 2007
    2010 Camaro SS/RS 6.2 V8 Inferno Orange Metalic 400rwhp 400tq
    Langley BC Ca.
    thats exactly what I want to do. looks great!
    07 Ibis White S-Line 6smt - APR 93,91,89 - APR snub mount - 19" Sportec Mono 10's - H&R springs - RS4 rear sway - RS4 pedals -
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    doesn't the amp require ventilation??? doesn't it have cooling fans and such... if so.. you might wanna be careful from it overheating and/or causing some kind of electrical failure or fire.
    DUH! an Audi
    los angeles, CA
    you make the box yourself?? if so I wanna get one done for a different car! haha
    Mar 31 2007
    CA
    Quote Originally Posted by Sanjman View Post
    i've been running the amp there for 6 months with no problems, the gain is set pretty low for my taste. Also these amps run cool and it is placed almost level. They were actually designed to be stacked on top of one another.
    Nov 16 2007
    Westerly//Providence
    doesnt that cover rattle? pretty sick setup!
    Mar 31 2007
    CA
    Quote Originally Posted by Quattro View Post
    Yes. It wasn't difficult to do, but it was very time consuming and very messy. I followed a4mods.com for the most part.
    Mar 31 2007
    CA
    naw, not ratting from the cover:) I originally carved one out of foam, but the box ended up to big because of the sub choice. I figured if it rattled i would add some dynamat on the guards, but it doesn't. However the carpet pulses in between.
    Veteran Member Four Rings CZA420tAvant's Avatar
    May 24 2008
    06 A4 Avant 6MTQ Brilliant Red
    Orange County, NY
    do you have any more pictures of the process from stick frame to solid box? Im guessing fiberglass?
    Nice and stealth.
    Driving: 2006 Brilliant Red A4 Avant 2.0TQM
    Revo Stage 2|Carbonio Intake|Stasis SS coils|Podi Gauge|iForged 19"|H&R spacers|RS4 F/R sways|custom inlet pipe|Milltek turbo back with custom twin tips
    Endorsing:
    Mar 31 2007
    CA
    No that's all I have from about 6 months ago. Just finished the cover...been lazy. Here is the writeup that I followed except i had to build the hole frame because I wanted to be able to take it out. All fiberglass with no filler(box is hidden) saves a lot of weight.
    http://a4mods.com/#index.php?page=we...es/subbox.html
    May 24 2008
    Orange County, NY
    can you take a picture of the removable box and how do you secure it, or is it heavey enough to be stable in there?
    Endorsing:
    Nov 16 2006
    Skokie, IL
    Quote Originally Posted by audidrver View Post
    wow that is dope
    Mar 31 2007
    CA
    Quote Originally Posted by CZA420tAvant View Post
    can you take a picture of the removable box and how do you secure it, or is it heavy enough to be stable in there?
    When add a cap i'll post a pic behind the cover.
    Stable for the average driver.... yes, for an Audi enthusiast....no. Its pretty snug. I have only 1 metal strap for the box because it sits on the floor of the cubby. Then I only have 1 strap for the amp because the way its wedge and everything is solid. The mounting all depends on what amps you have and the shape of your box.
    Mar 31 2007
    CA
    I also removed the factory sub to let the sound come in from the trunk. What a pita to do unless you are ok with hacking everything up. I might close it up though when i get an exhaust.
