Results 1 to 7 of 7
    Veteran Member Three Rings Blue_S4's Avatar
    Feb 26 2008
    1968 plymouth roadrunner 440+6
    Rockford, MI
    k04s go BOOM!!!!!
    K04s took a dump on me. so i picked up some k03s fro cheap. put them in this weekend so car drives fine again.
    car for trade or sale...looking for a 6-speed.
    http://www.audizine.com/classifieds/...p?product=3358
    B7 RS4...mmmm.
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Re: k04s go BOOM!!!!!
    mileage on k04s?.. what software? boost?
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    damn. did the car have boost leaks/vacuum leaks?
    Dec 11 2006
    Boston
    Didn't you just have these put in?
    Feb 26 2008
    Rockford, MI
    k04s had probably 80k on them, the original owner put them in....no leaks, stage 1 chip, ~15psi
    the problem was one of them began to leak pretty bad, so its needs to be rebuilt, and the other was real dry...one of the oil lines was clogged real bad, clean now!
    The k03s went in just so i can have a working car. its my only car, and i need it. so at least i can drive, just not fast. was going to be temporary, but instead im selling it and buying a 6spd, then the rebuilt/upgraded k04s will go in that!!
    im thinking k04/rs6 hybrids.....havent decided.
    B7 RS4...mmmm.
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    What kind of oil do you run and how often do you change it?
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Account Terminated Four Rings
    Nov 30 2006
    01.5 pearl white S4 6speed
    annapolis, maryland
    Quote Originally Posted by Blue_S4 View Post
    ko4/997 hybrides. or even better ko4/k24 hybrids
