Page 4 of 11 FirstFirst ... 23456 ... LastLast
Results 121 to 160 of 428
  1. #121
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: Ok , I guess I'll start one ...
    Quote Originally Posted by onemoremile View Post
    That is so cool.
    If you've got decent enough measurements to create accurate cad models you can print a perfect paper template of that end curvature. One of the assembly features is an interference sketch. You can select surfaces or bodies and you should do each. That gives you the interference curves on the leading and trailing edge of the blade when it is in it's nominal closed position.
    Copy and paste these profiles into a new sketch or into a drawing document and print out 1:1 scale. Cut the blade to the larger/longer shape. Then lay the shorter on it and color everything remaining with a Sharpie, both sides and the end of the blade too. Then hit the sander and shave the color off while still leaving a stripe down the middle of the edge. That edge can be radiused for longevity.
    It should take about 10-15 minutes to go from cad to paper templates. The whole thing should be knocked out in well under an hour. Finished tolerances should be about +/- .010".
    Jim, How accurate do you think the finish casting surfaces are inside the turbine housing? Wondering if you can work off a nominal part (if Garrett will supply a nominal 3-D model) and then build in some form of a tolerance to account for casting variation. Then CNC the plate to keep accuracy and precision high (and repeatability!).
    Looking awesome Jay!
    -Doug
  2. #122
    Senior Member Three Rings silverman's Avatar
    Sep 27 2008
    '98 A4 1.8tqm. Bilstein pss9.
    Hartford, CT.
    Thumbs up Re: Ok , I guess I'll start one ...
    This is sick, i now have a new goal for my avant!!!
  3. #123
    Mar 17 2006
    00 A4, 49 Ford p/u,
    Vibrant Performance
    The tolerance for the Garrett housing will vary slightly... there are three casting locations. Secondly, to keep this accurate and w/o issue from customer to customer you have a few other things to keep in mind- how far does each exhaust mani manufacturer over lap the collector to turbo flange weld? how much is each manifold surfaced? In quick, these two items inparticular can change the flapper design/length and profile.
    More to come today... Just finishing up the bracket to hold the actuator in place...
    My rat rod to tide you over.
  4. #124
    Mar 17 2006
    00 A4, 49 Ford p/u,
    Vibrant Performance
    So, after measuring the amount of throw the actuator will have at "x" psi- I've mounted it to the valve cover..
    Also to keep the actuator from going off line from the exhaust path at WOT I've also put a stopper on the outside of the housing.
  5. #125
    Oct 29 2005
    10speed
    San Francisco, CA
    Jay are you making a custom rod from the actulator to the flapper now?
    and why is the turbo backwards?
    - Clint
  6. #126
    Mar 17 2006
    00 A4, 49 Ford p/u,
    Vibrant Performance
    No... the turbo is exactly how it used to be... turbine passengers side, compressor drivers. The machined surface you see on the turbine, closest to the actuator, is the v-band for the new DP.
    The angle the actuator sits on is prependicular to the current "closed" location of the flapper... I put the actuator arm parallel to the flapper inside so I can monitor its exact location during dyno. So as u see it, it is connected. Its quite hard to get a camera in there to see the actuator arm.
  7. #127
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    it's not. it's called transverse
    EDIT eh, i guess i was staring at your work for too long. haha
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
  8. #128
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by sean1.8t View Post
    Thanks
    He posted a picture of a B5 that I thought this was going into... in which case the turbo WOULD be backwards
    - Clint
  9. #129
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Thanks
    Post 118 says this particular prototype is for a customer's TT. He'll then do something similar on his B5.
    -Doug
  10. #130
    Oct 29 2005
    10speed
    San Francisco, CA
    fair enough, must have missed that, I just saw the B5 and thought that was what it was going on
    - Clint
  11. #131
    Sep 17 2006
    SLC, UT
    thanks dougy. i figured people would be paying attention to every single word in this kind of thread. i know i am
    Current:
    Previous:
  12. #132
    Dec 03 2005
    2 pedals 1FG
    connecticut
    No problem guys.
    This is one of my favorite threads on AZ right now. SO much technical info with real-world results.
    -Doug
  13. #133
    Sep 17 2006
    SLC, UT
    No problem guys.
    yeah, i can imagine you reaching for the lotion everytime jim or jay posts up some of that technical mumbo jumbo
    Current:
    Previous:
  14. #134
    Mar 17 2006
    00 A4, 49 Ford p/u,
    Vibrant Performance
    This thread even gets me excited... beleive it or not it give me more motivation to get things done.. aside from the motivation I get from the end results of any project I do.
    Anyways... I hope to get this running today or tomorrow, the dp is almost complete now, I HATE rematching exhaust systems, time consuming to get things re-aligned.
  15. #135
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I don't get that excited.
    -Doug
  16. #136
    Oct 29 2005
    10speed
    San Francisco, CA
    lol Jay I imagined you to be older
    - Clint
  17. #137
    Mar 17 2006
    00 A4, 49 Ford p/u,
    Vibrant Performance
    you mean look older... lol.
  18. #138
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Quote Originally Posted by California Jay View Post
    Yeah I figured I could have done that.. I think with the amount of time I would have spent clay filling/profiling/measuring the interior contour of the housing may have been the same time I spent doing the sanding on the flaper you see here..
    I'm sure there will be a time again where I can carry this out in another part of the build.
    Right on brother - I'd rather get my hands dirty too. Got to spend a few hours today deburring, drilling, and tapping a waterjet piece designed last week. Took 3/8" aluminum plate and needed to drop weight so it got the full triangulation treatment and looks like fully triangulated 3/8" square stock. Went from looking like a shoebox to a like a fully machined mini monster truck chassis.
    I thought you were milling the housing to shape the interior walls. Four flat walls with radiused corners. Drop that profile in cad and extrude it a few inches. locate the flapper and that is all it takes to pop out that intersection curve sketch. It took a half dozen times playing with it for it to be of any use though.
    This is seriously my favorite thread in a really long time. Big ups yo.
    Jim
    I Do Werk.
  19. #139
    Mar 09 2004
    nw michigan.
    Garrett has already machined every feature that was important to their design and budget.
    Clean up the surface geometry of the housing and the collector and match it to cad or math data. You can make quick castings of the before and after with various substances if you want. My fave involves a baggy filled with expanding foam.
    Jim
    I Do Werk.
  20. #140
    Mar 17 2006
    00 A4, 49 Ford p/u,
    Vibrant Performance
    All done and running.. to the dyno tomorrow! Woot!
    You can barely notice the difference cosmetically unless you knew what to look for.
  21. #141
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Dyno tommorrow? Im gonna hold you to that!
  22. #142
    Oct 29 2005
    10speed
    San Francisco, CA
    HoW DOES IT SPOOL?!?!?
    - Clint
  23. #143
    Senior Member Three Rings bernB5's Avatar
    Nov 13 2007
    Long Island, NY/ Hartford, CT
    wow... so far, the fastest and most successful buildup i've seen on here haha. can't wait to see the results.
    Old: 97 30r'd A4 ---> headaches
    New: Evo IX MR ---> 354awhp/349tq and couldn't be happier
    BERNSTEINphotography
  24. #144
    Jan 25 2006
    A4 2.0T
    MD
    Any driving impressions?
  25. #145
    Mar 17 2006
    00 A4, 49 Ford p/u,
    Vibrant Performance
    Quote Originally Posted by bernB5 View Post
    Well things move a bit faster when its a day in and day out thing... plus I'm not quite as swamped with mani orders right now. Don't worry the A4 will probably go slower.
    So far the impression is good, w/o being on the dyno its hard to catch when I need to change timing and fuel for the flapper activating. Some of the time on the dyno will just be wasted trying different things.
  26. #146
    Oct 27 2007
    In the lab
    Jay...
    Dyno, dyno, dyno, dyno, dyno, dyno, dyno!!!!
  27. #147
    Established Member Two Rings blkb6a4's Avatar
    Feb 24 2008
    2001 audi a4 1.8t quattro
    Minnesota
    what he said ^
    2001 Santorin blue :91 oct APR chip, atp 3" test pipe, APR stealth cat back, "dope" rear emblem, painted grill, clear corner mod, custom center vent VDO boost gauge, H&R race, 034 Snub, 034 n75H, Southbend stg5, Stoptech stage 2, A8 fat fives, CXracing 2.25 FMIC, DDM 5k HID.
    I am currently accepting donations for my BT fund PM if your interested in helping
  28. #148
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Whats psi is the actuator set to?
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
  29. #149
    Veteran Member Three Rings xraycer2012's Avatar
    May 28 2008
    B8.5 S4
    ^^^ x3, I want to see how this worked out on the dyno. This thread reminds me why I'm a mechanical engineering student, and after reading everything that Doug has said about his job, I'm definitely gonna try to get a co-op at Pratt next year.
    ‘23 RS6
    '14 S4 Nogaro Special Edition - Sold
  30. #150
    Dec 03 2005
    2 pedals 1FG
    connecticut
    SaWEEET!
    That picture of the engine bay is beautiful.
    xraycer2012 .... Sent you a PM
    -Doug
  31. #151
    Oct 27 2007
    In the lab
    Jayyyyyy...
  32. #152
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Quote Originally Posted by 317ssayzarc View Post
    Jay...
    xELEVETYBILLION!
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
  33. #153
    Mar 17 2006
    00 A4, 49 Ford p/u,
    Vibrant Performance
    I won't be posting until I get this where I want it.... give me some time... plus I'm breaking the engine in a bit. Things are going well though.
  34. #154
    Oct 27 2007
    In the lab
    Ok
  35. #155
    Registered Member Three Rings kovalevandrew's Avatar
    Oct 19 2008
    South Africa
    How about now...?
  36. #156
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Aww man, the suspense is killing me. I hope you're a fast tuner or there will be some riots going on over here!
    because racecar.
  37. #157
    Dec 03 2005
    2 pedals 1FG
    connecticut
    It is relatively easy to fabricate physical hardware.
    It is not as easy to tune even if you know what you are doing. Predominately if you are looking for a tune that works in all conditions and all spectrums of the RPM range. Not just WOT.
    [on a relative basis, esp for a one-off.. first time out of the gate]
    Patience my friends. Good things are coming.
    -Doug
  38. #158
    Feb 27 2005
    North Wales, PA
    i check this thread everytime i take a shit....so i check this thread at least 3 times a day
  39. #159
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    fine.
    because racecar.
  40. #160
    Feb 24 2008
    Minnesota
    I check this thread everytime I come near a computer!
