Results 1 to 36 of 36
    2009 A3 2.0T Quattro S-Line
    Vancouver, BC Canada
    What tranny and differential fluid do you use?
    Castrol fully synthetic 75W90
    Motul Molygear 300
    Redline
    Any other ones and which one are you using?
    IG:@steadysupreme
    Pics&Detail
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: What tranny and differential fluid do you use?
    Redline MT90 in my trans with a quart of Redline Heavy ShockProof.
    Redline MT90 in my rear diff.
    -Doug
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Motul 300 with 1 qt of Redline shock mixed in.
    Veteran Member Three Rings oldblu's Avatar
    Jan 01 2008
    Budd Lake, NJ
    don't replace it. OEM
    --Silver 2000 A4 2.8L V6 Quattro
    S4 Bumper. Borbet Type LS Wheels. M3 Replica Spoiler
    Blue! How come there's no ice
    in my lemonade?
    Veteran Member Four Rings Kronic Budz's Avatar
    Oct 01 2007
    1997 A4 2.8 QM
    San Diego, California
    are there any future problems with high mileage/older cars if you dont replace these fluids? Lets say after 120k miles on a manual tranny? Older then a 1998?
    1997 Audi A4 2.8 QM black on black
    bilstein sports w/ vogtland sports ~ S4/sport sway bars ~ 17x8 Bremmer Kraft Br05 wheels et33~ BF G's Sport COMP 2's 225/45/17 ~ Custom Exhaust ~ CAI ~ Ebay SS ~ SS brake lines + EBC red stuff ~ 35% tint/70% front tint ~ face lift headlights w/ 5000k HID + tails ~ blacked out grill trim~ kenwood mp3 ~ Polk comp 5.25" Front mm speakers ~ Infinity REF 6.5" rear speaks ~ 10" Rockford Fosgate p2 in sealed box ~ ED nine.4 4ch. amp powering woofer/polks[/I]
    Jan 01 2008
    Budd Lake, NJ
    None. The fluid that's in there is suppose to last forever. There are possible* future problems if you DO change it though.
    I had a bad experience and the audi tech guy didn't understand why I was buying tranny fluid when the stuff in there was suppose to last forever. Though there are people on here that will say you can change for the better-my luck wasn't as good as theirs. And there are stories about people who replace fluid and the car runs horribly.
    But if it's not broken, why fix it?
    in my lemonade?
    Jun 20 2007
    2012 JSW TDI
    Raleigh, NC
    Quote Originally Posted by oldblu View Post
    well then why change your oil? or rotate your tires?
    it's called maintenance..
    Veteran Member Four Rings NorCal1.8T's Avatar
    Los Angeles, CA
    my last b5(99 1.8t auto) had a bad tranny bolt that leaked tranny fluid, so i took it to a bmw specialist who use to work on audi(certified), and he didnt want to put tranny fluid in for me because its a pain in the *ss, and that was one of the reasons he stopped working on audis. I convinced him to do it eventually and i had no problems with the auto tranny, sold it 2 months later.Anyways putting in tranny fluid is no joke, and that Oem stuff is supposed to last the entire car lifetime, i wouldnt bother changing, you might create a problem.
    2018 Mercedes GLC 300
    Jul 07 2004
    socal
    Quote Originally Posted by NorCal1.8T View Post
    He must have not known the easy way to put in the fluid into the transmission. There is a plug on the top of the transmission just behind the engine. You remove the bolt that holds the plug, slide a tube into the hole and dump the fluid into the hose. Leave the side plug off so you know when the transmission is full.
    Los Angeles, CA
    Really? He told me that you have to do it from the bottom side bolt, insert a tube, then something like wait for the right time and temperature to shoot the fluid up the opening...oh man,lol...i was 16 when i first got that car 5 years ago, i didnt know squat about audis, i wasnt even on a forum, when i look back now i laugh. If that happened today, i would have done it myself no matter what the work involved.
    Jul 07 2004
    socal
    Well I learned the easy way from a head Audi Tech.
    Veteran Member Four Rings MultiAudis's Avatar
    Mar 12 2006
    01 Allroad 6mt, 01 A4
    NoVa
    I just changed the tranny fluid in my c5 a6 tiptronic @ 107k miles and in my b5 a4 tiptronic @ 103k miles, and I noticed that both shift gears a bit smoother and feel more responsive in tiptronic mode, so positive feedback on both from here. I had a long discussion with Ray at RAI about it and although we both have heard of situations where trannies went after a fluid change at that mileage, it seemed like in most cases, something was already wrong with them or the tranny was already on its way out. He highly recommends the changes and has never had an issue in the past with any cars he has flushed.
    Jan 01 2008
    Budd Lake, NJ
    Quote Originally Posted by pinky View Post
    I know dude, but audi didn't say that the motor oil would last the entire lifetime of the car...
    You maintain what can go bad, not what will never have a problem
    in my lemonade?
    Jul 07 2004
    socal
    The fluid still breaks down over time. Plus it isn't like many of us are running "stock" power.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Speaking of, I need to do my flush!
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    I use Royal Purple 75w-90 (i think....can't remember the exact number) in the tranny and the rear diff......was told it didn't need to be changed in a manual car....but did it anyway. And it REALLY made a difference. Much smoother shifting, surprisingly. Its easy to do and def worth it
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Jun 04 2007
    Austin/DFW, TX
    What all do I need to buy/how do I do it?
    Auto tranny
    My 5-Speed Swap DIY
    - B6 USP
    Jul 07 2004
    socal
    Quote Originally Posted by biketsai View Post
    Auto tranny
    Auto tranny whats that?
    Sep 16 2006
    '98 528i
    Tranny drain plug bit
    I bought a transmission fluid filler.....its like a reservoir with a pump on it so you can basically fill the transmission and diff against gravity (since you'll be under the car while filling it)
    a spare bucket to catch and dispose of the fluid
    and thats pretty much it
    Established Member Two Rings newtonc2001A4V6's Avatar
    Jan 23 2006
    2011 Audi A4 2.0T, 2004 Lexus RX330, 1977 MG-B
    Colorado
    Personally, I would rather change the fluid at regular intervals.
    The fluid may be considered "lifetime", but that is the lifetime of the transmission. I am a believer that the tranny will last much longer with regular fluid changes.
    I changed the fluid and filter at 102K and it was really dirty. Didn't notice any difference in shifting, but hopefully, the tranny will truly last a "lifetime".
    YMMV.
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    i would reccomend not doing it. My trans shifted smoother before i changed. I've tried royal purple and redline.
    (5 speed)
    Veteran Member Four Rings Euro-Tuner's Avatar
    Jan 06 2007
    NH
    THREAD BUMP
    I have my tranny out so I was contemplating doing this...seems like a 50/50 split on whether to do it or not, any more input from people who changed theirs a while ago and areaaaa still running smoothly??
    BTW I'm at 18x,xxx miles and not so stock power...
    Jul 07 2004
    socal
    My transmissions have always shifted smoother with the redline or motul then it ever did with the stock stuff.
    Veteran Member Three Rings 2001A4QUATTRO's Avatar
    Jun 05 2007
    2001.5 A4 1.8TQMS
    Just changed to motul V300 when the clutch was done and it shifts much smoother. Old fluid was jet black and seemed very thin. (89k)
    Engine : Carbonio V2 Intake - RAI 3" TP - APR cat-back w/glass pack - APR TIP - Forge 007P - 00Black1.8T Heat shield - GIAC-X - APR Snub mount - RS4 motor mounts - SB Stage 4 w/DMFW - 034 Street trans mounts - Evolution Motorsports Phenolic spacer
    Braking : Centric Cryo Black Zinc / Hawk HPS (F+R)
    Exterior : Ultrasport 18" ET43 235/40/18 - RS4 grill - Debadged - S4 sideskirts and rear lip - E-codes/Philips+ HID
    Interior : AWE boost guage / vent
    Dec 05 2007
    I changed mine and rear diff fluid with Amsoil 75w90.
    Jan 06 2007
    NH
    so with my tranny out it should be pretty simple right? just drain from the bottom and replenish the same amount into the side with whatever fluid I choose...correct me if I'm missing something
    Dec 05 2007
    With the tranny out should be even simpler as you should not need a pump to angle the new fluid into the resevoir. Aquire yourself the drain plug tool bit, make sure you can remove the refill plug before attempting (hex), remove drain plug, drain out old oil, replace drain plug, and replace till it starts to overflow (I think it is 2.7 quarts or something like that). The rear differential is the same process, but takes 1.9 quarts. 75w90 GL4 for the tranny and 75w90 GL5 for the rear diff.
    Jul 07 2004
    socal
    If its in the car or out of the car its just as easy if you use the top sensor hole on the transmission right behind the exhaust side of the engine. Just 1 bolt, take the cap off with the sensor and slide a hose into the hole. Then you just feed the gear oil in from the engine bay. No need to lay under the car. Just leave the side plug off so you can see when the fluid has reached that spot, then just put the plug backs back on and your done.
    If the transmission is out of the car you dont even need to remove the bottom drain plug. Just tip the transmission on its open bell housing end and open the normal feel plug, just tip it a little to get out all of the fluid.
    Jan 06 2007
    NH
    so the full mark is basically when it reaches the side plug? thats easy enough, where is a good spot to buy Motul 300 and redline shock?
    Veteran Member Four Rings J Ozzie's Avatar
    Jun 06 2008
    Port Moody, Canada
    Since this is goin how many qrts in the tran? The guys that did my clutch didnt drain the fluid because they didnt have the drain plug..
    2014 Audi Q5 TDI - Brilliant Black | LED Fogs | VCDS Mods | LED Interior swap |
    R.I.P... (wrecked)2005 Audi A4 1.8TQM 6Speed
    R.I.P..2001 Audi a4 1.8TQM (casa white no sunroof)
    Vancouver Audi Club.ca
    where's our resident intoxicated lobster Canadian - Thomas
    Dec 05 2007
    Quote Originally Posted by J Ozzie View Post
    Jun 06 2008
    Port Moody, Canada
    lol thanks... Yeah thats what i figured. ill just use the mt90 as 2 and the shock as .7
    Oct 01 2007
    1997 A4 2.8 QM
    what is the shock? What is the point of it and what if u were to not add it to a tranny with say over 120k miles? (5 speed)
    Jun 06 2008
    Port Moody, Canada
    its when you grab the tranny with both hands and shake the shit out of it to mix the fluids..
    LOL
    Sock = Shockproof its a thicker gear oil and im guessing why people are starting to add it in is to protect the gears when givin er!
    Is putting shock proof in the rear diff a good or bad idea?
    IG:@steadysupreme
    Pics&Detail
    Veteran Member Three Rings hazard860's Avatar
    Aug 22 2011
    1984 gti, 2001.5 s4 (stg3)
    Lebanon, CT
    i feel if you did drain it, (unfortunately i did too) worst case is put new OEM fluid inside. i have some random junk fluid in mine, so gotta re-do it, i didn't wanna touch my tranny fluid but i'm sure there's meta shavings in it, so gotta do that too
